Question about Whirlpool Kitchen Ranges
The innermost glass window in the self-cleaning door broke (was in a rental). I ordered and received a replacement window, but am having trouble getting to the inside glass to put it in. I have the oven door apart, with the outside off; still cannot get to the very innermost window....help!
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
:->, yes, I've been in this boat before. You need to remove the latches. Once you remove the latches, two screws on one end, a lever slot on other, then the rest will be cake. Hope this helps,
Posted on Oct 12, 2010
Why are there brown/white streaks inside oven door glass after using self cleaner 1 time?
Thank you for your post, friend!
From my understanding after you used the self-clean feature on your Frigidaire range you now have brown and white streaks on the indoor glass. Typically streaks can be removed by cleaning the interior glass. Normally it is recommended to have a professional clean the inside glass but a consumer can do it as well. Use caution when following the steps some pieces can have sharp edges. You will need to have a Phillips head screwdriver or small quad bit driver.
A. Refer to owners guide for instructions on how to remove oven door.
B. With door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner.
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
Hopefully this is helpful. -Matt
Aug 23, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
On my frigidaire gallery series oven, how do you clean the glass of the oven door window (between the inside and outside)?
Below are instructions on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: good Phillips head screwdriver or small quad bit driver.
Aug 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
The glass front broke off from the screws holding it to the door-how to fix??
You just have to order the front glass and when you order from us, with this part will come instructions on how to remove and replace it.
You may contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
We look forward to getting you cooking again. :>)
Nov 07, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cracked see through glass -Frigidaire Gas Self Cleaning Wall Oven
Hi, You can replace the glass piece. You will need the whole model # when you call for the part.
Good luck. Please let me know if I can assist you further.
Thanks
Vic
May 30, 2009 | GE JTP86 Electric Double Oven
Oven cleaning
1) take oven door off (position door fully open, flip forward the 2 jammer levers on the hinges, raise door 1/2 open until hinge springs are relieved by jammers, gently ease out door)
2) at the bottom of the door there are 3 screws on left and 3 on right. Remove the innermost screw on left and innermost on right.
3) ease open the glass front by pivoting on the top of the door, separating the bottom that you have just released by removing the 2 screws.
Written by a Chartered Accountant who has current first hand experience of the FEA0614 door
Apr 11, 2009 | Jenn-Air JJW8230D Electric Double Oven
Whirlpool under counter oven, inside glass door broke.
To get to the glass on the inside of the door you need to do the steps listed.
1. Open door 4" and pull straight up at that angle
2. Lay door on flat surface with the handle down to surface.
3. Remove all screws that you see .
4. The inner housing should be removable now.
Then you should see the glass. Reverse the steps to put back together.
Good Luck with the fix.
Dec 17, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
95 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
