Question about Husqvarna Viking 1
My Viking Quilt Designer wigs out in the needle down setting. It makes a loud noise, the presser foot jerks up and down quickly, the light dims for a moment, then if I continue to sew, the presser foot no longer does the half lift to allow pivoting. In fact, most of the time it goes through this 'seizure' if left in needle down. If I turn the machine off for a moment it is okay for a small amount of time, then it will do the same thing after a few minutes of use. Needle down is a major feature I would like to use, but I rarely can. My machine has done this for years, even though it has been serviced. Hope you can help!
  • gottaquilt Oct 12, 2010
    The problem with my Viking Husqvarna Quilt Designer is much like the experience many of us have with our cars - it won't exhibit the problem when the mechanic is with you, or when he's taking it for a test spin - and my machine won't act up for the technician. That's why I'm throwing the question out there online. It has some sort of 'fit' after I've used it in the needle down position for some minutes (I've never timed it). It makes an an awful sound, the presser foot jumps up and down, many times the needle goes down and sticks down, the light dims while this is happening, then I'm not able to use the needle down setting. If I turn the machine off for a moment I will be able to use needle down, but it happens quickly again. Has this happened to anyone else? Please let me know, I don't even care if you know how to fix it, I'd just like to hear from you.
    Frustrated,
    Gottaquilt
  • 15,935 Answers
What is the model # please?
Thanks!!
Posted on Oct 12, 2010
    Brigadier General:
  • 3,513 Answers
This seems a service call. Please click on the article bellow to fix this:
http://www.husqvarnaviking.com/us/2821_3079.htm
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Ran over pin. Broke needle, replaced it. Was jammed pretty good. Cleaned out bobbin compartment. Dogs look good, but motor doesn't run. Lights come on, stitch card functions. Viking husqvarna Quilt
Oooh, ouch!!! Were you able to get all of the needle pieces out of the machine? Unfortunately, it may have knocked the machine out of time or bent/damaged some internal mechanism necessitating professional service.
In the future, instead of placing pins horizontally across the seam line, align them parallel with the seam edge--far enough away to clear the presser foot. Sew slower and remove the pins before they get to the presser foot. Broken needles can be dangerous to you and the machine--as you already know.
Apr 07, 2016 | Sewing Machines
Bobbin winder is malfunctioning. Has difficulty engaging in place and will not wind.
VIKING QUILT DESIGNER II USER MANUAL Pdf Download.
www.manualslib.com > ... > Sewing Machine > Quilt Designer II
View and Download Viking Quilt Designer II user manual online. Quilt Designer IISewing Machine pdf manual download.
Viking Husquavarna Designer II Sewing Machine - YouTube
? 1:27
www.youtube.com/watch?v=k0mXebnmzT4
May 30, 2008 - Uploaded by proudpop9pj
Here you can view my Viking Designer II Sewing Machine at work. The first two times I used the foot pedal, the ...
Aug 12, 2015 | Husqvarna Designer I
How to adjust pressure foot pressure on husqvarn viking disginer 1 sewing maching
I'm confused by your question, which mentions two machines. The presser foot pressure on a Tacsew T111-155 is adjusted by turning the knob on the left side, top of the machine that is directly over the needle. The Designer 1 mostly sets its own presser foot pressure, but it can be increased or decreased by following the procedure on p. 13 of the manual: http://new.husqvarnaviking.com/SiteMedia/Products/Machines/Support/Designer_I_manual_EN.pdf
May 22, 2014 | Tacsew T111155 Mechanical Sewing Machine
Birds nests embroidering husqvarna viking designer se
it would be a good idea to have the machine serviced
Try these suggestions for bird nesting
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case
& make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
6. Check to make sure the bobbin is not warped or damaged
7. Make sure the bobbin case is correctly in the machine,, if it's a top loading bobbin you may need to have the bobbin case checked to see if it's damaged or see if the hook and hook race has a problem
8. Also could be a timing problem, and the machine would need to be checked.
Feb 19, 2014 | Sewing Machines
Loud thumping noise CS-6000i
hmmm... Can you determine where the thumping is coming from?
In my experience thumping like this is because something has gotten out of time. You might be able to see it if you take the bobbin, and needle plates off. Take off the threads, top and bottom and you might have to take out the bobbin carrier too. Making sure to understand how it goes back in. Take off the presser foot and any presser foot holder. Locate the shuttle point. Hand rotate the machine in the direction it normally turns (NEVER backwards) and watch what the needle does. Does the needle hit the shuttle? Does the shuttle bounce up and down?
You also might try grasping the presser foot bar and the lever at the same time. Check for play of the bar by gently moving the presser foot bar up and down while "feeling" for unusual movement.
Even if you determine the issue... you'll need to take it in for repair. There are no publicly available service manuals for your machine (or my brother for that matter)
You also might want to check your bobbin for rough spots, use very fine sand paper to smooth them out if you find any.
Nov 06, 2012 | Sewing Machines
When free motion quilting the bobbin thread loops and snarls. The machine is not currently on a frame, but I have a Grace Sturdy Light and want to put the machine in (the quilt is rolled and ready), but I...
Try threading the machine with the presser foot up and see if the loops and snarls go away.........
When the foot is down during the threading, the tension control is closed and the thread cannot enter as it should.
No tension control of the top thread and the bobbin thread cannot connect for a proper stitch.
Mar 12, 2010 | Janome 1600P-DB Mechanical Sewing Machine
How do I install my darning foot?
First, raise the presser bar, remove the presser foot, the presser foot holder and screw.
Turn the handwheel to bring the needle to its highest position.
Place the darning foot on the presser bar and make sure that the metal bar of the darning foot is above the needle clamp and put the screw back on and tighten.
As the needle bar raises and lowers, the foot will hop up and down slightly.
Make sure that you always lower the presser bar when using this foot. Lower the feed dogs also if your machine has this feature.
Aug 20, 2009 | Kenmore 15343
Help setting Viking Designer I machine for free motion quilting
I assume you are doing free motion quilting? Use the V Menu, choose the first stitch. If you are using the Q Sensor foot or the spring free motion foot, go into the Set menu, hit "More" twice then turn On for either the Q Foot or Free motion. Make sure you have Needle Down turned on (top right-hand button on the left side above the needle). You might need to loosen the top tension by one or two clicks - first screen of the Set menu, under the picture that looks like DNA. A Size 90 needle is probably best and if the quilt is difficult to move about you might like to either use the Sewing Advisor to set for Heavy fabric or lessen the upper presser foot pressure - Set menu once again, next picture after the DNA. I have never had to do this with my D1 but I know some other people have. Get back if things are not working well for you.
Pam
Apr 29, 2009 | Bernina Activa 140
Free motion quilting Viking Designer 1
I had the same dissatisfaction when I switched from the 1+ to the Designer 1. After some trials I am now happy. You need the springy free motion foot. Part #413 03 76-45. You take off the white shank and screw it on with the metal bar over the needle hook. In the set menu turn the SensorQ on, the free motion on, select stitch 1 from menu V and drop the feed dogs. It also makes a big difference to use the straight stitch throat plate which just has a small hole for the needle to go through. One other hint is that I often have to reduce my needle tension 3 or 4 steps. Hope it works for you.
May 30, 2008 | Husqvarna Viking 1
Sewing Machines Logo
48 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Derek Massey
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
