Question about Kenmore 57029 Side by Side Refrigerator
Freezer started forming ice crystals on everything so we thought it was too cold and turned it down one notch. The next day everything was defrosted so we turned it back up--and now it doesn't seem to be working at all
    Brigadier General:
  • 3,513 Answers
This shows that water line could be frozen in the door. You need to disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws. Covering the opening with a blanket will prevent the loss of cold in the freezer. The refrigerator makes a heater that will prevent this from happening again. The part number for this heater is WR49X10173. Next you need to disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad and needs to be replaced.
Do get back to us for any further query and do not forget to accept it.
Thanks for contacting fixya.com
Posted on Oct 12, 2010
Accidentally left the freezer door open, and ice crystals formed.
You can defrost by turning off the power and leaving the door open, but if it is a frost free model it should gradually rid itself of ice at normal temp settings. This may take several days.
Apr 19, 2015 | Refrigerators
Whirlpool Estate series fridge/bottom freezer no longer gets cold
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 13, 2009 | GE GSS25LGM Side by Side Refrigerator
Ice getting accumulated even it is frost free
Sep 07, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Freezer isnt freezing yet ice is forming on the back wall
If the evaporator coils behind the back panel of the freezerare icing up because of auto defrost failure that will stop the circulation ofcold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. Inmost newer models the timer has been replaced by an electronic control board.If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicksand everything shuts down. The heater should now come on. If it does, replacethe timer. If it doesn't, check the heater and defrost thermostat. Turn thetimer again till everything starts back up to end the defrost cycle.
Sep 03, 2009 | Whirlpool 20.9 cu. ft. Top Freezer...
Neverending ice cystals buildup in freezer
Hi Rachel,
Opened 3-10 times per day, per week, per month?
There is only one possible source of these ice crystals -- moisture precipitating from the air (condensate) -- this air is coming from outside the freezer. It's either getting in when the freezer is opened or coming in around the gasket.
You might try a very thin coat of vaseline on the gasket to get a better seal.
Charlie
May 07, 2009 | Refrigerators
Fan running, weak air, fridge not cold enough, freezer working fi
it sound that your fridge is cloged of ice if so defrost it by unpluging it for the day to defrost completlyb with freezer door open then replace defrost timer if to much ice is formed on coil air does not cuculate properly thanks from gille
Feb 15, 2009 | Kenmore 64254 / 64252 / 64259 Top Freezer...
Ice forming on freezer
The drain is plugged. This fridge will defrost every 8 hrs or so. When it does , it will melt the frost that has built up on the evaporator. This melted frost will run down a drain under the evaporator to a drain in the bottom directly under the evaporator. When the drain gets plugged the water cannot drain out of the freezer compartment. After several defrost cycles the melted frost will overflow onto the freezer floor. When the fridge starts back up it will freez this water is the bottom of the fridge. sometimes this water that is now ice will melt on the next defrost cycle and actually run out into the floor. You will have to unplug the fridge or turn it off, then remove the cover to the evaporator. Get a hair dryer and melt the ice aruond the evaporator and drain. Once the ice is removed, check the drain and try to clear it. Once clear, replace everything but the shelves. Plug the fridge back in or turn it back on. Observe and listen for the evaporator fan. It should be running now. When working on the ice on the evaporator always be carefull. The defrost heater can be damaged if up push or pull on it too much.
Nov 15, 2008 | Samsung RF265AA Bottom Freezer French Door...
My frigidaire refrigerator does not get cold, but the freezer is really cold and freezes up. there is huge sheets of ice that form in the freezer and the food in the refer goes bad.
My problem also is that freezer is cold but fridge gets warm. When I turn the whole thing off for a sort time it works again.
How would I know which part needs to be replaced to repair this?
Rod
rodbutler@psci.net
Jul 07, 2008 | Frigidaire FRS3R5EMB Side by Side...
Kenmore 57029 Side by Side Refrigerator Logo
51 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
