Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
I have been reading your posts about the convergence IC repairs as my JVC AV56 just lost its convergence. I believe I can solder the ic's in with out any problem, but how do you identify which resistors that may need to be replaced?
  • 998 Answers
It has the value color coding try to check it commonly the value is changing.
Posted on Oct 12, 2010
Double picture on my jvc big screen
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. Your symptom sounds like a damaged convergence IC.
If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
*** VERY IMPORTANT NOTE***
If your set is not producing a clear picture and the colors are not lining up, do not continue to watch the set as this can lead to further failure and possibly damage the individual CRT’s in the set.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
How do I tell if the IC’s are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC’s. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC’s located and how do I find them?
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Jul 24, 2010 | JVC Televison & Video
When looking at any words on the screen there is a double of the words in blue and it arches upwards. It's not jsut he words, yet this is the best way to discribe the problem.
Their site is
You can also try
asnowman
I have attached some photos of really bad convergence problems; your picture may not be exactly as bad as these.
Mar 23, 2010 | JVC AV-48WP30 48" Rear Projection...
Double and blurred print and blurred picture.
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. What you might be experiencing based on this symptom sounds like a convergence IC problem. But if the set fixes itself you will need to have it repaired as soon as possible if you wait too long there are several components that will fail in due time. If you want to repair it yourself or know someone that can solder components on the circuit board, you will need to re-solder the convergence IC’s. All you will need is some solder wick, a good 45W soldering iron, Acid free solder and some solder wick (this is for the clean-up of solder joints and cleaning up solder bridges.
With any Projection Television that has a damaged or interment convergence problem, you do not want to continue the use of the set. If the IC’s continue to fail they will cause a short in the power supply and cause your television to not power up, and possibly damage the CRT’s in the set.
When looking at the area around the convergence IC’s you see some resistors that have changed colors, or you test a resistor and it no longer reads the marked value. You will have to replace the IC’s and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulation for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Their site is
You can also try
http://www.tvrepairkits.com/ , I have not tried them yet, but they do carry OEM or better parts.
asnowman
Dec 04, 2009 | Televison & Video
How do i get the convergance to work??? The up an down side to side buttons don't work
Their site is
You can also try
asnowman
Nov 30, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT56HX41PF projection TV. Image blurred up, color halos around objects on screen. Convergence in set up mode cannot be adjusted to compensate.
Their site is
You can also try
asnowman
Nov 29, 2009 | Panasonic Televison & Video
I have a Panasonic PT53Wx52C and although i line up the convergence, the picture, especially when not close-ups, are very fuzzy. Any idea what I can do to remedy? Please
Their site is
You can also try
asnowman
Nov 29, 2009 | Panasonic PT-53WX53 53" Rear Projection...
We have a red shadow on all images. Almost
Their site is
You can also try
asnowman
Nov 17, 2009 | Panasonic Televison & Video
I have a 53 in panasonic rear projection tv with a rainbow effict. what can I do?
Their site is
You can also try
asnowman
Nov 17, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Convergence of color with Mitsubishi Model #VS-60707
Your symptoms sounds like at least one damaged convergence IC.
You are correct you can sometimes rework the solder connections on each of these IC’s, although, if the convergence does not fix itself from time to time, you most likely do not have a bad solder connection. You will have a faulty IC. I recommend to replace them both at the same time because the chips legs can fall off due to the heat of the IC.
Please be sure to remove all of the white heat sink compound on the heat sink and apply a even coating over the back of the new IC’s. You should also bolt them down before you solder them in so that you have them at the correct height.
There are two and sometimes three very large IC’s that control the convergence in a big screen set. I believe that your set has two. They are secured to a very large aluminum heat sink. I think that the IC numbers will be IC8001, 80002.
The IC’s are large and black, you cannot miss them. They will usually have an STK-XXX number on them.
There are several schools of thought on the replacement of parts and I firmly believe that you get what you pay for, so don’t buy the cheapest IC’s that you can find. One company I worked for tried this and it only caused more work for the technicians, as we had to replace them with the more expensive ones in the end. I would think that you should be able to find these for around $60.00 each. If you can find the exact Mitsubishi part, even though the numbers on the front are the same, and they look exactly like the $10,00 ones, they are better and more reliable.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up)
Please Note: If you can not rate this post with the highest rating, then please do not leave any rating. I am doing this for free and I do not think that any rating other that the best is needed.
Jul 03, 2009 | Televison & Video
Convergance/coaxial cables
Check any / all soldered in micro fuses...F851,F852,etc.
Note:read my Powered Products>View all>Toshiba>convergence issues .........? What quality IC's did you use and what price did
you pay ?............................T.
Mar 12, 2008 | Toshiba 50HX81 50" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
44 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
