Question about Sanyo DS27930 27" TV
Is this tv Digital?
Does it need an (analog to digital) converter box?
  • 975 Answers
!! YES !! CONVERTER BOX is NEEDED , AJ
Posted on Jun 01, 2008
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Is a curtis mathes CM19033S TV, digital capable (with digital antenna) or only analog?
To use this TV with a digital signal you need a digital to analog converter. Here is a link for a converter and one for the TV user manual.
Hope this helps.
Bob
Samsung CM19033 User Manual
Zinwell ZAT 970A Digital to Analog TV Converter Box for Antenna Use
Jan 06, 2015 | Curtis Televison & Video
How do I hook up Coby 5" black & white TV to my digital converter box ?
You will need a digital to analog converter which you can get at Radio Shack, Best Buy and most big box retail outlets or online. Your Coby is most likely analog and will require the digital signal to be converted to an analog signal from the digital converter box to the TV. UNLESS the digital converter box has analog (round connectors on the back) then you just need an analog RCA cable (which you can also get almost anywhere even your local CVS/Walgreens) to make the connection.
Nov 24, 2014 | Coby Televison & Video
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
How can I get analog channels to work with DTV without cable
Hello drandald,
Your tv is a digital tv, so you do NOT need a converter box. The tv has a built in digital tuner. But if you have any other older tv's then what you need is a converter box to convert analog signals to digital. I know there is one in Best Buy (not sure if there is one in your location) but they have one called access digital tv converter. They are about $50 (CAN). You would still need your antenna or however you get your analog signals. The antenna needs to be plugged into your converter box and then the box would need to be connected to your tv.
-Joe
Aug 29, 2011 | Zenith Z32LC2D 32 in. LCD Television
Do I need a converter box for a Sony KD-27FS170?
When a TV hasn't digital tuner, it's necessary to add it a digital to analog channels converter box, but your TV already has digital tuner, you can switch between digital and analog tuning by pressing the digital/analog botton on the remote control.
Feb 24, 2011 | Sony FD Trinitron WEGA KD-27FS170 TV
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
Is it digital ready for over the air transmissions or will it need a digital cable box?
This tv a analog tv,CRT tube tv don't have a digital tuner in side a analog CRT tv.Yes,buy the digital converter box to converter to recieve over the free digital air broscaast.
Jul 02, 2010 | RCA 36V430T 36" TV
Does the JVC AV27230 require a digital to analog converter?
if you are going to continue using the rooftop antenna, then you will nee to purchase a digital converter box. Those television sets are only analog. You do have an option to get Directv or Dish network and you will not need a converter box at all. Directv and Dish network are 100% Digital and the receivers work as converter boxes for that product only.
Jun 16, 2009 | JVC AV-27230 27" TV
Sanyo DS27930 27" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
