Question about Whirlpool RF365 Electric Kitchen Range
The innermost glass window in the oven door on my Whirlpool range is broken. I ordered and have received a new glass, but how to get in there to replace it is the problem. I have taken the outside of the oven door off, still cannot get to the innermost glass (there are 2 others outside of it). Please help!
  • 1 more comment
  • k41swaf Oct 12, 2010
    This is NOT a microwave oven. It is an electric range with self-cleaning oven below. I have the oven door apart with the outside taken off, now there are 2 other glass windows before I can get to the broken innermost window and I cannot get the metal of the inside door to come apart so I can insert the new window.
  • k41swaf Oct 15, 2010
    I have removed every screw I can find. There are 4 that require a socket that I did not have. This is the small glass windown (about 6 x 20), not the big one in the front of the whole door (I have taken that off). KS
  • k41swaf Oct 16, 2010
    Never mind - had an appliance repair man come and finish the job. The final set of screws were under the strip of stick-on foam insulation around the inside door; plus needed a socket wrench for the others. Thanks anyway. KS
  • Whirlpool Master
  • 3,247 Answers
You will have to remove the screws on the sides holding the frame and the inner glass panes.
See items 1 and 4 in the assembly diagram here. Hope this helps.
please rate the solution if you found it helpful otherwise post a comment.
Posted on Oct 12, 2010
  • Sam Oct 15, 2010
    Not sure if i have the correct model for your range. Is the glass window you mention listed on the diagram on the website I sent. Which item no. is it?
    If not, then I have not got the correct model of your appliances. Can you please let me know what are all the characters in the model no. after RF365.
    Genius:
  • 1,416 Answers
Please note before you can be able to fix in the glass of the oven you will have to remove he oven door carefully fix in the glass then return the door back on the oven carefully you can do that with below solution carefully.
Instruction on how to removing the door carefully.
Removing your microwave door allows you to quickly clean out any accumulated food or grease. This also makes it easy to get to all the crumbs and debris around the door hinges. While you have the door off its hinges, examine the plastic panel and glass window for signs of damage. Make sure you install a replacement door that is designed for your brand of microwave to ensure that it will fit correctly.
then
  • Remove the power cord from the electrical outlet and move your microwave onto a workbench or sturdy table. For cabinet-mounted microwaves, pry off the decorative grills or front panels and remove the mounting screws. You should then be able to slide the microwave out of its mounting bracket.
  • 2 Open the microwave door and remove the glass tray. Use a flathead screwdriver or putty knife to pry off the plastic cover on the inside of the door work. around the edge of the glass until the cover slips free.
  • 3 Remove the door by pulling the mounting pins out of the hinges at the top and bottom. You may need an assistant to steady the door so you can have both hands free to work with the pins.
  • Replacement Instruction.after fixing the glass.
  • Unplug the microwave and set it on a table or workbench. If you have a built-in microwave, you may have to remove some mounting screws or retention clips to get the microwave out of the support bracket. Open the door and take out the glass tray.
  • 2 Pry off a corner of the plastic panel on the inside of the door with a screwdriver or butter knife. Once it is loose, work the screwdriver or knife all the way around the glass and remove the panel.
  • 3 Ask someone to hold the microwave door as you disconnect it from the hinges. Depending on the design of your microwave door, you may have to remove a set of screws or slide a pin out of the hinge to release the door. Remove and discard the old door.
  • 4 Have your assistant hold the replacement door up to the hinges. Attach the door to the hinges by reversing the previous step. Snap the plastic inner panel into place around the glass. Move the microwave back to its original location. Insert and tighten the necessary mounting screws if you are working on a built-in microwave. Set the glass tray back inside the microwave and close the door.
  • Thank you and thanks for using fixya.
    • Oloyede Monsuru Oct 12, 2010
      hello,
      you can apply the method on any of the kitchen aid.
      thank you once again.
    Replace inner door glass in a Maytag CWE900 built-in oven?
    There is a poor diagram on Searspartsdirect.com, but no instructions. A diagram might help.
    Feb 18, 2015 | Maytag Microwave Ovens
    On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
    Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
    Tools needed: good Phillips head screwdriver or small quad bit driver.
    A. Open Door remove 2 screws and washers on door lining at door hinge area.
    B. With door in broil stop position lift door assembly off hinges.
    C. Lay door on table, position so that handle hangs freely over edge of table
    D. Remove 2 screws and washers that secure handle to lining assembly.
    E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
    F. Lift door lining up and out of wrapper trim assembly.
    G. Lay lining assembly on table with wool shield/inner part of lining facing up.
    H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
    I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
    J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
    K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
    L. Reassemble in reverse order.
    Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
    Broken glass on oven door how to replace it
    Here is a tip that I wrote about the oven door glass replacement...
    It is not that hard...
    Range/Stove/ Oven Door Glass Replacement
    heatman101
    Feb 04, 2011 | Maytag MGR5775QD Gas Kitchen Range
    Cracked inner oven glass window
    heatman101
    Jan 16, 2011 | KitchenAid Ovens
    Describe your dacor rsd30 new oven door Problem - the glass is broken in the window
    heatman101
    Nov 26, 2010 | Dacor Preference RSD30 Gas Kitchen Range
    The innermost glass window in the self-cleaning door broke (was in a rental). I ordered and received a replacement window, but am having trouble getting to the inside glass to put it in. I have the...
    :->, yes, I've been in this boat before. You need to remove the latches. Once you remove the latches, two screws on one end, a lever slot on other, then the rest will be cake. Hope this helps,
    Oct 12, 2010 | Whirlpool Kitchen Ranges
    Took apart glass oven door on a whirlpool. Where
    Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
    #1 -- Oven door liner
    #2 -- Oven inner glass
    #3 -- Oven door hinge
    #4 -- Retainer, glass
    #5 -- Bracket, handle
    #6 -- Door glass seal, top
    #7 -- Door glass seal, side
    #8 -- Oven outer door glass
    #9 -- Door handle
    #10
    Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
    http://www.appliancepartspros.com .
    Hope this helps.
    Thanks
    May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    Interior Range Window cracked - How to Replace
    It is simple enough not to need a manual.
    1- open the door, then pull outwards. The door mounts slide right out.
    2- lay flat on a towel on the floor. Remove screws on the inside of the door.
    3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
    4- replace broken inner glass panel
    5- put each piece back together, install screws
    6- slide door (mounts) back into their homes on the front of the range
    It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
    Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
    Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
    Whirlpool RF365 Electric Kitchen Range Logo
    95 people viewed this question
    Top Whirlpool Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
