Question about Canon CanoScan LiDE 70 Flatbed Scanner
How to open case on my scanner for repair....
  • 98 Answers
It has plastic locks. Take it for a repair center.
Posted on Oct 12, 2010
How will i fix scanner error in
Scanner is a major component in Laser printers. It is actually the integral part of the engine. It cannot be repaired easily. Needs speciality equipment, skills and mostly is more costly to repair in most cases than new printers
Jul 18, 2016 | Office Equipment & Supplies
Bulb out
Are you saying that if you try to make a copy or scan, when opening the scanner bed cover, the bulb is not lit? If this is the case, then the scanner light "bulb" has gone defective now. Lexmark does not have a replacement for that part, you can try to have it repaired from 3rd party shops, otherwise, it's time to replace your printer.
Please try to contact Lexmark technical support center for other options.
Dec 17, 2011 | Lexmark P4350 All-In-One InkJet Printer
The paper partially feeds in the upper tray and then you hear a grinding noise and it says scanner failure
clean the rollers
Used a clean paper
Open the area the paper feeds in on the scanner
lift the roller
without paper try to make a copy
press the flag-like hardware part on the ground portion of the scanner feeder
then forcefully put the whiteroller to the ground as if its trying to make a copy without the paper
to test if its working fine while you are pressing down the flag structure on the ground area also do it 2x
- wipe the rollers
- specially the one that feeds up the paper
try to scan again
- in case no go
= remove all removable parts
paper, cartridges ,black box and power supply
lift the printer turn it upside down makse sure the cover is open
so taht any foreign material will fall
shake it for 5x
return all the parts
- in case no go
have a printer repair on your area
usually its only on the rollers
- Hope it help
May 28, 2011 | Computers & Internet
I am getting this error on my mc9090 scanner: " Error A000000B enabling scanner. Scanner support has been disabled"
In most cases you find that the flex that connects the cpu and the scan engine is faulty or out of alignment. Try to cold boot the device or if it's out of warranty you can open it and realign the flex. Other than that you have to send it for repairs.
May 17, 2010 | Zebra Symbol Technologies MC909X-G Series...
Amtenna conector problems
Your problem is more than likely due to a bad/broken connection on the inside of the antenna connector. If you're brave, and handy with a soldering iron, you can open the case and check/resolder the two joints at the connector. Otherwise, take it to a local electronics shop. It's a simple repair, but only for those who know their way around inside a scanner.
Bill B
Mar 08, 2010 | Icom IC-R10 Handheld Scanner
Opening an older HP Scanjet 3300C case ??
I recently picked up a SJ 3300Cse and have the same issue.
On mine, on the top of the scanner near the hinges there are two small white rubber peices that are very well camoflaged. If you remove them you'll see the two screws to open the hinge side of the case.
Good Luck.
Jul 18, 2009 | HP Office Equipment & Supplies
Slide holder is stuck in Dimage scanner
I solved the issue by opening the casing of the scanner after having unplugged it front the computer and it's power supply.
There are 3 rounded head screws that I unscrewed to do this.
1) The single screw at the back of the unit.
2) The two screws that are closest to the rear of the unit underneath the unit.
The tricky part is that the casing that makes up the sides, top and the back of the unit has to then be pulled back and a bit up to be released and the plastic hings of the casing will catch parts of the internal frame. Therefore great care and patience must be taken when pulling the case back and off of the rest of the frame of the unit.
With the casing removed, I slowly pushed the film holder towards the back of the unit until the front door of the casing could be fully opened manually, and then using one hand I kept the door open while slowly pushing the film holder towards the front of the unit with the other hand.
After that I put the casing back on, and the unit is running normally again, although I suspect that this jamming is a sign of wear and tear on this unit as it has been used a lot.
IMPORTANT:
There is a mirror within the unit and I would advise as a precaution that no contact should be made with that mirror unless you are willing to risk the unit not being able to focus properly or showing smudges or scratch marks on the produces scans!
Jul 30, 2008 | Konica Minolta Dimage Scan Elite 5400 II...
Opening Canoscan case
screws on bottom ease the case off fix ribbon there under the rubber stops then once open your going to want to seal galss back down i recommend jb weld on edges to hold glass in if u dont secure glass when open a month down the road the glass will pop down i had my scanner 16 years since jb welding the glass down you only spot jb weld the glass though
May 05, 2008 | Canon CanoScan LiDE 25 Flatbed Scanner
"The Scanner has reported a hardware error..."
Version:1.0 StartHTML:0000000105 EndHTML:0000008195 StartFragment:0000002796 EndFragment:0000008159 Normal 0 0 1 464 2648 22 5 3251 11.0 0 21 0 0 I brought a coolscan 9000 the last month without the film holders, software etc just the scanner. A friend of mine sold me it for a good price. I run Leopard in a Powerbook G4 15” 1.2 ghz 2 Gigas ram. I installed the Nikon scan 4 and when I open it the scanner report an error: The Scanner has reported a hardware error... every time that I run the program this message appears. I thought that this was because I hadn’t got the film holders. When the film holders arrive from USA the same problem appears : The Scanner has reported a hardware error... Them I tried Silverfast Software. In this case the scanner report another error: there are not film holder ( or something like that). I uninstalled Nikon Software with the same utility to install it. Reinstall the Software and the same ****** problem. When I switch on the scanner a loud noise came from inside, after this the blinking light stopped and nothing happen ( no calibration, no light inside, nothing). Just one thing. The Scanner has reported a hardware error...
I checked on internet and the solution of switch it of and on doesn’t work. CALL TO THE NIKON SERVICE that’s was my only solution.
Of course I didn’t . The price of the scanner was 300 Pounds.
SO I OPENED IT.
I REMOVED THE SCREWS FROM THE BACKSIDE AND FROM THE BOTTOM OF THE SCANNER. I TOOK THE METALLIC CASE OF: PICTURE 1. After a while looking everything without touch I’m start to check for the connection cables one by one, WHEN DISCOVER THAT ONE CABLE PLUG THAT GOES FROM THE SCANNER TO THE FIREWARE BOARD WAS DESCONECTED…. PICTURE 2 Maybe on the shipping this plug looses his place. SO I SWITCH ON THE SCANNER AND THE PROBLEM DOESN’T APPEAR. Now the problem was that the film holder wasn’t recognising from the scanner. So I followed the steps that most frequently indicate on the web:
1-Close the scan program –
2-Turn off and unplug the scanner
3-Plug the LS9000 back in and turn it on
4-Reopen the scan program
The scanner worked. When I switch on the scanner take a minute or so to calibrate and determinate the film holder. Them I open the Nikon Scan 4 and every looked nice. I could scan my first negative ALELUYAAAAA. So I close everything without the screws so I put the scanner vertical to put back the metal case ones I finished I turned on the scanner and the Nikon program. For my surprise the same ******* error I couldn’t believe it.
I opened it again and I found the cause of the problem . BECAUSE THE SCANNER WAS ON VERTICAL BEFORE, THE METALLIC GUIDE THAT CONNECT WITH THE SERVO WAS MOVED (Move the scanner from one place to another may cause this issue) So with my finger I putted it in the same place. THE SCANNER WORK’S.
After this the only problem was a big loud gnashing and grinding noise that I sorted with CELOTAPE BETWEEN THE TWO PIECES THAT WAS SEPARATED BEFORE.
PICTURE 3
Now the scanner work fine. Sorry for my **** English and I hope that someone can find useful this information.
Feb 27, 2008 | Nikon CoolScan V ED Film Scanner
Can't figure out how to open the case
There may be lock system rather than a screw. Please see the lock and it will be opened by pressing a lock node(s) or aplying the force in a paticular direction. Do not try to open force fully. Refer manual of scanner if there are instruction to open the case.
Aug 23, 2007 | HP ScanJet 3300Cse Flatbed Scanner
Canon CanoScan  LiDE 70 Flatbed Scanner Logo
713 people viewed this question
old marine
old marine
