Question about Tappan TGF320 Gas Kitchen Range
Constant beeping from the clock/timer
My stove has started a steady beeping noise and it is very annoying. I have resorted to unplugging it until I need to use it. Any suggestions as to what is causing this? I was wiping off the stove and all of a sudden it started beeping.
    Scholar:
  • 110 Answers
Sound as if u got water in your controls which would cause the electronic clock assembly to short. unplug for 24 hrs to allow it to dry if the probelm coming back it eca is bad
Posted on Jun 01, 2008
Two burner s on Kenmore gas range will not ignite. When set to Lite Igniter clicks but burner does not ignite. Clock beeps and blinks
Hi I forgot to comment on your clock beeping and blinking that is a short. If you have someone or you can do it yourself that back panel comes right apart a couple of small screws, then can look in the back and it's probably either grease or dirt but cooking grease is a conductor of electricity as you know. it's annoying absolutely but electricity plus Grease equals fire! PLEASE UNPLUG it before you do anything and check out the wires from there. Do not spray anything on to the wires spray your cloth and gently go from there if you see a break in the wire do not plug it back in until the wire is repaired!
**NOTE** you will not have electric ignition for your stove top... but not to worry, you can light your stove with a match if need be.
Nov 06, 2016 | Miscellaneous
My wall oven is making a constant unusual noise
Without a model number its hard to be exact. If your oven is older it will have a clock timer motor that turns the dials or flips the clock display cards. This timer has gears and bushings that will be annoying as they wear and start a vibrating hum or clicking-usually not worth tinkering with..it can be taken out and checked or replaced. Electronic timers of course don't have any moving parts to the timer, but have relays in the circuit to turn the oven on and off. They do not 'whir'. This is the likely issue.
Repost..let us know.
Apr 28, 2015 | Ovens
How to disconnect beeping hotpoint stove digital timer/clock?
Good Afternoon Patti,
I understand that your Hotpoint stove digital timer/clock is beeping and you are wondering how to disconnect it. I suggest resetting your stove by either unplugging it or disconnecting the power at your home's circuit breaker for 3-5 minutes. When power is restored, if your stove is still beeping, I suggest contacting your local authorized technician. They will be able to diagnose your appliance and determine what the cause of the beeping is. They will also be able to assist with repairs, if needed. Hope this is helpful.
-Best Regards-
WP
May 06, 2014 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire FRA186MT2 beeping noise
sounds like you have a problem with the temperature probe - system defaults from temp to a time cycle if the probe fails
Nov 28, 2013 | Refrigerators
I have a vintage Hardwick gas stove squealing sound coming from the range when oven has been on? Thought it might be the clock/timer.... can't tell and very annoying? Thoughts?
It could be your clock when the clock gets old the clock motor can start sqeaking. It is unusual if it only does it when the oven is on but perhaps it is heating up and then starts to make noise. the only other thing I can think of is your oven safety valve may be not opening completly and causing a whistle.
Dec 02, 2012 | Kitchen Ranges
What is the EOC and how much does it cost to replace? Can I replace it myself or do I need a professional to replace it?
kenmore stove model #c970635326 serial #nf70205945 is showing f11 on the clock and a constant beeping noise.
when you unplug and plug it back on the clock show 12:00 for a few seconds then the f11 shows again and the continuing beeping noise
how much is an eoc to replace....can i do it myself....
Jan 09, 2011 | Kenmore Ovens
I want to turn off the clock on the stove
i want to turn off the clock on my whirlpool stove
Jan 06, 2010 | General Electric Stove/Oven/Range Chrome...
I have a Tappan gas stove. Don't know how old the stove is as the stove was in the home when I purchased it. Six years ago we had a power outage. When the power was restored the clock started beeping. Only...
Try disconnecting the AC to your range and leaving it overnight. If this doesn't help, the clock has probably been damaged by a power surge during one of the dropouts.
Oct 25, 2009 | Kitchen Ranges
Hi; We have a Whirlpool Gold range and stove - roughly two years old. The stove works but the oven and all functions ie clock set, timer do not work at all, not even a beep or anything appears on the creen...
Try holding down the off button for 5 seconds and if this does not work the start button for 5 seconds. Unplug for 5 minutes first. Then try holding the button and then set the clock.
Aug 25, 2009 | Whirlpool GR773LXSS - Stainless Steel...
PF on Whirlpool super capacity 465 electric Stove Model RF366PXGW2
PF = Power Failure. Sounds like you have a bad electrical connection. With your breaker off, check that the connections from the cord to the range are all good and tight. Next, check the receptacle where the cord plugs in. Remove the cover and check the connections there as well. Examine the power cord also. There could even be a poor connection at the breaker box (at the circuit breaker or the neutral buss bar) but not as likely, as your problem appeared when you moved your range.
Oct 19, 2008 | Whirlpool RF378LXKS Electric Kitchen Range
Tappan TGF320 Gas Kitchen Range Logo
346 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
