Question about HP Photosmart Premium C309A All-In-One Printer
When I scan in a document, I can't find it to use it. I have looked everywhere. It is not where is says it is putting it. It doesn't show up at all. Doesn't matter if I scan to PDF or to Word 2007, nothing there. Where are the scans going?
    Scholar:
  • 135 Answers
I looked in the users manual http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&lc=en&dlc=en&document=&product=3737195 I'm wondering what OS you are using xp, vista or win 7
I found this in the knowledgebase go have a look . looks like theyre aware of this issue and have a update to fix it at Critical Update: Cannot find scanned image or document files after scanning completes. http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-79942-3&cc=us&lc=en&dlc=en&product=3737195&tmp_track_link=ot_search
Fix/Enhancement: When I scan in a document, I can't find it to use - s.gif Corrects a scan file configuration problem which causes scan files to be sent to a nonexistent folder
Posted on Oct 12, 2010
Testimonial: "I had been trying to solve this issue for about 2 weeks. Mediastormer researched and had the solution in less than an hour, maybe faster. Thanks!"
  • Osogama
    Osogama Oct 12, 2010
    I hope this helped you to fix the problem
  • kwconway Oct 12, 2010
    Thanks so much! It fixed the problem. Works like a charm now. BTW it was a Windows Vista 64 bit OS. Thanks again.
I have an HP Officejet 6500 wireless printer. If I scan or copy a document through the feeder the scanned or copied document has vertical lines from top to bottom. If I lay the document on the glass and...
Lift the scanner top, then look at the narrow pane of glass. There probably is a spek of dust or ink on it. Clean it with alcohol. I've had to remove the glass, due to the speck being on the undersaide of the glass.
Also, lift the ADF cover and clan the rollers with a damp cloth.
Jul 17, 2011 | HP Officejet 6500 Wireless All-in-One...
How to scan on MFC-7840W?
There are many questions and answers related to Scanning, If you mentioned how you would like to scan, eg, Scanning using the Brother software or scanning using windows/mac utilities, I can help you better. Anyway, here are few scanning related tutorials, please click this LINK and select whatever tutorial/s you wish to go through.
To scan using the Brother Control Center, follow the instructions given HERE. And THIS is the tutorial about how to scan without using the Brother Control Center application.
Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Jun 23, 2011 | Brother MFC 7840W Printer
When I copy papers on my Canon imageRunner 2800 there are 2black lines in the middle of the copied paper. How do i solve this problem?
Hello mike,
You may have a fairly easy problem to fix, and that's good thing ! If the lines only appear when you use the document feeder then we can handle this. Please place a document on the platen glass and make a copy. If the copy looks good then we need to clean your "scan" glass. The scan glass is the small glass located to the left of the large platen glass. It's about 3/4" by 14",and will only cause problems when you use the automatic doc feeder.If it gets dirty then thin lines will show up. If indeed this is the problem then I have a test u can use that will help you Take a plain piece of paper. Mentally divide it into 4 squares and then simply write the numbers 1,2,3,4 on each quadrant. At the top edge of your newly formed test document place an arrow pointing away from the body of the paper, and it needs to point "UP".. Now draw an arrow on the test document that points to the left "lead " edge. Put your newly constructed test target in the document feeder and make a copy of it. Now, you KNOW how you placed the test document, so lets look at the copy. If you have lines only thru the document feeder, then look at the copy you made and notice where the lines are. Ok, now you know where the lines show up on the copy, so lets take your "test" document and compare them side by side.Once you have made this comparison, and can see where the lines show up, take the ORIGINAL test document and place it IMAGE UP (1,2,3,4) on the glass. This will point out exactly where the dirt is. By looking at the copy that has lines, and where they show up on the page, you can use the test page that is laying face up on the glass and compare the 2. BOOM !! You can look towards the small scan glass and find the dirt that is causing the lines. With your copier, IF you place a document on the glass then the scanner moves to "scan" the document. But if you use the document feeder, the scanner stays in one spot and the motion of the document moving ACROSS the scanner and is scanned like a bar code. If there is dirt on the scan glass then a line occurs instead of a "blob" as you would see if you used the platen glass.I hope this all makes sense (I tend to ramble) and I hope it helps you. You of course could have far more complex problems. But your description of the problem sounded like my remedy/idea might be just what you need. Take care and good luck. if I helped you please let "fixya" know. SPINAL
Apr 02, 2011 | Canon Office Equipment & Supplies
How do i scan to my computer
As long as the printer/scanner is hooked up to the computer, you should be able to put the document on the glass face down, close the lid and press the scan button. The HP screen will pop up on the computer screen, don't mess with that, just let the document scan (it should show you the progress) and once it's done, it will ask you if you want to scan something else or be done. If your done, click done and then it will open up the HP window and show you what you scanned. To retrieve the scan, I always go to start, my documents, my scans and look for the current month and year, open that folder and then you have access to the document you just scanned. Hope this helps.
Mar 02, 2010 | HP Deskjet F340 All-In-One Printer
In what direction to you put in the paper when sending a fax? Up or Down?Front or Back? Thanks
Up or down doesn't matter much, as the recipient can always turn the printout around :) But generally putting the documents upside down will make the fax scan the top of the page first.
As far as front/back is concerned, it depends on the construction - if you look at the document feeder you will see a symbol of a sheet with a corner bent, showing the back side. If there are stripes (symbolizing text) on that corner, you must put the document(s) face down; if the stripes are on the rest of "sheet" - put them face up.
In your case most probably it will be face down. You can always check that, and the quality of document scanning (whether the document is not too light for example) by using the "Copy" function of your fax.
Dec 21, 2009 | Brother IntelliFAX 770 Plain Paper Thermal...
I have a HP Photosmart 6180 series printer. I want to know how to scan multiple document of several pages or more and put into one file? Whenever I have scanned in the past, I have only been able to put 1...
To scan documents, you must choose the PDF scan. Need to figure out how to choose to scan as a PDF. That's in the software or scan buttons. In that setting, there should be a choice of single or multiple scans. After the scans, you choose finish and the program should show you a PDF document and then save to a folder of your choice.
Jul 30, 2009 | Epson Printer
My printer prints and copies but doesn,t scan
scanning requires a place to keep a copy of the document.connect ur computer and printer via usb2.0 and then open kodak home center from ur desktop. from there scan the document. u will be able to scan and keep a copy of the document on the desktop. if there is any problem,contact kodak @ 1800 421 6699
Jul 19, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
Can't find where scan is stored. Looked everywhere in every file
Normal 0 Most applications default to the MY Documents or the MyPictures folders, look in these first.
If they are not there try this:
Open your scan software and scan a pic
After the scan completes watch closely, the application will show a location or a --scan to -- option.
At this point you can select a location for storage.
Another place to look is the application folder itself.
Feb 01, 2009 | Canon PIXMA MX850 Multifunction Printer
Can't find file where scan goes from Canon MX850
When you choose email or pdf you should be shown a file name of the file - search your computer for this file using Start>Search>For Files and Folders (XP) or Start>Search (Vista). When you locate the folder the files are in create a shortcut to it on your desktop. The obvious places to look would be in your My Documents folder or the Program Folder for the application (C:\Program Files\Canon?)
Dec 19, 2008 | Canon PIXMA MX850 Multifunction Printer
HP Photosmart Premium C309A  All-In-One Printer Logo
323 people viewed this question
Seeker5211
Seeker5211
