Question about Euro-Pro Sewing Machines
Zigzag stitch not right.
I can not get the zigzag stitch to do right ( on any settings), it seems to skip the zigzag, and the bottom of fabric has straight line, and no zigzag. i have had the machine for about 1-2 years, and i am tired of not being able to use that stitch!
  • crochetmommy Jun 01, 2008
    on the manual says the model is 385w. i am pretty sure it is what you call a front load bobbin.
  • crochetmommy Jun 02, 2008
    My mother bought it from fingerhut for a christmas, and i use it off and on, and i just started using it alot recently.
  • Euro-Pro Master
  • 1,388 Answers
This is an issue entirely related to the timing of the hook to the needle.
What model is your machine, top loading or front loading bobbin ?
The correct passage of the hook behind the needle, is generally very similar for either type of bobbin...adjustment requires the ability to disengage the shaft movement tying the top (needle) and bottom (hook) so that each may move separately and the small adjustment be made.
As the needle rises from the lowest position approx 1.2mm, the tip of the hook should be at the point of beginning to pass behind the needle, to pick up the bobbin thread, when in wide zig zag and at the widest and furthest travel of the hook........there is a shallow "groove" in the back of the needle just above the eye to allow a very close pass by the hook as it whizzes around.
If the hook travels clockwise, the furthest needle position is when the ZZ is in the right stitch position, so conversely, if the motion is anti-clockwise, the left needle position is the one to set.
The method of releasing the two shafts from each other will depend on the machine model, typically there are grub screws on the bottom shaft near the drive belt, or connected to the handwheel at the top........generally 2 screws at 60 degree offset in either case.
Re-timing is not especially difficult, but does require knowledge of the screws to aim for, hence the model is necessary info.....
...If you want any more help with this, just post back here with a photo of the machine (< 150kb) , or, drop a line through the "Contact Us" page at www.bargainbox.com.au and remind me of the posting.
Posted on Jun 01, 2008
  • Hassy
    Hassy Jun 02, 2008
    I cannot find a reference for this model, nor an image via google search.........but.......... if it has a 2 piece moulded case, the setting of the timing will probably require it to come apart and this is not recommended for home users. There are numerous hidden screws with these cases and the locating clips are easily broken.
    Can you discuss the issues with the dealer you bought it from and arrange to take the machine in for them to look at...with some samples of the troubles you describe..they may be able to suggest a local remedy that will not be too costly.
    Am sorry to say, but feel I ought to mention that if this has been ongoing since before the expiry of the 12 mth warantee, you really ought to have been in touch with them earlier, as there is no longer a contract with them for free repair after the 12 mths expire........if you have a good ongoing relationship with them and mention that it has been ongoing for some time they may be persuaded to meet you somewhere in the middle as a gesture of good faith.........good customers are a valuable asset, disgruntled or upset customers are not, it really is that simple.
Skipping right side stitch on a zigzag stitch, so when i am running a zigzag stitch when the needle goes through the fabric and comes back up it pulls the stitch back with it ??
check your bobbin and is the needle good and sharp and the proper length.make sure its not bentthe tiniest defectt n a needle can mess up any stitch.
how does it work on regular stitching.
most problems with machines involve.bad needles incorrect threading of bobbin or spool,dirty bobbin,incorrect needle.
it sounds like the needle isnt catching the bobbin thread.
hope this helps
Apr 05, 2017 | Sewing Machines
Singer 6510 3 dial machine - no "S" on stitch length dial selector
Lower numbers moves the fabric further for each time the needle penetrates the fabric. . If you raise the number you will get more stitches per inch which means your fabric is moving more slowly. Try moving the number to different locations for examples. If you are attempting to make something so it will stretch you are probably wanting to use a zigzag stitch. A wide zigzag stitch will allow a longer stretch than a less wide zigzag stitch.
Dec 23, 2014 | Singer 6510 Sewing Machine
Elna 3210 raw-edge zig-zag stitch bunching
Zigzagging on the raw edge of a lightweight fabric will pull up, because the needle is swinging to the right side off the fabric, bet solution is to use the three step zigzag to overcast the raw edge, it looks like a zigzag mad of dots in the stitch icon. Dont know your model well, but its late model so should have this stitch.
Sep 26, 2014 | Elna 3210 Mechanical Sewing Machine
Why is my singer 9015 skipping stitches, particularly on zig zag setting???
There are several possibilities for skipped stitches. A needle that is dull or bent; using a ball point needle when a sharp should be used, such as a woven fabric, the needle is not all the way up in the needle clamp; the needle was not inserted with the flat side in the correct position (unless your bobbin case is on the side of the machine, that's toward the back), or the top thread and or bobbin thread is not threaded correctly.
Sep 13, 2014 | Sewing Machines
Straight stitch works fine, but,on any size zigzag the machine skips stitches
let me ask this,,
have you tried a new needle?
is the needle inserted correctly--if there is a flat side to the needle it should be to the back of the machine & pushed up inside the needle holder as far as it will go
is it the right size needle for the fabric & thread?
if you check all these things & none of these things help then it's possible the cams or gears that do the zigzag stitch could be worn some.which means it needs to be serviced
Sep 08, 2011 | Necchi 3101 Mechanical Sewing Machine
I have been attempting to use the zigzag option on my Brother sewing machine model X57521-001,the zigzag stitching is showing on the underside of the fabric and not at the top of the fabric, so if i am...
Sounds like the needle is not connecting on one side of the zig-zag stitch. Be sure to install a brand new needle as a damaged/worn needle will sometimes skip stitches. Also, check that you are using the correct type of needle for the fabric and thread you are using. (AVOID old or bargain bin threads!) Could also be that your machine is somewhat out of time. Search for sewing machine timing or take it for service.
Nov 15, 2017 | Brother Sewing Machines
I don't have a manual for a Husqvarna 6440 and don't know how to switch from zigzag to straight stitch. Everything else seems to be sewing beautifully and it was on straight stitch when I first tried it. I...
You have 3 knobs/dials on the machine, the top left dials the stitch, the top right sets the length and the bottom right set your width. set it 0 for straight.
Mar 03, 2010 | Sewing Machines
Tension problem using zigzag stitch
Most likely the fabric is too light weight to sustain the thread tension using a wide zig-zag stitch. Tunneling will occur in this case.
Loosening the tension (top & bobbin) could also be beneficial.
Sometimes the machine has a special foot (sometimes called overlock) that will help. However, using something to add more body to the fabric, like a wash-away or tear-away fabric stabilizer to the seam or even adding paper will help limit tunneling. Sometimes heavy starch applied to the seamline before stitching will be helpful.
tunneling when zigzagging Threads Magazine Gatherings Forum Sewing...
zigzag stitch troubleshoot
May 08, 2017 | Kenmore 19233 Computerized Sewing Machine
Sewing Machines Logo
165 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
