Question about Hitachi Heating & Cooling
My Hitachi RA-15MA has water inside it. What could the problem be.
Cam specs on a 1967 Pontiac 400, 335 hp
Firebird App. Pontiac Part # Duration @ .050 Degrees Int/Exh Adv Duration Degrees Int/Exh Lobe Center Degrees Int/Exh Lobe Separation Angle Overlap Cam Lift Int/Exh Gross Lift Int/Exh
(1.5:1 Ratio Rocker) Gross Lift Int/Exh
(1.65:1 Ratio Rocker) 1977 TA6.6 549431 274/289 62 .249/.270 .374/.406 .411/.446 1978 TA6.6 10003402 273/289 54 .270/.271 .406/.407 .446/.448 1979 TA6.6 10003402 274/298 55 .249/.270 .374/.406 .411/.446 1967 400, 1968 350, 1973-76 400 w/ AT 9779066(E) OEM 200/210 273/282 106/116 111.25 55 .272/.271 .408/.407 .449/.448 1967-68 400HO w/ MT 9779067(P) OEM 200/213 273/289 113.5 54 .272/.271 .408/.407 .449/.448 1968 400 HO MT & RA-I AT, 1969 350 HO MT, 1969 400 MT, 1970
RA-III MT/AT, 1971-72 455 HO MT 9779068(S)
OEM 212/225 288/302 113/118 116 63 .272/.271 .408/.407 .449/.448 1967 RA MT/AT, 1968 RA-I MT,
(Some 1969 GTO RA-III MT) 9785744 (H)
OEM 224/236 301/313 112/119 115 76 .272/.271 .408/.407 .449/.448 1968-70 RA-II & RA-IV MT/AT 9794041
(T) OEM 230/240 308/320 112/115 114 87 .313/.313 .470/.470 .516/.516 (Stock in RAIV)
Sep 20, 2017 | Pontiac Cars & Trucks
How do you stop a kohler toilet from spraying water inside of tank lid
There should be a small hose that is spraying the water. That hose should be put inside the overflow tube and heald in place with a clip or put into a small hole on top of the tube. Only put the tube in just enough to hold it in place. If it is spraying from anywhere else you need to replace or repair the ballcock.
Nov 13, 2014 | Kohler - Toilet - Two-piece - Highline -...
I have a 2yr old Kohler K4634 toilet. After flushing the water level drops about 1 inch in the bowl after the bowl filled. This causes a lower level in the bowl than is recommended. The main issue
check to see if waster continues to run into the bowl after the plunger has returned to stop water flowing. If it is a slow leak then replace the flush washer on the stopper plunger.
Oct 01, 2014 | Kohler K-4634-RA-0 Cimarron Toilet Tank...
Rotel RA 12
I think RA 12 is not existing type, but RA 12xx types exist.
Please try this link, and I hope you will find the relevant documentation.
gylacz
Mar 18, 2013 | Audio Players & Recorders
Hitachi SF-P95FJ WASHING MACHINE ERROR CODE F9
if you have Hitachi nw-d8ax f1 error check water sensor f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips nava@netintec.com cheers
Oct 29, 2010 | Washing Machines
Alesis RA 500 makes a "clicking" sound and no more sound. later it will "click" on again
Clicking sound is a protection relay. This means one of the power amp sections have failed. Or that your speakers connections are faulty
Sep 24, 2010 | Alesis RA300 Amplifier
RA will not track on Orion Atlas mount
Are you sure it's not actually working (tracking)-- can you hear the motor running?
I would contact Orion and make sure you have a manual for the hand-controller-- it may have a setting that turns tracking on or off.
http://www.telescope.com/control/main/
Nov 14, 2008 | Orion Atlas Mount GoTo Upgrade Kit...
Hitachi RD6106 10-Cup Rice Cooker
The Hitachi has notches on the inside of the pot. You put your rice in the pot and than start adding water until your water level reaches the notch labeled 7. Remember that the rice has to be inside the pot when you start adding water so that you will have the correct amount of water for the rice you're cooking. It doesn't work the other way around. Rice in pot than add water. But usually the average cup that comes with these rice cookers only holds 3/4 of a cup when you fill them to the top.
Jul 09, 2008 | Hitachi RD6106 10-Cup Rice Cooker
Need Instructions on how to use the Salton RA-10NS Rice Cooker
hi!
good news! you can use any small cup as a replacement for that. just remember that the ratio is 1:1
1 cup of rice = 1 cup water.
hope this helps!
cheers!
Jan 05, 2008 | Salton RA10 10-Cup Rice Cooker
Heating & Cooling Logo
Top Hitachi Heating & Cooling Experts
D. E. Hev
rugby prop
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
