Question about Sony KP-51HW40 51" Rear Projection Television
Speaker cover what is the best way to clean the gray fabric on the front of the tv?
  • Justin
    Justin Jun 30, 2008
    thanks but a simple damp cloth will not get oil from human skin off of the screen. ive tried that.
  • 868 Answers
Damp cloth
Posted on Jun 07, 2008
2008 dodge ram speaker polarity
Here is the radio wiring.
2008 Dodge Ram 1500 Car Stereo Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Ground Wire: Black
Left Front Speaker Positive Wire (+): Dark Green/Yellow
Left Front Speaker Negative Wire (-): Dark Green/Light Blue
Right Front Speaker Positive Wire (+): Gray/Yellow
Right Front Speaker Negative Wire (-): Gray/Light Blue
Left Rear Speaker Positive Wire (+): Gray/Light Green
Left Rear Speaker Negative Wire (-): Gray/Dark Green
Right Rear Speaker Positive Wire (+): Dark Green/Gray
Right Rear Speaker Negative Wire (-): Dark Green/Light Green
Jul 14, 2017 | Cars & Trucks
1999 dodge truck speaker wire coler picture diagrame
2010 Dodge Ram 2500 Car Audio Installation Guide
Left Front Speaker Positive Wire (+): Gray/Violet
Left Front Speaker Negative Wire (-): Gray/Yellow
Right Front Speaker Positive Wire (+): Dark Green/Violet
Right Front Speaker Negative Wire (-): Dark Green/Yellow
Left Rear Speaker Positive Wire (+): Gray/Dark Green
Left Rear Speaker Negative Wire (-): Gray/Light Green
Jun 29, 2012 | Cars & Trucks
Does anyone have an audio system wiring schematics for a '02 montero sport with an infinity amp? color code?
http://www.the12volt.com/installbay/stereodetail/1582.html
This is the best I could find. Hope it helps.
May 04, 2011 | Car Audio & Video
I've bought an adapter thing, but I don't understand how to wire these wires.
  • Yellow - To the car battery of continuous +12VDC
  • Red - To ACC Power, +12VDC
  • Black - Ground, to bare metal or clean part of the car
  • Dark Blue - Motor Relay control lead for Antenna
  • Dark Blue / White Strip - Amp Relay Control lead
  • White - Front/Left Positive Speaker
  • White / Black Strip - Front/Left Ground Speaker
  • Gray - Front/Right Positive Speaker
  • Gray / Black Strip - Front/Right Ground Speaker
  • Green - Rear/Left Ground Speaker
  • Green / Black Strip - Rear/Left Ground Speaker
  • Violet - Rear/Right Positive Speaker
  • Violet / Black Strip - Rear/Right Ground Speaker
Nov 11, 2010 | Panasonic CQ-DP133U CD Player
Stereo Wiring Colours
2006 Ford Focus Car Stereo Wire Color Codes
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Jul 11, 2010 | 2006 Ford Focus
I am looking for a replacement part for my Toshiba TV (model # 57H94), the bottom speaker cover.
What is the problem with the speaker cover? Is just the mesh damaged? If so you would have better luck replacing the mesh fabric yourself. You can purchase good replacement mesh fabric and adhesive at www.parts-express.com under speaker building supplies.
Oct 13, 2009 | Toshiba PSS421S TV Speakers
How did you remove the front speaker cover?
Should find 2 screws in front down on bottom behind gray cap one on left and one on right side.
Aug 18, 2008 | Sony KP-51WS510 51" Rear Projection...
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Wiring harness
This is on the case of the CD-335X
Line Out
gray (rear)- red/ right, white/ left
Power
Red- ign
Yellow- batt B+
Black- ground = neg12 volt
dark blue- power ant
orange- dimmer
Speakers
gray- right front (+)
gray/ black- right front (-)
White- Left Front (+)
white/ black- Left Front (-)
voilet- Right rear (+)
violet/ black- Right rear (-)
Green- Left Rear (+)
Green/ black- Left rear (-)
use 4 or 8 ohm speakers
Aug 25, 2007 | Jensen CD-335X CD Player
How can I clean the gray fabric covering speakers?
the cover should be held on by 1/4" hex head screws, you can use a 1/4" nut driver to remove them, I dont know if they are 2 on the bottom or 6 from behind on the sides. then the fun of trying to clean the stains? maybe some hydrogen peroxide?
Jul 07, 2007 | Sony KP-51HW40 51" Rear Projection...
Sony KP-51HW40 51" Rear Projection Television Logo
32 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
