Question about Maytag PGR5710 Performa Gas Kitchen Range
How do I unlock the oven on my Maytag range? I am unable to use the oven due to being locked. It does'nt work on bake or broil.
  • 833 Answers
SOURCE: Oven will not bake or broil
bann...why did you replace the element? It is possible that the relay or the control circuit were the problems and still are. The hi limit switch is a temperature 'box' which is designed to open the circuit in case of overheating. Rarely a problem. First, these units are 3 wire units. That means 220 volts ... two breakers. They may be part of a linked unit or separate. Turn them BOTH off and then on. Do all of your burners heat properly on high? If you have a voltage tester, you can test to see if the voltage is there. Unplug the unit. The vertical slot is neutral. Each of the other slots with the neutral should light the tester. If not, your problem is outside the stove.
Posted on Dec 12, 2007
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
  • 1314 Answers
SOURCE: GE XL44 gas range...door is registreing as locked when it si not
try cancel if that doesnt do it try unplugging it for three mins
Posted on Feb 14, 2008
SOURCE: Oven igniters, are both suppose to be on during preheat or bake?
good choice,sounds like the bake igniter is bad
Posted on Nov 29, 2008
SOURCE: Can't Unlock oven doors after "self-Clean" maytag double oven
I was advised to disconnect power for at least 60 seconds to clear the control board. I did this several times with no luck getting the door unlocked. However, a few hours later, the door did finally unlock. Not sure what ultimately caused the door to unlock, but happy that I did not have to replace the control board.
Posted on Dec 22, 2008
Maytag oven problem
Somehow, usually when cleaning the face of the clock area, you locked the oven control. Go into your manual, and it will tell you how to unlock it. If I remember right, try holding in the broil button for 5 seconds, that might take it out of the lock mode.
Apr 04, 2008 | Kitchen Ranges
Maytag double electric oven. we turn on to bake and would switch to broil then will turn off.
Assuming this is on a gas range, the bake burner ( under the oven floor) and the broil burner ( at the top of the oven) have electric igniters . When switching from bake to broil the broiler goes off due to a defective or broken broil igniter. cheap part to replace ( +-$40.00)
Oct 16, 2014 | Maytag Ovens
When I turn on the broil function in the top oven, the bake igniter glows. I checked the voltage in the wires to the broil igniter and there is 0 volts. Is this a bad component on the ECB or can the ECB be...
This is probably a problem with the wiring outside of the control. To confirm this, check for continuity on the bake and broil relays upon activation of the broil function. If the the broil relay activates and the bake relay does not then your problem lies outside off the control board. I am familiar with troubleshooting Maytag appliances as I work for a company that repairs appliance timers.
Mar 20, 2011 | Maytag MGR6772BDS Gemini Gas Kitchen Range
My top oven on the maytag "gemini" doesn't work! it is a gas oven.
1) Confirm if its just the bake or both bake and broil that doesn't work. 2) If its just the bake you will most likely need to replace the bake ignitor. 3) If its both you need to test for voltage output from the electronic control to the ignitors.
Jan 13, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Oven doesn't work
I once had the same problem! Don't remember the part number. But there are two coils; the broil coil is on top and bake coil on bottom. Both are inside the oven at the rear. I replaced the bottom coil and my wife is baking again!
May 02, 2009 | Maytag MGS5770 Gas Kitchen Range
Oven not heating
if that hi limit is bad or tripped you wont get heat.the hi limit should sit near the heater if not in it.if you find this is tripped your thermostat could be faulty.from the schematic try to trace the wires from the heater to the hi limit and then jump it out.let me know.
Dec 11, 2007 | Maytag MER5755QAS CleanDesign Electric...
Maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Maytag PGR5710 Performa Gas Kitchen Range Logo
398 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
