Question about Yamaha P-7000 2-Channel Amplifier
My yamaha P7000 always lights its protection lamp whenever turn on...
    Genius:
  • 1,175 Answers
The amp will require service. One or more power transistors have failed and the protect circuit keeps the power supply from blowing your speakers
Posted on Oct 12, 2010
I need diagram yamaha p7000 change power supply using a transformer
I'm sorry. I have no idea what you're asking, but if you need a service manual, you'll have to go to the Yamaha website.
Dec 18, 2014 | Yamaha P7000S 2Channel Amplifier
Where is the fuse box located on a 1996 savage ls650
Hi Chris,
The fuse box is under the left side seat.
Regarding the brake light, check your brake switch located somewhere at the brake pedal arm. My guess is, it was stucked to ON position that is brake lamp is always lit.
I hope that helps.
Regards,
JKeep Brainy
Oct 19, 2012 | Suzuki Motorcycles
Short circuit in Stratoliner passing lamps
Hi, Doug you have a dead short which is usually the easiest to find. Using a test light connected to the hot side of the blown fuse holder, start probing the wire leaving the fuse holder about an inch away from the test light should illuminate, keep probing towards the ignition switch until the test light no longer illuminates you are now very close to the short. For more information about your issue and valuable free downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Need help passing lamp probs
passing lights
Yamaha XV19SX Service Manual
OEM parts for Yamaha
Yamaha STAR XV19CSX Owner Manual
Jul 30, 2012 | 2009 Yamaha Stratoliner
I'm the original owner of this projector with not many hours on the lamp. About 1 year ago it became difficult to turn the projector on. Eventually I would get it turned on by multiple attempts and...
Hi Ron.
Re:"a clicking sound that continues for 20-30 seconds than stops as the projector "gives up" trying to turn on"
The clicking sound and the projector not responding is not indication of a particulare issue or fault, but just the generic protect mode that kicks in whenever a fault is detected.
The condition is called protect mode or protection.
The clickin noise is a safety switch that keeps turning off the unit until the projector shuts down completely.
When the problem is the lamp the unit does not go into protect mode, but usually there is a well defined diagnostic condition (eg. a lamp light on). I do not think that the problem is the lamp.
Most common failure is the PSU (power supply), with in second place convergence issue. Other faults, like the lamp power board or main digital board failure are still possible.
As first trubleshooting, try leaving the projector off and disconnected for one hour, that will probably not help, but is a necessary step to ensure that there is a fault.
If that doesn't work, then the choice is between calling manufacturer and taking the projector to a local technician.
Jul 26, 2010 | Televison & Video
Trying to change a rear light bulb and dont know how to open it up
Rear Turn Signal, Brake & Parking Lights The taillamps, stoplamps and rear turn signals lamps are all incorporated into the rear taillamps. The taillamps are lit whenever the parking lamps or headlamps are in operation. The rear turn signal lamps flash with the front turn signal lamps whenever a turn is indicated with the turn signal/headlamp dimmer switch. The stoplamps light whenever the brake pedal is depressed and the stoplamp switch is closed.
The trim panel is likely held in place with retainers like this. Back out the screw to release tension on the pin legs and remove the fastener
The taillamp is retained by plastic wingnuts
Remove the plastic wing nuts from the taillamp housing
Remove the taillamp housing from the vehicle to service the light bulbs
  1. Open the rear compartment (trunk).
  2. If equipped, unhook the convenience net that stretches between the taillamps. It is attached to hooks molded into the plastic taillamp assembly retaining wingnuts. Loosen the rear compartment trim panel. It is retained by plastic pins with a screw in the center. Back out the screw to release any tension on the plastic pin legs, and pull the trim (thin carpet-like material) for access to the taillamps.
  3. Remove the plastic taillamp assembly retaining wingnuts.
  4. Remove the taillamp assembly from the vehicle and service the light bulbs as required.
  5. Installation is the reverse of the removal process.
  6. Test the lights for correct operation.
Apr 29, 2010 | 1999 Pontiac Grand Prix
How do you switch from 8 ohms to 4 ohms on a 3500 yamaha amp
Switch what? It accepts 4 ohm speakers for stereo mode just fine.
Jan 25, 2010 | Yamaha P-3500 Amplifier
Tv turns off (both video and sound) after running for 20 sec and then turns on after 20 sec. This pattern continues over and over. None of the lights are blinking. Lamp is less than 2 yrs old and is...
TV will show Lamp Light warning if lamp got broken or dead.
Symptoms of TV shows lamp is weak and will be replaced. Weak lamp consume more current than allowed ratings and causing activation of protection circuit that shuts off TV and TV turns on again itself, that is why no blinking red light.
Please replace lamp in your Sony KDF-E55A20 TV, lamp replacement procedure is easy and written in user manual, click Sony Support to download user manual copy, if required.
Always buy Sony original lamp for TV safety, Sony original lamp is available in Sony Accessories Store for $200 with following part number..
A1085447A... LAMP BLOCK ASSY XL-2200U
Hope this info will help you.
Thanks.
Dec 31, 2009 | Sony Televison & Video
52' DLP Mitsubishi HD T.V. gets an error message on the bottom of the screen ''T.V. will shut down. Check that air flow is not blocked'' T.V. is in the open and air flow is not blocked. There is also a...
most rear projectors will turn themselves off whenever the lamp is dead. what we call protective mode. in this case the yellow light may be for the lamp. otherwise check if all the fan are working properly.
But MAKE SURE you let sufficient time for the tv to cool off before unplugging the main.
hope this helps
please rate me!
Mar 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Yamaha LPX 500 home cinema projector isn't lighting up
The reason for a red light is replacement of lamp or it is running too hot. Have you checked for proper venting, and cleaned them recently. The bulb usually lasts 2000 hours, so you may need another.
Jan 27, 2008 | Yamaha LPX500 Multimedia Projector
Yamaha P-7000 2-Channel Amplifier Logo
417 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
