Require a Lemair 2.2 kg washer repair manual. it is siphoning whe water out as it fills
  • 105 Answers
SOURCE: FP ecosmart GWL15 fills but water not siphoning out
This is very simple machine to work on. Just tilt it back or lay it on its back. You will see the pump on the right side. It just has a thumb tab that you depress and then turn the pump until it comes out. There is probaly a clog of lint in the pump impeller. Clean it and the sump where the pump was attached. If this doesn't solve it you would need a Technician.
Posted on Apr 09, 2009
  • 1937 Answers
SOURCE: Kenmore Mod 110 24632300 won't drain
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110+24632300
and you'll see a list of major sub-components with diagrams and parts.
I'm assuming that it will spin.
See the section for the Pump, Motor and gearcase and the basket and tub assembly's
I'd pull the cabinet in order to get to the hoses going to and from the pump first.
See the following:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131
If the hoses are fine, check the shaft from the motor to the pump and check inside the pump to make sure the inlet and outlet aren't blocked.
As an aside, see the following Whirlpool Service Manual for top load direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Posted on Feb 13, 2010
  • 713 Answers
SOURCE: Hi. My smartdrive 6.5 kg top load washer pushes
on your machine when you select cold, the hot water valve will open automatically letting cold water thru it.can you connect the hot hose up to a tap to stop the water leaking out? or you can buy a screw on plug from a hardware shop that will cap off the valve at the machine or the hose. sometimes to save a customer money i connect their hot hose to the hot valve then fold the hot hose in half and tape it in that position . this stops the water. hope this helps. please reply for further help if you need it
Posted on May 27, 2010
ginko
  • 19396 Answers
SOURCE: my nec nw452 4.5 kg
Hi.
LE is lid error. Disconnect the appliance or trip the circuit breaker to reset.
If error is still there check the door lock and ensure that the lid is well closed and that latch is snapping.
If problem persists, then the lid switch is defective and must be replaced. In that case I suggest calling the service support number listed in the manual.
Posted on Sep 08, 2010
  • 385 Answers
SOURCE: my used Kenmore washer fills
It sounds as if it is siphoning out the drain pipe.You have to get the drain pipe up to the top of the washer and also be sure that the pipe is a little bigger than the drain hose or it will siphon. Hope this helps.
Posted on May 13, 2011
Whirlpool duet 8E error code, what is the cause?
F8E0Steam valve failureCheck the water supply hoses for kinks. Check for a restricted screen in the water valves. Replace the steam valve if defective.
Steam valve
F8E1No water detectedMake sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it.
See the repair guide to fix it yourselfWater valve assembly
F8E2Dispenser failureThe dispenser can't move into position. Unplug the washer and check the mechanical linkage on the dispenser housing. Repair or replace any damaged dispenser parts.
Dispenser assembly parts
F8E3Overflow conditionUnplug the washer and, if the washer is overfilled, check the water valve assembly for proper shut-off of water flow. If the water valve assembly is defective, replace it. If the washer is empty when this error code appears, replace the water level pressure switch.
See the repair guide to fix it yourselfWater valve assembly, water level pressure switch
F8E4Low water flowThe flow meter detects a long fill time. Make sure that both water supply valves behind the washer are fully open. In winter, check the fill lines for freezing. Check the drain system for a siphon problem. If the water valve assembly is defective, replace it. If water flows normally, replace the flow meter.
See the repair guide to fix it yourselfWater valve assembly, flow meter
F9E1Long drainRemove excess suds; the washer can't drain excessively sudsy water. Check your house drain system for a clog. Check the drain hose for kinks or clogs. Replace the drain pump if defective. If the washer drains properly, replace the water level pressure switch because it isn't accurately detecting the water level.
See the repair guide to fix it yourselfDrain pump, water level pressure switch
Oct 16, 2016 | Whirlpool Washing Machines
I have LG fyzzy logic 6.5 kg WFS65AO1DCT and it keeps loading and draining water even when in spin
see this causes and fix it. God bless you
This happens on new installations usually. The drain hose must be higher than the highest fill height of the washer. If the drain hose is to low it will create a siphon effect and drain the machine. Next is the drain hose is to tight in the standpipe. The standpipe is your homes plumbing. If the drain hose does not have an air gap aroung it, it can cause a siphon effect and start draining your machine as it fills. If none of these are the problem and your drain pump is running at the same time it is filling you will need to replace the control. For top load machines follow this video and for front load machines follow the tutorial.
Sep 30, 2012 | Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
E 10 code what do u do
I'm assuming your washer is a Kenmore or Frigidaire front loading washer. E10 error code is an indication of a slow fill, took to long to fill, no fill or the fill water could be siphoning out the drain hose as it's filling with water.
Check to make sure that the drain hose is not stuck too far down the stand pipe and causing the water to siphon out. Check the cold and hot water supply to the washer for any restrictions. If you have a slow fill remove the hoses from the washer and check for restricted filter screens in the water inlet valve. Check for any restricted hose screens too.
Jan 10, 2011 | Frigidaire ATF6000ES Front Load Washer
Does not fill to wash
If draining is occurring at the same time as it is filling you have siphoning happening. There could be 2 reasons for this.
#1 the drain hose must be higher than the washer tub before it connects to the drain pipe in the house.
#2 the drain hose from the machine must not stick into the house drain more than 6" - if it is pushed down the drain too far it will siphon out the water in the machine.
Apr 21, 2010 | Whirlpool LSQ8000 Top Load Washer
LG WF-8071TTP drum fills 3/4 and then drains unexpectedly
Either a main control board or you have a drain line problem causing the water to siphon out. If you house drain is lower than the washer water fill line or if your drain hose is sealed into the house drain line then you can have the water siphoned out of your washer. Check to make sure the drain line is not to far into your house drain pipe and that there is air around the drain hose where it enters the drain pipe, (not sealed tightley). If it is not the drain siphoning then you need a technician to diagnose the main control board and to replace it. Good Luck Appliance Specialists
Dec 14, 2009 | Washing Machines
Whirlpool washer fills, begins to agitate, then drains
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
moz-screenshot.jpgThe washer fills and drains at the same time only on the rinse cycle.
Shut the machine off with timer during this period and raise the drain hose. If the water continues to drain, you will need to install an anti-siphon kit.
Please leave a solved rating before you sign out
Jan 31, 2009 | Whirlpool LBR4121JQ Top Load Washer
Washer filling over and over
Check the placement of your drain hose. This may be a simple issue of siphoning. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Make sure you have a sufficient air gap at the top of the drain stand pipe, and that the drain hose is not placed in the standpipe too deep. This can cause the water to constantly siphon out of the wash tub and the washer will continue to fill to try to maintain the water level.
Please let me know if you have questions, or if you require additional assistance. I hope this helps you.
Jan 19, 2009 | Frigidaire GLWS1649A Top Load Washer
Washer keeps draining
Sounds like you may have a siphoning problem. The following link explains:
Double check your installation and drain hose placement. You need to ensure you have an air gap to break the suction caused by the drain line. In the event that this is not a simple siphoning issue, please let me know if you require additional assistance. I hope this helps you.
Oct 29, 2008 | Frigidaire FWS833A Top Load Washer
Washer fills then drains
Daisy, check your drain hose going into the drain. It sounds like you have a siphoning problem. If the drain hose does not have a air gap the water filling will siphon right out. Check this first and post back, Catriver.
Sep 21, 2006 | Kenmore 98702 Stacked Washer/Dryer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
