Question about Hitachi 35TX79K * 35" TV
My Hitachi television, 35TX79K V5J000359, made in Mexico City, Oct, 1995 has line that goes horizontally across the TV, occasionally...would this be the picture tube going out... more info 60Hz, 210W, 2.8 A...Thank you for any help...
  • 998 Answers
Its not the tube it the vertical ic it is defective try to replace it commo9nly it is a flat silicon with a heat sink it has many pins.
Posted on Oct 12, 2010
Older big screen hitachi w/pip tube tv and has blue lines across the screen turn off on it own sometimes.
It could be time to retire the TV.
The blue almost horizontal lines are probably a fault in the flyback blanking and the fact that it will turn itself off is likely due to a poor solder joint on a circuit board inside.
Jun 26, 2016 | Hitachi Televison & Video
Power
this a simptom for power supply: you need test with a VOM the line cord, fuse, c.breaker, rectifier, filter, switch, IC regulator, etc for open, short, or leaky.
God bless you
Jul 17, 2013 | Hitachi 35TX79K * 35" TV
Have a 50fx48b Hitachi TV, screen flickers, gets wavy and goes to horizontal line, smack top of tv and it goes back to normal.
This problem is a couple of bad caps in the vertical and horizontal sweep area, just can't remember which. It use to be a 220uf cap that needs changing.
Feb 28, 2011 | Hitachi 50FX48B 50" Rear Projection...
Has pink/green horizontal line across top l corner
Hi,if your tv is dlp or lcd you will need to replace the light engine that's in charge of creating the image and colors, and when bad you 'll get discoloration or lines across image.
Oct 01, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Horizontal lines across middle of screen sometimes
Vertical problem coming from bad solder, or vertical circuit problems!!!
Check for bad solder and capacitors problems in vertical circuit.
Aug 30, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi 51GWX Scrambled Picture
STK392-560 STKS convergence CHIPs Replace both of them.
Feb 24, 2008 | Hitachi 51GWX20B 51" Rear Projection...
Picture reduced to a horizontal line across center
sounds like the vertical, more info ctechnicians.com
Dec 21, 2007 | Hitachi 35UX80B 35" TV
Televison & Video Logo
119 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
