Question about ViewSonic N3735W 37 in. LCD TV
When i try to adjust volume down on the television or try to power it off, the menu pops up
  • 1 more comment
  • mavericksmam Oct 13, 2010
    ok, weve removed the screws but is there some secret to popping off the front frame part?
    there just doesnt seem to be any like...clip releases, maybe? there are some small slits along the side of the frame where it meets the back cover, but it doesnt seem to be just giving way. afraid too much pressure will snap the frame. hold up....we may have a breakthrough!
    so we got the back off and blew out the button pad. they all sound like they are "clicking" the same as if they are not stuck. checking the power button too jic. if we do need to replace the button pad, any suggestions for a place to purchase? and would i need a specific model numer for that part or just the model number of the tv?
  • ViewSonic Master
  • 3,866 Answers
This is caused by ether a stuck button pad under the actual button on the panel or a faulty control board that has the button pads on them, what would need to be done is first investigate if there are any stuck buttons then replace the actual board if that is not the case,
let me know if you have any questions, otherwise please do leave positive feedback and ratings for your free answer today, Thanks
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Oct 12, 2010
Testimonial: "Quick response time! thanks!!"
  • 2 more comments
    what is the best way to access the button pad to see if it is a stuck button?
  • Grand Canyon Tech
    Grand Canyon Tech Oct 13, 2010
    best way is to open the unit up i cannot see any other way of doing that. it will need to be opened.
  • Grand Canyon Tech
    the fram should not be to hard to access i do not have a diagram of this TV handy but let me know if you have trouble maybe you can send over some photos
  • Grand Canyon Tech
    www.partstore.com should have the button pad, and you would need to look it up via model number.
    This has been a totally free endeavor helping you on my part, As a expert of fixya I enjoy helping people. But if you need more insight, Help. I would encourage a chat with you.
    See the bar gets raised at a certain point here and I feel getting to where you are now with your TV has more then raised that bar. The button pad is what controls the tv, Thus a stuck button can be cause or the whole board itself. further diagnostic would be needed going forward.
    Sergeant:
  • 330 Answers
The problems is the main digital module if no defective fileters on the power supply board.
Part Number:6201-7037151301, you may do a goole search to find the part. Usually it cost from $70.00 to $125.00.
Good Luck
Posted on Oct 13, 2012
How to unlock buttons?
Not sure if this is exactly the same as yours your model hard to find I had 2 similar monitors at previous employer and they both operated the same way Taking a Look 1. Power Switch Pressing this button turns the display system power on or off. 2. Menu/Select ? Pressing this button pops up the OSD menus on the screen, and used to select ("Up" direction) the OSD control options on the screen. ? This button is used to select ("Down" direction) the OSD control options on 3. Select the screen. 4. + This button is used to increase the value of the selected OSD control option. 5. 0 This button is used to decrease the value of the selected OSD control option. Quick Adjustment Function When the OSD Menu is not active, the following functions are available for the quick adjustment. Pressing ? button once pops up the OSD Function Main Menu . Pressing ? button once pops up the small Brightness icon. Use +or 0button to adjust the Brightness level. Pressing + button once pops up the small Volume icon. Use +or 0 button to adjust the Volume level.
If you need further help, reach me via phone at https://www.6ya.com/expert/richard_b70d968cd1a1d293
Apr 17, 2016 | Princeton Digital VL173 Monitor
Need to adjust convergence but no longer have the Remote Control
you can always buy a cheap universal remote and fix it that way.On most tvs you can access any menu features by hitting the channel up and down buttons or volume up and down buttons at the same time on most tvs its you have to hit the channel up and down buttons at the same exact time and the tv menu should pop up on screen.Hope this helps GOOD LUCK!!!!
Jan 02, 2011 | Hitachi 43FDX01B TV
RCA HDTV Monitor; menu popping up and volume going down
The small signal board needs replacement. You can get replacement small signal boards from www.tvrepairworld.com
Jun 28, 2010 | RCA HD52W56 52" Rear Projection HDTV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
MENU SCREEN POPS UP, TV CHANGES CHANNELS, TURNS SOUND DOWN
Yes. Its probably a stuck button on the TV's front panel. Try pushing or wiggling each button on the panel. It could be the channel up/down buttons or volume up/down, menu, etc.
When there is a button that is making slight contact, it keeps the microprocessor busy attending to the command its erroneously receiving from the offending button and may not allow other functions to work when this occurs.
It doesn't matter which button is stuck, any of the symptoms you describe can happen.
michtech
Feb 17, 2009 | RCA P52926 52" Rear Projection Television
How to service mode
With TV powered off press: [mute], [1], [8], [2], [power]
Television will power up in service mode and GAMMA GAIN1 will be displayed on the screen.
Use [mute] and the [menu] button to move values up and down.
Use the [volume +] and [volume -] keys to move to other adjustements.
Use [add] to save the settings.
If you're attempting to adjust color or geometry errors, you'll need the Video Essentials DVD, Laser Disc or some other source of test material.
Sep 10, 2008 | Samsung HC-P4752W 47" Rear Projection...
Samsum PLH403W service menu
Here is how you get to the service menu. Just be sure to write down anything you change in case you want to change it back.
1. TV turned off
2. Press 'Mute' then '182' then 'Power' buttons on the remote.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the category.
5. Use the 'Volume up or dwn' to enter the category.
note:Some models may not have Category Selection.
6. Use the 'Channel up or dwn' buttons to select item to be adjusted.
7. Write down the old value of the item before changing.
8. Use Volume up and down adjust the value.
9. When you have made all the adjustments you want turn the set off to exit.
Feb 01, 2008 | Samsung PLH403W 40" Rear Projection...
Service menu
1. TV turned off
Jan 23, 2008 | Televison & Video
ViewSonic N3735W 37 in. LCD TV Logo
174 people viewed this question
Top ViewSonic Televison & Video Experts
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
