Question about Kenmore Front Load Washer
The machine will not spin the sheets, they are soaking wet
  • Kenmore Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Oct 12, 2010
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Soaking wet clothes after spin cycle
Check and choose a longer spin cycle and see if the fault changes. If so the SPIN cycle is too less or there is less action or speed in the cycle, check the motor speed, check the capacitor to the motor, the spindle friction - if so reset the spindle and drive.
Jan 17, 2013 | Washing Machines
Washing machine does not spin well and leaves the clothes soaking wet
Likely a bad belt or tensioner causing it to slip. Take it apart and look to see what the belt is doing or call a repair man.
Apr 22, 2012 | Whirlpool Washing Machines
Clothes are soaking wet after washer is done
maybe your clutch is slipping not getting full spin speed,,,,or could be a problem with your basket drive assy
Feb 21, 2010 | Whirlpool LSB6200KQ Top Load Washer
My clothes are soak and wet after the spinning cycle ends
Could be a gearcase problem or a motor coupler problem or a clutch problem .Best off to call a reputable service company such as Sears.
Feb 06, 2010 | Washing Machines
Spins but is soaking wet
There is something impeding the outlet of water. Could be a pipe blocked, a pump filter needs cleaning, the spigot, the point at which the washing machine drain hose connects to the sink, is blocked. Definitly caused by,'slow' release of water.
Apr 04, 2009 | Washing Machines
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Washer will turn on but will not spin
ck door switch had one today tech sheet if needed is behind bottom panel left side wall in envelope if gives test procedure ..switch most likely but still could be control bd issue
Jul 31, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore Front Load Washer Logo
41 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
