Question about Lite On (SK2850) (sk-2850) Keyboard
I have a LITEON SK-6000 keyboard and the touchtone mouse pad stopped working. can it be replaced? If so, where to get part?
PC CONCEPT SK-6000, KEYBOARD WORKS WITH USB ADAPTER, BUT MOUSEPAD WONT. HELP
Install drivers should come with a disc install the software and all should work
Jan 04, 2014 | Maxi Switch Silitek SK 6000 Keyboard
I cleaned my keyboard while turned on and now I cannot get my number pad to work, which buttons did I accidentally push to get to turn off and how can I get them back on.
Based on your description of the problem you're experiencing, it sounds like you most likely pressed the "NUM LOCK" key. If NUM LOCK was activated before you cleaned the keyboard and was accidentally pressed during cleaning, this key press would deactivate NUM LOCK, causing the number pad to stop responding. To reverse this, simply press NUM LOCK again. The NUM LOCK button is located right above the "7" key on the number pad (see picture below).
Alternatively, since the setting determining whether NUM LOCK is activated when your computer is started is stored on your hard drive, you can try restarting the computer to revert back to an active NUM LOCK. Be sure to try this in case the first solution above does not work.
If you found this solution helpful, please leave a positive rating!
Sep 06, 2011 | Maxi Switch Silitek SK 6000 Keyboard
Lite on keyboard sk-6000 USB conection windows xp
Make sure that all USB functionality is enabled in the BIOS, especially USB Legacy Mode. If Windows still does not recognize the keyboard, then it is not compatible with USB. USB keyboards can be found as low as $10 pretty easily if all you need is basic keyboard functions.
Feb 11, 2010 | Maxi Switch Silitek SK 6000 Keyboard
Nc 6000 mouse pad not working...only a wireless mouse will work..the pad does not work
There are two types of connectors to the mouse pad...unscrew the bottom screws in the laptop. Hint: remove the extra cdrom from its tray and there is a screw hidden there. the keyboard should slide out first and then the houseing of the surrounding of the keyboard to include the mouse....make sure the connectors are snug and then is it still fails then the mouse is faulty. The recepiticals that the ribbon cable to the mouse plug into have a tanish color that pulls out and then you feed the ribbon in then push the tan portion back into place....takes a little work but that's usually the problem. Hope this helps
Nov 05, 2009 | HP Compaq nc6000 Notebook
Keyboard wont connect i have windows vista home basic and a Sk-6000 keyboard
Make sure the computer is off, before you connect the keyboard. After you connect the Keyboard, go ahead and start it up.
Aug 28, 2009 | Maxi Switch Silitek SK 6000 Keyboard
Wireless desktop 6000 keyboard problem
Check the inside of the battery chamber to see if there is corosion on the spring or front pip for the + ve.Batteries leak ands should be chaged every 6 months regardless
Jul 27, 2009 | Microsoft Wireless Laser Desktop 6000 V2...
Medion Media PC Model 8828 uses wireless keyboard and mouse,(Liteon SK-7225). The keyboard has failed. Any tricks please? Alternatively, where could I but a direct replacement? Many thanks indeed. ...
The wireless keyboards & mice work on batteries, try replacing the batteries first, if that doesn't work you may try with an USB(or PS2) replacement keyboard/mouse.
Dec 17, 2008 | Computers & Internet
Sk-6000 keyboard
For the touchpad: if your keyboard equipped with standard COM connector try: http://www.acersupport.com/library/ti_note/2x0tpad.exe (older synaptics driver - working with COM port based touchpad perfectly) - or if you have converted it to PS2 connector (i converted my one from COM to PS2) you can use the latest generic touchpad driver from http://www.synaptics.com/support/drive.cfm . (sadly synaptics dropped support for comport based devices in the latest drivers...)
Dec 23, 2007 | Maxi Switch Silitek SK 6000 Keyboard
Lite On (SK2850) (sk-2850) Keyboard Logo
210 people viewed this question
Top Lite On Computers & Internet Experts
Rommel Balcita
Gbenga
William Alequin
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
