Question about GoVideo DV2140 DVD Player/VCR
Baby pushed buttons and now the unit is in a locked mode
    Scholar:
  • 143 Answers
Http://dl.owneriq.net/6/67159ef8-48c4-49fa-abaa-9b186082968e.pdf The manual is here. The instructions say to simply press the button on the remote to unlock....
To disable the LOCK function, press CHILD
LOCK on the remote control until OFF appears
in the display window.
Please leave feedback!!!! Thanks!
Posted on Oct 12, 2010
Buttons won't work on my baby lock
Is there one stuck button? Get it loose so the others can be pushed
Jun 02, 2013 | Baby Lock Sewing Machines
Tip
HOW TO FIX BUGABOO WHITE SEAT BUTTONS
To fix it yourself, you need to disassemble the buttons, which can be done with two screwdrivers one a thin slot type the other a Phillips. Here is the process: 1. On the other side of the white button unit is a screw. Remove it using a Phillips screwdriver.
2. You'll now have a black housing with a white button held in by three white tabs. 3. Free the white button from the housing by pressing inwards on each of the three tabs with the slot type screwdriver.
4. You'll now have a black base, a spring and a white button. Pay attention to how the two black parts align to each other so you re-assemble it correctly.
macnutz_28.jpg.
5. Pop the white button out of the upper black surround. Sand the circumference of the white button evenly until it slips easily in and out of the black surround. A little silicon spray is a good idea.macnutz_27.jpg
6. Reassemble unit and check it has full movement (see photo below). macnutz_30.jpg
7.
On the underside of the button unit a ramp shape should lineup with an opening in the bottom edge.macnutz_33.jpg
8. Fit button unit back into upper seat leg, Fit lower seat leg aligning it to the back of the button unit so the push rod in the lower seat leg pushes on to the ramp on the button unit. Note the seat button will not come out and lock until the seat is fitted back on to the chassis pushing the rod up to push the button out to the lock position. Once you have fitted the back screw in you can use a large screw driver to push down the inside of the lower leg to check the white button pops out and locks. If you have any resistance dismantle again to check alignment and the condition of the interlocking teeth of the button and the outer rings. Sand of any burrs and use a little silicon grease. Reassemble and test again.
Repeat operation to the other side if necessary. Buttons are not interchangeable so doing one side at a time avoids mixing them up.
If the tabs on the white button are broken you can buy a new button unit as a part www.babycare.nl/bugaboo-cameleon-seat-frame-push-buttons-p-2664.html
on Jan 14, 2011 | Bugaboo Cameleon Jogger
Tomy baby monitor srv 400 instruction
Page 1 SRV Series (Model SRV400) Q & A'sQ. My Parent and Baby (Camera) Unit have lost contact, what should I do?A. It may be possible that the encrypted code pairing both units has corrupted, to reset the code please
follow these instructions;
1. Place the Parent Unit next to the Baby Unit.
2. Activate both Parent and Baby Units by pressing their respective ON/OFF buttons for greater than
2 seconds.
3. Press the Mode/Enter Key to enter the Parent Unit's Main Menu screen.
4. Using the four-directional Navigation Keys, select the 'Add/Remove Baby Unit(s)' option and
press the Mode/ Enter Key to confirm your choice.
5. The current status shall now appear, showing all four Camera Units shaded grey;
6. To reconnect the Camera unit to the Parent Unit, using the Parent Units Navigation Keys ensure
the green circle is highlighting 'Camera 1'. Now press the Mode/Enter Key
7. Select the 'Add' icon with the plus symbol and press the Mode/Enter Key.
8. The screen will show the Parent Unit at the bottom transmitting a signal to Baby Unit
Jun 05, 2012 | Baby Care
Hello Am having great difficulty reassembling our bugaboo after fixing white buttons. Am aligning lower leg with the ramp inside button. When I screw it all up again the lower leg and the outside of the...
With the seat unit face down push down inside the lower leg unit with a screw driver, The white button should pop out. If it does not either the button is stuck or the locking splines on the outer sides of the button unit are not sliding freely into the spines of the outer ring. When you push down with the screwdriver your force only pushes the back of the button unit. It is the inner spring that has to move the white button and the locking splines so any burrs or roughness can stop its movement. www1.fixya.com/support/r7805137-fix_bugaboo_white_seat_buttons
Oct 19, 2011 | Bugaboo Cameleon Jogger
My babylock ellure won't work on the embroidery mode, but works on the sewing mode. I only use this machine for embroidery. When I turn it on it tells me to lift the pressor foot, which I do, but nothing...
Ours did the same thing. They said it was the circuit board for embroidery that went bad. The one for sewing is still good. They wanted $200 to $300 to replace it.
Oct 19, 2010 | Baby Lock Ellure
Sv370xvt, remote instruction tv has no screen picture baby pushed button...have no idea which one, now no pic
Babies.............Aren't they precious? Yeah, until they do stuff like this and can't tell you how to change it back. :-) :-) :-)
I'm thinking you got pushed into VIDEO MODE. Try using the input button on your remote. Hopefully that does the trick.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Vizio L37 Television
How to program regency model 1070 scanner? I program scanner,yet unsure why no ''frequencies'' stop.Only zero flashes>
I couldn't locate a manual for you, but this vintage 10-channel unit is fairly simple to operate.
Start by turning the unit on with the POWER button.
Push the MANUAL button.
Push MANUAL until you see the Channel you want to enter the frequency in -i.e: Ch 1, Ch 2, etc.
Enter the frequency with all the digits needed - i.e: 44.94 / 44.98 / 154.965 / 155.610 etc
Push the ENTER button. The frequency will now be in the Channel "Ch" you chose.
While still in the manual mode - go the the channel you expect to listen to most - then push "DELAY/HOLD". This will hold the scan so you will get the reply from the dispatch unit to the receiving unit.You can set this feature on any or all of the ten channels.
Push the "LOCK" button to lock out channels you no longer want to listen to, or that you want to ignore temporarily.
Dec 09, 2009 | Radio Communications
I cant eject cd/dvd changer.
there may be a lock/unlock selection in the menu somewhere, something like a parental lock on tv sets, this is just a thought on my part.
Mar 25, 2009 | Panasonic sa-ht930 Home Theater Audio...
CDC-X304 in permanent DEMO mode
I HAVE SAME PROBLEM. AFTER I REPLACED MY DEAD BATTERY MY AIWA CDC-X304 IS STUCK IN THE DEMO MODE. ONLY CD WORKS BUT ALL BUTTONS ON FACING DO NOT RESPOND. ANY SUGGESTIONS HOW TO RESET.
Jan 16, 2008 | Aiwa CDC-X304 CD Player
FW-R7 displays "Locked" when attempting to open CD Trays
You were close, but didn't explain it very well. If you push on the 'DISPLAY' button (left side of machine as you are facing it, about half way down) when the unit is off, it will say something like "DEALER MODE", push it again to return it to regular mode. You may have to press and hold the button to get it to display 'DEALER MODE', then when everything is normal, "DEALER MODE" just goes off and isn't replaced by anything. Hope I explained it well. nyati585@aol.com
Feb 09, 2007 | Philips FW-R7 CD Shelf System
GoVideo DV2140 DVD Player/VCR Logo
137 people viewed this question
Top GoVideo Televison & Video Experts
 Grubhead
Grubhead
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
