Question about GPS
I need a wiring diagram for a pivot retractable half unit-x headlight controller, the one with 6 wires, not the mini which has 4 wires
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
SOURCE: Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
Posted on Jun 06, 2009
  • 295 Answers
SOURCE: Headlight wiring diagram for 2004 Chevy Impala
I would go to Alldata.com on line for your vehckle to get the wiring diagrams.
Posted on Jul 18, 2009
c17hydro
  • 2984 Answers
SOURCE: replacing spark plug wires on a 1981 cadilac
Not sure what you mean by 8-6-4 but this will help you. Pick the correct one for your application:
GM (Cadillac) 250 (4.1L) V8 .GM (Cadillac) 273 (4.5L) V8 .GM (Oldsmobile) 307 (5.0L) V8 .GM (Oldsmobile) 350 (5.7L) V8 w/EFI.Engine firing order: 1-8-4-3-6-5-7-2 .Distributor rotation: counterclockwise
GM (Cadillac) 368, 425, 472, 500 V8.Engine firing order: 1-5-6-3-4-2-7-8.Distributor rotation: clockwise
GM (Cadillac) 429 V8.Engine firing order: 1-8-7-2-6-5-4-3.Distributor rotation: clockwise
Posted on Oct 17, 2009
iadame
  • 676 Answers
SOURCE: we need the wiring diagram
Try to see if this diagram will help you out. The ground could also be just black.
Posted on Sep 12, 2011
1999 Oldsmobile Delta 88 headlight problem, daytime running headlights come on, but will not come on when I press the switch, so I do not have any headlights at night, changed relays and switch
I have learned from experience that the things you changed are seldom the problem. It is probably a problem with the lamp control module (LCM), a little mini-computer switching device that controls the lighting circuits. It would be tucked up under the dash somewhere. An electrician (or you) would check for power in on the appropriate wires and then check for power out on the appropriate wires that go from there to the headlight dimmer switch and then routed to the headlight assemblies. You really need a wiring diagram to know what you are looking for. A yellow wire out from the LCM goes to the dimmer switch-this should be hot with headlights turned on.
Nov 05, 2017 | Oldsmobile Cars & Trucks
Spark plug wiring diagram for a 2003 chevy malibu
SPARK PLUG WIRE REPLACEMENT (ENGINE CONTROLS - 3.1L)
Removal Procedure
  1. Turn OFF the ignition.
  2. Notice: Twist the spark plug boot one-half turn in order to release the boot. Pull on the spark plug boot only. Do not pull on the spark plug wire or the wire could be damaged.
  3. Remove the spark plug wires 2, 4, and 6 from the engine left side spark plugs.
  4. Remove the spark plug wires from the retaining clips.
  6. Remove the spark plug wires 1, 3, and 5 from the engine right side spark plugs.
  7. Remove the spark plug wires from the retaining clip.
  9. Remove the spark plug wires from the ignition coils.
  10. Remove the spark plug wires from the engine.
  11. If you are replacing the spark plug wires, transfer any of the following components:
    • Spark plug wire conduit
    • Spark plug wire retaining clips
Installation Procedure
  1. Install the spark plug wires to the engine.
  2. Install the spark plug wires to the ignition coils.
  4. Install the spark plug wires 1, 3, and 5 to the engine right side spark plugs.
  5. Install the spark plug wires to the retaining clip.
  7. Install the spark plug wires 2, 4, and 6 to the engine left side spark plugs.
  8. Install the spark plug wires to the retaining clips.
v\:* { behavior : url(#default#VML); position:absolute; } v\:* { behavior : url(#default#VML); position:absolute; }
Aug 20, 2014 | Vehicle Parts & Accessories
Yamaha v star wiring diagram
Hi, Anonymous if your headlight is not working, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply wire to headlight bulb socket.
2. Worn, chaffed, or broken wires in the light circuit.
3. Corroded, broken, or loose pins/sockets in wire connectors.
4. Faulty hi/lo beam switch.
5. Faulty ignition switch.
6. Fuse is good but no continuity on both sides.
7. Faulty wiring between battery positive and headlight bulb socket.
8. Weak charging alternator/generator.
9. Faulty voltage regulator/rectifier, overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Yamaha Star 1100 wiring diagram Google Search
Electronics Star 1100 Wiki Knowledge Base
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2000/LIT-11626-13-36_96.pdf
Apr 13, 2014 | 2005 Yamaha V Star 1100 Classic
Wiring diagram
Hi, Anonymous if your headlight is not working, only one beam works, keeps burning out, blinking, or is dim the first thing you need to check is the headlight bulb for damaged filaments then check your light circuit fuse, then check your head light bulb socket ground wire for a clean tight connection, that being said the usual suspects are:
2. Worn down solder contacts or loose fit of the bulb base in the socket due to vibration.
3. Worn, chaffed, or broken wires in the light circuit.
4. Corroded, broken, or loose pins/sockets in wire connectors.
5. Faulty hi/lo beam switch.
6. Faulty ignition switch.
7. Fuse is good but no continuity on both sides.
8. Faulty wiring between battery positive and headlight bulb socket.
9. Weak charging alternator/generator.
10. Faulty voltage regulator/rectifier ground or overcharging.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
wr426 Wiring diagram Google Search
Wiring Diagram
YAMAHA WR426F Owner Service Manual
YAMAHA WR450F Owner Manual
Feb 13, 2014 | Yamaha WR 426 F Motorcycles
Logitech z3 wiring
I have a logitech z3 subwoofer with a mini-DIN-9 connector socket. It also has a volume control and 110V power cord. As best as i could trace the circuit, and using the TDA7377 stereo bridge amplifier chip datasheet, the pinout for the mini-DIN is as follows (untested):
1: L in (to vol.)
2: R in (to vol.)
3: Power (12V from transformer)
4: Standby (5V to play, 0.05mA; 0V to standby)
5: L out
6: R out
7: Ground
8: Ground
9: Ground
Connecting 3 to 4 with a large resistance (~20K ohms) should enable speaker. Pins 1 and 2 might be swapped; pins 5 and 8 might be swapped. Mini-DIN socket pin holes are numbered right to left, bottom row to top row:
9 8 7
6 5 4 3
2 1
Sep 03, 2012 | Logitech Z3 2 Speakers
Changing the headlight bulb?
1. Open the hood.
2. Remove the electrical connector from the bulb by squeezing the connector on both sides to unlock the tab. Pull the connector straight off.
3. Remove the rubber weather seal by pulling on the tab.
4. Unclip the end of the hold-down wire from its slot. Pivot it out of the way and remove the bulb.
5. Insert the new bulb into the hole, making sure the tabs are in their slots. Pivot the hold-down wire back in place and clip the end into the slot.
6. Install the rubber seal over the back of the headlight assembly. Make sure it is right side up; it is marked "TOP".
7. Push the electrical connector onto the new bulb. Turn on the headlights to test the new bulb.
Hope this helps you.
Dec 20, 2009 | 1998 Honda CR-V
I need a wiring diagram for 1987 Chevrolet 3/4 ton
The Haynes repair manuals usuall have wiring diagrams in the back of book.Around $20.
Oct 16, 2009 | 1990 Chevrolet Crew Cab
2003 BMW 330CI convertible frt. passenger window does not retract
the problem is in the door lock and the assemble must be changed. when one looks in the catch which look the door you will see a white switch in the lock and this the defect. the switch is built in the lock.
Jul 20, 2009 | 1997 BMW 328
May 12, 2009 | Heating & Cooling
ERROR CODE C0096 - BIZHUB C350
2.6.19 C0096: Image Transfer Belt pressure/retraction failure
2.6.20 C0098: Fusing Pressure Roller pressure/retraction failure
Relevant Electrical Parts
1st Image Transfer Retraction Position Sensor (PC12)
1st Image Transfer Pressure/Retraction Motor (M11)
Control Board (PWB-MC)
Step Action
WIRING DIAGRAM
Control Signal
Location
(Electrical
Component)
Check the M11 connector for proper connection
and correct as necessary.
2 PC12 I/O check PWB-MC PJ3MC-6B (ON) 6-B
M11 operation check PWB-MC PJ5MC-1~4
(Pulse Output)
6-C
4 Change PWB-MC
Feb 18, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
GPS Logo
94 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
