Question about Dryers
For whirlpool duet GGW 9250 PW0 GAS DRYER How do you know if the gas solenoid are bad? I check the resistance as per manual and its within its limit. It ignites and flames come out but the flame only last for 17 secs the first ignition and from there on it only last 7 or 8 secs. Ignition goes every 2 to 3 minutes, but still only 7 to 8 secs of flame out. do you think its still the gas solenoid?
    President:
  • 1,554 Answers
The gas valve solenoid coils work when cool that's why the resistance reading is within the limit but fail when heated. Bypass the thermostat on the burner funnel and if the flame still goes out too soon, the coils are weak and both must be replaced. The resistance reading is reliable only when the dryer does not heat at all or shall we say the flame does not go on at all and the purpose is to check the continuity of the coil.
Posted on Oct 12, 2010
Whirlpool Duet Gas Dryer, runs about 2 seconds then shuts down. Time remaining display flashes
raoul answered just now
come fare il reset della scheda della lavastoviglie whirlpool ADP 5555 per cancellare un errore dovuto a sensore sporco? non vorrei chiamare l assistenza solo per questo.
Grazie
Feb 06, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dryer runs as normal thru two cycles of the burner then the burner does not restart. the igniter heats up but the burner will not come on. All controls are within specs. Can the flame sensor...
It could be defective but be careful as gas appliances are very dangerous and any work on gas appliances must, by law, only be carried out by a local competent gas service person with licence , preferably CORGI registered, and must comply with 'Gas Safety and home insurance policies regulations
Oct 12, 2013 | Whirlpool Gas Dryer Flame Sensor 338906
Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 01, 2011 | Whirlpool Dryers
My whirlpool duet gas dryer will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Smell gas coming from whirlpool duet gas dryer. Its not the gas line.
Hi, Often times that is because it is not lighting right...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Nov 04, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Gas dryer duet does not heat up? what could be the problem
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 02, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
MY WHIRLPOOL DUET DRYER IS WORKING BUT NOT HEATING
heatman101
Jul 12, 2010 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryer is spinning, but there is no heat. How do I
The Duet manual referenced below will help you with diagnostics.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/479b6231e5693a13852571650061e709/$FILE/8178559.pdf
Jan 17, 2010 | Whirlpool Dryers
No Heat on a whirlpool dryer. 14 years old.drum turns,timer moves,getting gas to valve,tapped solenoids-no change.burner not lighting. thanks for any info
if ignitor not coming on could be flame sensor mounted on side of burner housing or ignitor ..if ignitor glowing but burner no lighting replace both solenoids bad connections interally on solenoids..also if ignitor not glowing possible small white thermal fuse open.. sensor and fuse can be jumped across to confirm ..
Dec 22, 2008 | Dryers
Dryers Logo
202 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
