Back to:
Tags:
Jenn-Air JED8430 Electric Cooktop
Remove Meat Probe
posted by tkitts on Jun 01, 2008
I am cooking on the stove top and the oven is off. The oven starts beeping and reads: remove meat probe across the screen. I do not have the meat probe in or the oven on. I press the meat probe and it turns off. 30 secounds later it is beeping again. I try this several times with the same result. I tried inserting the meat probe than turning it off. The same result. So, without putting the meat probe in, I set the meat probe to 100 bake and go have dinner. When I return the oven is off and there is no beeping.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Can you Help with these Kitchen Cooktops problems?
We have a Jenn-Air electric cooktop Model 8430BDB. My son...
I have a Jenn Air CP220 cook top control unit with a CM200...
When I turn the dual element on High, either the large or...
Only the right front (large) burner operates. The lights...
I just found in a two-inch hairline crack curving along...
Loading problems.
Repair Service
Find Kitchen Cooktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
