How to plug in a componet to tv - Audio Players & Recorders
  • 3,866 Answers
Is it a reciever?
A componet usually uses HDMI, Composit, Optical, ETC
1. let me know witch your talking about
Posted on Oct 12, 2010
I can't get no picture when i plug up my
Try setting the T.V. to a different channel or display setting. You can do this by just pushing the channel up button or pushing the input button
Jan 18, 2012 | Televison & Video
I have a toshiba rear projection tv 40inch model no 40pw13p, does anyone know how i connect the xbox 360 as i cant get any av channels up?
Hello:The xbox came with an audio and video cable, probably componet cables on one end, if you are going to use HDTV input which is the red/grn/blue cables on the end of you xbox plug them into the corresponding color in the back of the tv, also on your cable is a switch labeled HTDT and TV make sure the switch is in the HDTV mode if you are going to connect the componet cables if you are going to use regular video then make sure its in the other posistion. If you use componet cables you are going to use the red an white audio cables also a total of five cables should be connected to the TV. Some newer xboxs have hdmi output as well this is the better of the three connections as it also has audio and hd all on one cable. using your tv's remote switch the tv's input to the same input you connected your xbox to. HAPPY GAMING..
Sep 29, 2011 | Televison & Video
Hello my Phillips 42" model
HI:
Check your componet connections to the TV, Componet cables use green,red, blue and red and white for audio, check the green cable go see if it came loose, because if it is the picture will be B
&W.
May 23, 2011 | Philips 42PF9630A 42 in. Plasma Television
I am attempting to use my sennheiser rs 110 headphones with my lcd-led tv. the componet jacks coming out of the transmitter are red and black. All my componets on the tv are red and white. so when i plug...
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Mar 10, 2011 | Sennheiser RS 110 Consumer Headphones
Toshiba dvd when plugged to componet to tv picture balck and white... The picture is fine when plugged to composite or s-video... Component from sat box plugged to tv works fine too..
Sounds like either the cables you are using are bad or the component out on the dvd player is bad. Try using a different set of cables and make sure there are no loose connections on the dvd player
Aug 21, 2009 | Televison & Video
Configuring the componet out ?
u can buy a converter for output to configuring the tv. the converter is to connect the cables output to the player.
Dec 24, 2008 | Onkyo TX-NR801 Receiver
Ilo 26 inch tv
I am sorry, Thats the one manufacturer that I diont have any experience with. although I would quess that its a signal processor that may be at fault being that you cant switch inputs.I would try to resubmitt your request to one of the other experts that may be famillar with that manufacturer.
Jun 08, 2008 | iLO 2600 Television
Cabling -- Panasonic LCD TV into LG DVD player (model no. DV6812P)
Take the basic Red, White, Yellow component cable -- plug it into the backside of the DVD player and plug the other side into the back of the t.v. Make sure to plug the right colors into the right sockets. If there are no available AV inputs on the back of the t.v, plug the other end into your cable box (if you have one).
Mar 03, 2008 | Televison & Video
Grey Screen
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
Jun 23, 2007 | Sanyo DS32224 TV
15 people viewed this question
 Grubhead
Grubhead
