Question about Canon PowerShot S3 IS Digital Camera
Zooming in and out
When I zoom in and out quickly and fully extend or fully retract the lens the camera shuts off. Couldn't find any thing in the manual regarding this. Any suggestion would be greatly appreciated!
    Novelist:
  • 130 Answers
I know nothing that will cause it to shut down like that unless it's the batteries (bad set, bad brand?), or unless it's after a few minutes of non-use and it turns off due to power saving mode.
If it is just doing an auto power down malfunction, it requires service and I would call Canon and see what your warranty/service/upgrade options are.
Hope this helps!
Posted on Jun 01, 2008
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
My Kodak Z885 shuts off when I try to use the zoom even after I changed the battery to a DuraCell Ultra CR-V3. Any idea why?
I experienced the same thing while i was fixing a problem with my lens not extending fully. I simply used a vacuum cleaner over the lens to remove possible dirt/sand. After my initial (lens) problem was solved, using the zoom would automatically shut off the camera, so i used the vacuum some more and all the dirt preventing the zoom from extending is gone, so the camera works 100%
Aug 05, 2010 | Kodak EasyShare Z885 Digital Camera
Lens problem, turn camera back off then on message
That usually occurs after the camera has been dropped or dirt is stuck inside the moving parts. I have had this on two cameras; one was filled with dirt, and eventually started working again. If you can try to clean it while it is fully extended and retracted you may be able to get away with a simple fix. Cleaning it in one position may be impossible.
My other camera was dropped into dirt (with a lot of force...fell on it). After trying to clean it with the above method I was able to get it to finally work. The clicking you hear is the zoom mechanism binding on 'something', which is either dirt or a bent or broken part inside. After a few seconds it will shut off to prevent causing further damage.
Jun 19, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
Lens not extending
You have a lens problem. Sure it can be fixed but be sure to get an estimate first.
Aug 24, 2009 | Samsung Digimax S73 Digital Camera
My Pentax Optio S7 has developped a fault. When I turn it on, the zoom pops out, the screen lights up but it makes a buzzing sound then the zoom retracts and it switches itself off.
The gearing for the lens has become damaged and the lens can no longer fully extend. As a result, the camera detects a fault when attempting to extend the lens and shuts itself off. The most frequent cause of this kind of damage is dropping the camera with the lens extended. Always used the wrist strap!
Unfortunately, there is no way to correct this at the consumer level for this camera. It is very compactly designed, and the lens is the hardest to get at. Even if you were able to get to it, you'd still need the replacement part for whatever has become damaged. You will need to return this for repairs - although with the price of this camera, buying a new one will probably be cheaper.
Jul 03, 2008 | Cameras
Zoom lens Motor Problem?
The suggests the zoom control failure
Only Olympus can fix it to it will have to go back.
Nov 08, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Lens barrell doesn't retract for zooming out, only for shutting off.
Hello, Sounds like you have a drive motor/gear assembly malfunction,this type of failure is costly to repair.
Best Regards, Russell
Oct 29, 2007 | Kodak EasyShare DX6490 Digital Camera
Zoom lens won't fully retract
This is a gradual breakdown of the zoom mechanism due to ingress of dirt or having had a knock. A repair will be expensive- Fuji support will advice.
Sep 27, 2007 | Canon PowerShot S1 IS Digital Camera
Photosmart m627 camera
It sound like a problem with the zooming mechanism, does your camera was dropped down ? In case it dosen't, since your camera is still under warranty, best thing will be sending it to the appropriate factory service center for repair the problem. Good luck!
Aug 13, 2007 | HP PhotoSmart M627 Digital Camera
Canon PowerShot S3 IS Digital Camera Logo
105 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
