Question about Maytag MSD2656G Side by Side Refrigerator
Freezer side works o.k., but refrigerator side is not cool.
The refrigerator side is about 65 F, independent of the "refrigerator temp setting." Is this problem due to the "adaptive defrost" or what. I saw some ice in the air slots at the top/back of the freezer. I knocked this off, but it made no difference. Your suggestion will be greatly appreciated.
  • r5w11 Jun 06, 2008
    Yes! The "adaptive defrost control" (ADC) was bad. This was replaced and everything now works fine. It appears that the ADC is prone to failure.
  • r5w11 Jun 08, 2008
    Thanks very much for your "on-target" response!
    Scholar:
  • 110 Answers
IF THE FRESH FOOD SIDE IS RUNNIG HIGH TEMP AND THE FREEZER SIDE IS O.K YOU PROBABLY DO HAVE A BAD ADC. BUT THIS CAN ALSO BE A BAD DAMPER ASSEMBLY. IF YOU CAN NOT DETERMINE WHICH IT IS ORDER THEM BOTH THE DAMPER COMES AS A ENTIRE HOUSING AND RANGES FROM 22.00 WHOLESALE TO 60 BUCKS RETAIL. IN MOST CASES IT THE ADC I CHANGE ABOUT 5 TO 9 A MONTH HERE IN B'HAM AL
Posted on Jun 01, 2008
Freezer side cold, other side not cold, temp settings ok set to 33f
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 10, 2010 | Frigidaire FRS-26DR7D Side by Side...
FRESH FOOD SECTION OF SIDE BY SIDE FRIDGE NOT COOLING ENOUGH. TEMP SET @ 9. FREEZER SECTION WORKING FINE
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
heatman101
Sep 20, 2010 | Hotpoint HSS25GFP Side by Side...
Freezer side is working normal. Refrig. is not cooling .temp set is on more cool side. I cleaned condenser. Light bulb off during closing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Sep 08, 2010 | Kenmore Refrigerators
I have a GE side by side Fridg.that is approx 7-8yrs old.The freezer side is working fine but the fridg. side is not cooling. staying at about 50 degrees just barely cool.. This seemed to happened...
Setting the cooling setting up all the way will not help at all.Make sure your freezer and refrigerator controls are about the same setting. Temp. settings for refrigerator should be between 38-42.degree at medium.. Freezer about 0 to -10.If it is a simple fix this will help.
Feb 20, 2010 | GE GSS20IEP Side by Side Refrigerator
Model FRS26ZRF, the freezer side is cooling down
It could be the defrost system? When you allowed to thaw, did you check the evaporator? It could be frozen? It will take longer to thaw. Is the evaporator fan working? It and the compressor will not, when the box is in defrost. Is your defrost working? Are your door gaskets sealing properly? Are your doors aligned properly? Some things to check. Good luck.
Jul 13, 2009 | Refrigerators
The refrigerator side of my kenmore refrigerator does not cool
Make sure the evaporator fan is operating. Since the fresh food side is cooled by the air flow from the freezer side. Check for blockage of the air duct from the freezer to the fresh food side. Set the temp control half way. Over adjusting this setting can cause problems with cooling. If I can help you any farther, let me know.
Nov 12, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Oct 08, 2008 | GE Hotpoint Top-Freezer Refrigerator
Maytag MSD2656G Side by Side Refrigerator Logo
89 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
