Question about Whirlpool LEQ9858L Electric Dryer
How do I get to the back and the controls? - Whirlpool LEQ9858L Electric Dryer
  • 171 Answers
To get to the controls you need to pop uo the top panel and this is done by using a screw driver with a cloth over the end so it does not scratch it . Put the driver in the gap between the top panel just above the door and pry the top up as it is held on by metal clips. they are along the front as well as the sides.good luck !
Posted on Oct 12, 2010
I have a GE gss25tgp, I was hearing noises earlier now i just went back to the fridge and now the water dispenser and ice dispenser aren't working would that be a control board issue?
The dispenser control board is fed from the main control board located in the back. The main control is usually the root of most problems .Order from repair clinic if it does'nt work they will take it back.
Dec 05, 2016 | GE GSS25TGPWW / GSS25TGPCC Side by Side...
Burner says hot.. wont go off, moffat stove
Hello;
My name is Peter. I am a retired field service appliance technician.
I assume you have an electric oven.
You have a defective individual burner control.
1.) Pull your oven out so you can get behind it.
2.) Unplug your oven.
3.) Remove the upper back metal cover.
4.) At the top in the center is your main oven control board. On the left are two burner controls and on the right are two burner controls.
5.) Inspect the burner controls for burn marks or melted wires.
6.) Finding the bad control unit, pull the control nob off the front.
7.) Unscrew the burner control in the front.
8.) Remove the connectors on the burner control.
9.) With the burner control in hand. re-attach the upper metal back panel on your stove.
10.) Pug in the stove and push back in place.
11.) On the burner control that you just removed note the part number. Search on the internet for best price.
12.) Continue to use your oven without the burner control.
13.) Install the new burner control when received. Remember to un-plug.
May 15, 2015 | Kitchen Ranges
How do i re install the oven control board?
It's very easy.. Pull your oven from wall and take screws from back of panel.. You will see control board after removing cover panel. Take screws from control board or could be attached with clips. Pull wires with plug ends off of board and reinstall on new board. (In same places of course). Put control board back in and put cover panel back in and screw down and plug back in. Make sure all power is unplugged before servicing.
Jun 06, 2014 | Ovens
My phenom controller wont connect unless connected to usb
1 Hold your controller like you normally would when playing a game, and then flip it over. 2 Use a paperclip to hit the Reset button on the back of your controller. The button is located to the right of the screw found above the sticker on the back of the controller. 3 Connect your controller to your PlayStation 3 using the USB cable. 4 Press the PS button on the front of the controller. The system will boot up, and your controller is now reset and synced with your PlayStation 3. Tips & Warnings: If you use the same controller for multiple PS3 systems, you should do this whenever you notice problems with your controller, since it could resolve the issue. Don't press the reset button on the back of the controller too hard. Otherwise you risk damaging your controller.
Source(s):
http://www.dwtechz.com/
Jan 24, 2014 | dreamGEAR 1012587 Phenom Wireless...
How to install a damper on a Frigidaire side by side
Installing the new damper control takes just minutes. The replacement damper control comes with a foam mounting gasket. Remove the paper backing from one side of the gasket to expose the adhesive; press the gasket to the back of the damper control. Now that the gasket is mounted to the damper control, you can mount the damper control to the freezer wall. Peel the paper backing off the other side of the gasket and press the damper control to the mounting area. The wiring harness and thermistor attach to the right side and bottom of the component, respectively. Replace the damper control cover and reinstall the removed mounting screws.
Mercedes wheels
May 31, 2012 | Frigidaire Refrigerators
I need a replacement 27MHz remote control for a Playskool Tonka Bounce Back Racer model #09995. This model has been discontinued. Would another 27MHz remote, with forward & reverse control features...
Yes! The FastLane brand works. I thought my bounce back was a loss because the remote doesn't work until my older daughter played with her remote control car in the same room. The Tonka Bounce Back responded very well to the FastLane remote. And fortunately, FastLane is pretty inexpensive. Good Luck!
Jul 10, 2011 | Playskool Tonka Bounce Back Racer Remote...
NORTON GO BACK HAS CONTROL OVER MY COMPUTER
JUST UNINSTALL IT FROM
CONTROL PANEL>ADD REMOVE PROGRAMS or vista/7 control panel>programs and features
Apr 11, 2010 | Sony VAIO FRV37 Notebook
Putting the L1 and L2 keys into the ps3 controller
They just snap in after the controller is back together.
Nov 12, 2009 | Sony Wireless Controller for PS3
Whirlpool LEQ9858L Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
