Question about Kirby G5 Bagged Upright Vacuum
No power I ran over an elastic hair band with the hose that wrapped around the shaft (not the brush). Since then, no power. could the motor have burned up?
    President:
  • 1,673 Answers
If pieces wrapped around the fan fins and jammed the fan from turning, this could be the problem. You may have to remove the front of the vac to get to the fan.
Posted on Jun 01, 2008
How do I replace the belt for this model
Make sure vacuum is not plugged in to power outlet. Lay it upside down and remove 4 screws from bottom plate covering brush roll. Remove bottom plate and pull the brush roll out. Clean hair and debris from brush roll and make sure it spins freely. Remove end caps from brush roll if possible and clean debris out. Install new belt around motor shaft then insert brush roll into belt and pull on brush roll to give you enough leverage to stretch belt far enough to put. Brush roll back into position. Reinstall bottom plate and screws. Make sure brush roll will turn before turning vacuum back on. Belt will lose elasticity and should be replaced twice a year.
Jan 17, 2015 | Hoover U5434-900 WindTunnel Plus Bagged...
Burning smell
For an upright or canister with a power head
a burning smell is usually an indication that the belt is slipping. It may just be worn out or the brush and or bearings may be bound up with hair. Remove the brush cover, some are on top other on the bottom, and look for anything wrapped around the brush. Also look at the belt where it goes around the drive spindle, if you see small black specks the belt needs to be replaced. Check the brush fro free movement, if it dosen't spin easly the bearings may need cleaning.
Dec 28, 2014 | Vacuums
Brushes will not rotate
I can't tell for sure from the pictures, but there are two possibilities - the drive belt to the brushes broke, or the brush can't turn due to excessive hair wrapped around the shaft. If the belt is OK but the brush does not turn, you should smell burning rubber.
If the belt is broken, you have to remove the bottom plate to expose the brush, remove the brush and the broken belt, and replace the belt, and put it back to gether. While you have the brush out, now would be a good time to clean it - remove the hair, etc from the brush and around the shaft. Good Luck!
Dec 19, 2012 | Hoover F7210-900 SteamVac V2 Upright...
My Dyson DC 14 is making the horrible "ratcheting"sound only when the brush is engaged on the carpet setting. I have cleaned the brush, so there are no obstructions, the canister is empty and...
Something is causing the brush to slow down, either it is full of hair or debris or the brush itself is wearing out and may need changed. The noise you are hearing is the motor protector keeping it from burning up becuse there is some type of drag on the brush. If there is no issues with the brush then I would suspect the clutch assembly is worn and needs replaced. Here is a diagram for you to look at and go from there.
http://www.espares.co.uk/diagram/dyson/dc14-vroom/p/1086/716/0/474352
Nov 09, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson absolute 17 animal smells like its burning when turned on also has terrible noise...nothing wrong with belt already checked it..so what's going on
I had the same problem with my DC15. With the brushes going it smelled like burning hair (bad). I had cleaned the brushes many times and it didn't seem to help. I even took it into a Dyson authorized repair shop and they couldn't find anything wrong with it. As a last resort I called Dyson 866-693-9766 1-866-My-Dyson. I was on hold for about 15 minutes before getting a live person. He had my problem diagnosed in literally 1 minute. I had hair wrapped around the spindle, inside the brush/roller mechanism. He walked me through taking apart the brush mechanism (super simple only using a quarter). There was a TON of hair crammed around the spindles and inside the brushes. All wrapped very tightly. I hung up with him to do the cleaning. It took some time and I had to use tweezers to get inside the rollers/brushes. But I got it all, put it back together (which was really easy) and tested it out. No burning hair smell at all. FIXED!
Nov 21, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Eureka boss power plus
I had this same problem. The brush roll wouldn't spin, smoke came out, and it smelled like burning rubber. I changed the belt thinking that would fix the problem but it didn't, so I took the belt back off and checked the motor shaft in the back and found a whole bunch of hair wrapped around the shaft. Once I cut out the hair with some scissors and replaced the belt, everything worked like normal. I hope this helps.
Sep 01, 2009 | Eureka Boss SuperLite Bagless Upright...
Burning rubber smell when turned on. checked the belt-is ok.
Take the bottom off as if to change the belt and remove the brush assembly from the VAC. Take the ends off the roller and clean out the string and hair and whatever is wrapped around the end bushings and reinstall. Should free-up the roller Brush and stop the resistance on the belt to motor shaft. Or your belt is streched out and should be replaced, they don't always have to Break to be bad.
Aug 18, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Roller not spinning on hard floors
after 2 weeks it should be still under warranty. but my guess is you have hair etc wrapped around the brush tip vac so you can see brush(es) remove all string,hair etc... from around the brush area (may have to remove bottom to get all the hair etc... stuck around it. it also may have been jammed up pretty tight and continued use could snap the belt or burn out motor
Aug 14, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Roomba brushes won't spin
I had this problem with my Roomba Discovery. I ran across your question while searching for an answer. My main symptoms were, Roomba hesitated a lot, and the dust bin did not fill. I had plenty of hair wrapped around the brushes and against the filter.
I just finished taking my Roomba apart. I found the motor drive shaft had a LOT of hair wrapped around it and it had climkbed into my gearbox. I took that apart and cleaned all the hair out of the gearbox. My Roomba is back to normal now, filling the dust bin.
Jun 28, 2008 | iRobot Roomba Red 4100 Bagless Robotic...
No power
There is a safety switch in the motor area that, if not engaged correctly, can result in your vacuum not running. The most common thing that's wrong is that at the bottom part of the motor, where the cord plugs in, the cord is in between the motor and the plastic holder for the bag and it's not letting the bag click on all the way and so it's not pushing in the safety switch enough for it to turn on. Also, you may want to remove the head and reattch it and make sure it's lined up properly. If none of this works, then you could have a cord problem or your safety switch might be out. These are very fixable problems. Find your nearest vacuum repair shop. A cord should cost no more than 30 dollars and a switch with labor will cost around 80 dollars. If you can't find anyone, contact us at 1-866-509-1952 and we can help.
Apr 19, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
