Kenmore 110.26322503 fills, agitates, drains, everything fine. When it gets to the spin cycle, however, it doesn't spin and just makes a clicking noise. What is causing this?
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 15Oz of gear oil (auto parts store) , remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Oct 12, 2010
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
HELP!! Washer machine wont work. Doesnt drain or spin. Clicks to drain and spin but nothing happens, the timer still counts down as if everything is fine.
If the machine starts, fills and goes through its' agitate cycle fine, the problem is likely not in the motor or transmission.
This type of washer uses a reversible motor. When turning one way, the machine agitates the clothes.
When the timer gets to the spin cycle, the motor reverses, drives the pump (directly from the motor) for a period of time and then goes into spin cycle.
This appears then that is is either the connection to the motor itself or the timer.
The timer is driven by a separate motor on the control panel so if the contacts for the spin cycle are worn, the timer will move but the motor won't turn on.
Sep 09, 2009 | Washing Machines
Kenmore washer will not spin or drain water,agitate works fine
Sounds like a lid switch. there should be a hole under the lid on the right side about the size of a dime. Make sure the plastic "flipper" is inside and "clicks" when you push down on it with a pen.
Apr 20, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will fill with water but the agitator won't spin.
No agitation or spin in any cycle? If so and the machine will drain check the coupler.
Oct 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore Elite King Size Top Load Washer
If your washer fills, agitates, drains, but will not spin, the likely cause is the gear case (transmission). A new gear case can run about $200 just for the part. With labor, this could be a bit expensive to repair. I hope this helps you some.
Jul 30, 2007 | Kenmore 22642 Top Load Washer
Washing Machines Logo
133 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
