My Dell Inspirion Mini 10 is beeping 8 times when I turn it on. Nothing on the screen.
  • meganforet Oct 12, 2010
    How on earth do I do that? I hope my memory isn't broke too!
  • Richard Alleyne Nov 14, 2012
    Have same problem, System will boot if I connect external monitor. Will continue working fine when monitor disconnected but resorts to 8 beeps no boot if I shut down and reboot. Changed memory and mother board, same problem.
Try holding Fn + End with battery and power cord out and while still pressing Fn + End plug only power cable back in and try to power on.
Posted on Sep 01, 2011
    Scholar:
  • 135 Answers
Dell Diagnostic Beep Code Troubleshooting Chart
Those beeps your computer emits at startup, yea, they mean something. If you're having difficulty figuring out why your Dell desktop, tower, or mini tower won't boot, take a look at this chart. Dell also has a diagnostics utility and can provide excellent technical support, sometimes. The numbers and hyphens mean exactly what's listed. For example, the sequence 1-1-2 means beep, beep, beep-beep. Some issues are caused by owner carelessness, others require hardware replacement. If you're unsure, either Google further, or contact Dell Technical Support.
Dell Beep Code Meanings 1-1-2 Processor Register Failure 1-1-3 NVRam 1-1-4 ROM Bios checksum failure 1-2-1 Programmable Interval Timer 1-2-2 DMA Initialization Failure 1-2-3 Direct Memory Access Page Register Read/Write Failure 1-3-1 - 2-4-4 Memory/RAM Not Properly Identified or Used 3-1-1 Slave DMA Registration Failure 3-1-2 Master DMA Registration Failure 3-1-3 Master Interrupt Mask Registration Failure 3-1-4 Slave Interrupt Mask Registration Failure 3-2-2 Interrupted Vector Loading Failure 3-2-4 Keyboard Controller (Input) Test Failure 3-3-1 NVRam Insufficient Power 3-3-2 Improperly configured NVRam 3-3-4 Video Memory(RAM) Test Failure 3-4-1 Screen Output Initialization Failure 3-4-2 Screen Retrace Failure 3-4-3 Failure Finding Video Read Only Memory 4-2-1 Lack of Time Tick 4-2-2 Shutdown Failure 4-2-3 Failure in Gate A20 4-2-4 Unexpected Interruption in Protect Mode 4-3-1 Memory Address Failure above 0FFFFH 4-3-4 Non Functioning Time Of Day Clock 4-4-1 Serial And/Or Parallel Port Test Failure 4-4-4 Cache Test Failure
Posted on Oct 12, 2010
  • tj138 Sep 01, 2011
    Had problem with mini 10 beeping 8 times. Tried another posters solution from a different forum by removing battery power cord and hold down Fn and End keys while plugging in only power cord which changed beep pattern from 8 short beeps to 1 long beep and 2 short. still did not fix problem so then i kept holding Fn + End with battery in while pressing power button and windows resumed with error message telling me that battery had reached critical level and was in some recovery mode. hope this helps
  • 386 Answers
U have a malfunction device that why it's beeping, Check your RAM (memory) take it out and re insert it.. hope your memory is not broke..
How to unlock a Dell Inspirion Mini Keyboard
I don't know if you have a mini or a mini 10 but here are the instructions on how to do both.
Aug 05, 2014 | Dell Inspirion Mini 884116022442 Notebook
Reset administration password for a dell inspirion 500m
turn on the computer --> press f8 on start up after flashing of the bios screen
it shows advanced start up options from the menu select safe mode
then it shows classic logon screen type username as administrator leave password as empty and press enter
now you can reset the password using user account control panel or using computer management from control panel
May 09, 2012 | Dell (INSPIRION MINI 10) Netbook
When i turn my laptop on, it beeps for a while then boots up
You may have a ram memory stick that is showing early signs of failure. This should be checked quickly before the laptop shuts down.
May 08, 2012 | Dell Inspirion Mini 10 Netbook
Can't turn on my mini netbook inspirion - help
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.Maybe your DC Power Jack which is where the power cord plugsinto the computer is bad. Take an ink pen and push the tip inside thejack and see if the little pin wiggles, if so the jack is bad. You'll have totake the laptop apart to fix it. Most times it is soldered onto themotherboard, so you will have to desolder the old and solder a new one.
Mar 31, 2012 | Dell (INSPIRION MINI 10) Netbook
How to change screen resolution on dell inspirion 1010 to 1024 x 600
To change your screen resolution1.Open Display in Control Panel.2.On the Settings tab, under Screen resolution, drag the slider, and then click Apply.3.When prompted to apply the settings, click OK. Your screen will turn black for a moment.4.Once your screen resolution changes, you have 15 seconds to confirm the change. Click Yes to confirm the change; click No or do nothing to revert to your previous setting.
Jan 29, 2012 | Dell Inspiron Mini 10 10v 1010 1011 PP19S...
Dell inspiron mini -- at first it works fast but suddenly the screen goes black and I don't know why. I tried pushing the power button but it didn't work, the power button still lights up (so meaning, it...
Hi, Please try removing the battery and then starting it. Those beeps are error codes that help tech support people identify the problem, The easiest solution is to take the laptop to service center. Good Luck
Apr 01, 2011 | Dell Inspiron Mini 10 Notebook
Dell 10" mini netbook is unable to display the entire contents of a web page. The bottom part is cut off. I tried changing the resolution to 1024X768 but it keeps popping back to the default.
Simply change the screen resolution.
Steps
Right Click on your Desktop
Click Properties
Then go to the Display settings
Select a lower resolution
Your problem will be solved
Cheers
Sep 01, 2010 | Dell Inspirion Mini 10 Netbook
My inspirion mini went into hibernate mode, and now won't restart. tried power button, light flashes 3 times but won't come on. tried pulling battery, no luck. Help?
Try this: Disconnect AC power, pull the battery, then press and hold the power button for 10 seconds. Release the button, replace the battery & AC, and try booting.
Mar 09, 2010 | Dell Inspirion Mini 10 Netbook
Have a dell mini inspirion 10, not sure how to
I can make most of them out Fn+F1 Toggles the External VGA port Fn+F2 Toggles Wireless on and off Fn+F3 Battery Meter Fn+F4 Brightness Decrease Fn+F5 Brightness Increase Fn+F7 Mute Fn+F8 Volume Decrease Fn+F9 Volume Increase Fn+F10 Print Screen
Jan 22, 2010 | Dell Inspiron Mini 10 Notebook
Computers & Internet Logo
1,724 people viewed this question
David Payne
David Payne
