Question about RCA DIRECTV Satellite Remote Control
Code for dvd philips dvp3980 hdmi (rca uni versal remote control)
trintek
  • 111 Answers
SOURCE: rca remote control code list
unfortunately i do not have a code for that specific model, you can however try the automatic code search method.
1) turn on the dvd player
2) press and hold the code search button, when the indicator light is lit, release the code search button
3) press and release the component button you wish to use (dvd), the indicator light should blink once and remain lit
4) aim the remote at the dvd player and push the on/off/power button, there is a 3 second pause between codes, so keep the remote aimed at the dvd player
5) as soon as the dvd player turns off via remote, press and release the enter button
now to record the code for future reference..
1) press and hold the code search button, when the indicator light is lit, release the code search button
2) press and release the component button you wish to use (dvd), the indicator light should blink once and remain lit
3) press and release the code search button, the indicator light should turn off
4) starting with 0, press and release each button in numerical order (0-9) until the light blinks, write down the number that caused the light to blink
repeat step 4 two more times until you have the 3 digit code. in the future you can use the direct programming mode to reprogram the remote if need be.
hope this helps,
trin
Posted on Nov 16, 2007
  • 54 Answers
SOURCE: im using the rca rcr312w
  1. These instructions come from the RCA website. The crucial step is to keep pressing the reverse button.
  2. Turn on the component (the tv, dvd, etc).
  3. Hold the TV (or DVD) button and the on/off button at the same time. It will stay lit.
  4. Press the play button every five seconds until the component turns off.
    • Each time the Play button is pressed, the illuminated ON-OFF button blinks ten times and a block of 10 codes is sent to your component. This process continues until all the codes in the Code Lists have been searched. If the component has not turned off after all codes have been searched, the illuminated ON-OFF button blinks four times, turns off, and the Auto Code Search Entry method is exited.
  5. When the component turns off, press and release the REVERSE button, then wait two seconds to see if the component turns on again.
  6. If the component does not respond, continue to press the REVERSE button EVERY TWO SECONDS UNTIL THE COMPONENT TURNS ON again. This will isolate the correct code in the last block of codes sent. Each time the REVERSE button is pressed, the illuminated ON-OFF button blinks.
    • If the REVERSE button is accidentally pressed after the component responds, press and release the FORWARD button. Wait two seconds to see if the component turns off again.
  7. To save the new code, press and release the STOP button.
  8. The illuminated ON-OFF button turns off. You must press the STOP button to save the code.
Posted on Aug 17, 2008
SOURCE: Codes to program an RCA remote control
my remote will only work the volume. i need to program the remote to use menu to adjust the picture.
Posted on Oct 08, 2008
OK GANG: HERE GOES, I PURCHASED A RCA REMOTE (RCR312W), 3 CHOICE FUNCTION.
SAT-CBL...TV...VCR-DVD.
I HAVE 2 DIFFERENT TV'S, DAEWOO TV AND A PANASONIC TV/VCR. THE REMOTE HAS
WORKED ON BOTH SETS. I DROPPED THE REMOTE WHEN IT HIT THE FLOOR THE BACK
FLAP HOLDING THE BATTERYS KICKED OFF AND ONE BATTERY FELL OUT. I WENT NUTS
FOR 2 DAYS TRYING TO GET THE CODE FOR THE DAEWOO. TODAY 11/14/2008 A FRIEND
GAVE ME A PANASONIC TV/VCR 20". AGAIN I TRIED TO FIND THE CODE, DIDN'T WORK OUT EASILY, AGAIN DRIVING ME LOONY TUNES IF YAA KNOW WHAT I MEAN.
HERE IS THE SKINNY: SOLUTION TO YOUR PROBLEM !!!! IT DOES WORK.
1, TURN ON THE COMPONENT YOU WANT TO PROGRAM.
2, PRESS AND RELEASE THE COMPONENT BUTTON ON YOUR REMOT THAT CORRESPONDS TO THE COMPONENT YOU WANT THE REMOTE TO OPERATE.
TV, VCR, ETC... THE ILLUMINATED ON-OFF BUTTON WILL TURN ON AND STAY ON.
3, NOW PRESS BOTH BUTTONS ON-OFF AND TV, OR: ON-OFF AND CBL. WHAT EVER.
THE ON-OFF BUTTON ON TOP OF THE REMOTE WILL TURN OFF, KEEP PRESSING
AND IT WILL COME BACK ON AND STAY ON. RELEASE THE BUTTONS,BOTH.
ON-OFF WILL STAY ON NOW.
4, KEEP POINTING THE REMOTE AT THE COMPONENT, THE REMOTE AND THE TV
NEED TO TALK TO EACH OTHER,(MAKES SENSE.)
5, GO TO THE BOTTON OF THE REMOTE AND PRESS THE "PLAY" BUTTON,
RELEASE. "" KEEP PUSHING THE PLAY BUTTON EVERY 5 SECONDS,
UNTIL THE TV TURNS OFF"". OR THE VCR, OR THE CBL, WHATEVER YOU ARE
PROGRAMING.
6, NOW: PRESS AND RELEASE THE "REVERSE" BUTTON, THIS IS AFTER THE TV
HAS TURNED OFF. TV SHOULD TURN BACK ON WHEN THE "REVERSE" BUTTON
IS PUSHED.
7, IF THIS WORKS THE LAST STEP IS TO HIT THE "STOP" BUTTON,
THIS WILL SAVE THE SETTING. REMOTE SHOULD BE PROGRAMED AND TURN
THE TV ON AND OFF. YOU DON'T NEED THE SILLY CODE NUMBER, THE REMOTE
DOES THE ACTIVE PROGRAMMING AUTOMATIC.
HOPE THIS HELPS YAA ALL... "PEACE".........OKIE
Posted on Nov 15, 2008
dvinnedge
  • 35 Answers
SOURCE: lost my manuel "codes" to my rca universal remote control crk74ba3
magnavox codes, 11454, 10054, 10030, 10706, 11990, 11963, 11944, 11931, 11904, 11525, 11365, 11254, 1198, 10802, 13=0386, 10230, 10187, 10186, 10179, 10096, 10036, 11028, 10024, 10020
Posted on Nov 29, 2008
I have RCA 404n universal remote. I am trying to program a Philips Dvd/VCR combo device. I cannot I guess it out. Please help :) thank you.
Use code search to find something that handles some or all functions of your Philips combo. If a search through all codes stored in the remote fails, you may have to try a different universal remote. All universal remotes do not store all possible codes.
Dec 24, 2016 | RCA Televison & Video
Philips DVD/VCR Player DVP3150V code for RCA universal remote
My RCA universal remote code list shows 062, 096, 022, 021, and 124
Nov 01, 2012 | Philips Televison & Video
I've disc locked my DVP3980 and it asks me to enter a password. I've never set up a password to my recolection and don't know what it could be. Thank you for your time, Ian Williamson
Ian, try the password 136900. If that passcode works for you, then access the general set up menu using your remote, and choose the Disc Unlock option.
Hope this helps!!!
Dec 20, 2010 | Philips DVP3980 1080P DVD PLAYER
Need codes to philips dvd player
If it is a universal remote it should come with an instruction booklet. (Containing the codes) If the codes there don't work, try all the other philips codes (dvd or not). If tis still fails, get another remote.
Apr 12, 2010 | RCA RCU404 Remote Control
Program RCR4358 to Control Philips DVD player DVP5982/37 C1
I am having the exact same problem. Did anyone ever find a fix for this?
Mar 24, 2009 | RCA Universal Remote Control
I bought a Philips DVP3980 on the promise that I'd be able to go online and get instructions to unlock the regional zoning to make it multizone. I haven't been able to find these instructions -- can you...
DVP3980
1. Turn the DVD player on.
2. Open the loading tray.
3. Press the "Setup" button on the remote control.
4. Navigate to the "Preferences" page using the right arrow key.
5. Type 138931.
6. The current region code will be displayed - use the Up/Down arrow buttons to select the region required or "0" for all regions.
7. Press the "Setup" button on the remote control.
8. Press "OK" on the remote control.
Simple!
Oct 12, 2008 | Televison & Video
I Need Codes.
Here you find RCA D770 codes :
How do you program an RCA d770 universal remote
Panasonic are : 1003, 1054, 1062, 1170
Aug 23, 2008 | RCA D770 Remote Control
I NEED REMOTE CODES FOR THIS DVD RCA DRC200N
I finally found a code that works. Code 3144 worked. I am using the RCA universal remote control RCR412S and RCA DVD player DRC200N. The code 3144 is listed under Memorex in the code book that came with the remote control.
Oct 17, 2007 | RCA DRC200N
RCA DIRECTV Satellite Remote Control Logo
403 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
