Question about Flotec 1 Hp Deep Well Pump
Pressure switch - Flotec 1 Hp Deep Well Pump
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
    Problem Solver:
  • 19 Answers
Remove cap from pressure switch (small nut on top). You will see 3 threaded studs with springs held down by nuts at the end opposite from wired connections. Avoid wired connections with tools and fingers! The center sprung nut adjusts the ON AND OFF pressure settings. Clockwise (tightening down on spring) increases the pressure setting. One of the outside springs controls nothing - note that it has no connection to the switch moving parts. The other one adjusts the OFF setting. So adjust the center one until the ON pressure is 30 psi and then adjust the OFF setting until the pump cuts out at 50 psi. If you have an expansion tank, set this to 2 psi below the OFF setting. (If you have manual for the pump, check the pressure settings in the tables given for your pump.)
If this isn't what you need, please post more info!
Posted on Oct 14, 2010
Why do I get an error saying that the pressure switch is open
pressure switches in washing machines , control the water level
in your case the program telling you the pressure switch did not operate when machine was filling or emptying , it may not be the pressure switch that is at fault , it could be the small pipe connected to the pressure switch is blocked with muck , so disconnect machine, find pressure switch , pull of pipe and blow through
cycle pump may do trick ,otherwise replace pressure switch.
good luck.
Oct 10, 2016 | Washing Machines
E34 code what does this mean
Incongruence between level of electronic
pressure switch and level of anti-boiling
pressure switch 2 (duration of fault at least 60
seconds).
Cycle is blocked with door closed.
Could be: Hydraulic circuit of pressure switches; electronic
pressure switch; pressure switch; wiring between main PCB and electronic pressure switch; wiring between main PCB and safety pressure switch; and finally main PCB.
Dado
Oct 20, 2014 | Zanussi FJS1225W Front Load Washer
Karcher pressure washer 620m motor only runs with switch held down but will not water pressur is the same as tap pressure out the nozzle
it is not uncommon that the switch is bad? if the switch controls the pressure telling it their is water and to start working? then i would just replace the switch.
Dec 17, 2013 | Karcher Garden
Switch interruptor
If we are talking about a pressure switch, it usually is the low pressure cut-off switch. Before messing with this switch, verify what your Freon pressure is.
If the pressure is low, the low pressure switch may be fine and you need to add Freon and find out why the Freon escaped.
If you have high pressure, there is a second switch which cuts power to the compressor. Too much Freon will activate this switch.
Tip: You have both a high and low pressure switch. The proper amount of Freon will center the pressure and keep the compressor running more consistently.
Either pressure switch unscrews from the fitting and with a minimum of pressure can be removed from the lines and replaced. The housing should have shapes for wrenches.
May 12, 2013 | 1997 Ford Ranger SuperCab
Diagnostic code P1782
P1782 DODGE - 2/4-OD Pressure Switch Circuit Possible causes of this code are: - Low transmission fluid level (check level hot transmission only)
- Dirty transmission fluid (has transmission been serivced at least every 60,000 miles, fluid and new filter?)
- Faulty 2/4-OD Pressure Switch
- 2/4-OD Pressure switch poor electrical connection
- 2/4-OD Pressure switch circuit is open or shorted
P1782 DODGE Description The pressure 2/4-OD Pressure Switch is part of the pressure switch of the transmission. The pressure switch are located in the solenoid assembly. The switch provide input information to the Transmission Control Module (TCM). The switch will inform to the TCM is pressure exist in a specified hydraulic circuit. the TCM uses this information to verified that the solenoids are working or not.
Oct 20, 2011 | 1999 Dodge Caravan
What is proper fix for fault code p 1782
P1782 - P/ES Circuit Out Of Self Test Range.
Means that 2-4 pressure switch sense circuit failure. It basically means that the transmission solenoid pack needs to be replaced.
Symptoms:
- Engine Light ON (or Service Engine Soon Warning Light)
- Transmission shift shock
Possible Causes:
Hope helps.
Apr 20, 2011 | 2001 Chrysler Concorde
LARRS LX 400N It will not start the ignition sequence. Flame switch is OK. Limit switch mounted on the right outside of the upper cabinet is OK. Have low voltage. The pressure switch is open (is there...
"The pressure switch is open (is there supposed to be water pressure on the pressure switch so that it will close?)"
All switches need to be closed in order for this heater to start.
If you know you have good water flow (at least 50gpm) and your finding the pressure switch still open, it is either failed or clogged. Clean or replace the pressure switch.
Apr 12, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
WFW9200SQA12 f32 error
The "F32" error code is indicating that there is no electrical supply to the Pressure Switch from the Central Control Unit (CCU) or if the Pressure Switch contacts are not making, then "F32" is displayed.
Possible Causes/Procedures:
  • Pressure switch failure
  • Check the Pressure Switch wiring harness for continuity.
  • Check the Pressure Switch for correct operation with a Digital volt/ohm meter.
  • To manually check the function of the Pressure Switch, remove hose from switch and apply air to switch. Audible clicks will be heard from the switch.
Jan 15, 2011 | Whirlpool GHW9400 Front Load Washer
I need to know where the oli sending unit is and how to replace it?
Fig. 1: Location of the oil pressure switch-3.3L and 3.8L engines
Fig. 2: Location of the oil pressure switch-3.0L engine
Fig.: Oil pressure switch (sending unit) schematic
The low oil pressure warning lamp will illuminate when the ignition switch is turned to the ON position without the engine running. The lamp also illuminates if the engine oil pressure drops below a safe oil pressure level. To test the system, perform the following:
  1. Turn the ignition switch to the ON position.
  2. If the lamp does not light, check for a broken or disconnected wire around the engine and oil pressure sending unit switch.
  3. If the wire at the connector checks out OK, pull the connector loose from the switch and, with a jumper wire, ground the connector to the engine.
  4. With the ignition switch turned to the ON position, check the warning lamp. If the lamp still fails to light, check for a burned out lamp or disconnected socket in the instrument cluster.
REMOVAL & INSTALLATION
On the 2.4L engine, the oil pressure switch is located on the side of the engine block facing the firewall. On the 3.0L engine, the oil pressure switch is located on the oil filter adapter housing, next to the starter motor. On the 3.3L and 3.8L engines, the oil pressure switch is located next to the oil filter.
  1. Locate the oil pressure sending unit on the engine.
  2. Disconnect the negative battery cable.
  3. Disconnect the pressure switch electrical harness.
  4. Using a pressure switch socket, deep-well socket or wrench, loosen and remove the pressure switch from the engine.
To install:
  1. Install the pressure switch into the engine and tighten securely.
  2. Attach the electrical connector to the switch.
  3. Connect the negative battery cable.
  4. Start the engine, allow it to reach operating temperature and check for leaks.
  5. Check for proper oil pressure switch operation.
Hope this helps (remember to rate this answerr).
Dec 22, 2010 | 1999 Plymouth Voyager
I replaced my pressure switch with a Square D FSG2j24M4CP. Last night when the iron genie went into it's regeneration cycle the pressure switch snapped off. Should I be using a different type of pressure...
The problem is that the pressure switch is not adjusted properly...
You need to turn the taller screw down so that the pressure switch kicks the pump on sooner...
This tip will help you with that...
Well Pressure Switch Adjustment Water Well Problems
http://www.fixya.com/support/r3691134-pressure_switch_adjustment_water
heatman101
Jul 14, 2010 | Square D FSG2J24M4CP Water Pump Pressure...
Flotec 1 Hp Deep Well Pump Logo
299 people viewed this question
Top Flotec Garden Experts
Jay Finke
Jay Finke
Mike Raino
Level 1 Expert
jasbo
jasbo
Are you a Flotec Garden Expert? Answer questions, earn points and help others
