Question about NetGear FS608 Networking Switch
I have 2 computers connected but only one is working and the second one is working erratically
  • NetGear Master
  • 7,733 Answers
Is not a Net Gear problem as i guess is a OS problem.
Posted on Oct 12, 2010
Transmission hard shifting between first an second gear only when this happens the tachometer goes erratic
You have a engine RPM sensor that is not working correctly. Computer thinks you have push gas pedal to the floor and is providing that type of shift. It may be the sensor attached to your gas pedal has worn out.
Apr 14, 2015 | Acura TL Cars & Trucks
Hot weather auto transmission shifting problem
Often this kind of problem it is caused from faulty throttle position sensor, you find out by connecting a code reader to your car computer.
throttle position sensor tells to your transmission control module how you are using the throttle, so that the car automatic transmission can shift to right gear, when this is faulty often you have transmission faults related to engine rpms and temperature, this can explain a trans problem happening only when engine is hot.
In some case it is not the sensor, but the computer module controlling transmission that is faulty.
To find out cause for the problem you need to connect a code reader to transmission module and to main computer module (ECU).
The code reader will return fault codes that allow to locate the problem. this kind of job can be done at any qualified garage.
Aug 16, 2008 | 1993 Toyota Camry V6
I have a read screen on my 2001 Jaguar S- Type that says " Fail Safe Engine Mode. What does it mean
Hi, fail safe engine mode means that the ECM (Electronic control module) or computer box as some know it, is running in a mode whereby it is bypassing a particular component in the engine that has gone faulty in order to keep the car from cutting out, or has picked up an erratic function in any component, which is more than likely an electrical problem and could be one of the following which have to be checked by computer analysis equipment at the Jaguar agents or any one else that is familiar with the process that is required to trace the fault. Here are the possible causes: 1.Erratic wire connection 2, Engine cooling Fan thermal switch. 3. Control module 4. CKP sensor 5. Computer box not functioning correctly (a rare fault) 6.Engine coolant fan not working, or running erratically. Unfortunately only a computer analyis will depict the location of the fault and if the repair man is very experienced will be able to sort it out quickly with the computer analysis.( Although I strongly suspect it to be the cooling fan thermal switch which is working erratically and will soon fail completely.)
So get your car to the experts as soon as possible especially if it could be the cooling fan thermal switch, which could cost you a major expensive engine repair job if your Jaguar overheats.
Have a good day.
Oct 02, 2014 | 2001 Jaguar S-Type
Dynex blu-ray wi-fi disconnects after 1 hour
The issue is with the chip that works with the wi fi. It is erratic in operation. Too expensive to fix. Can you just hook it up via ethernet cable for internet connection?
Sep 07, 2017 | Dynex™ Televison & Video
Drive no longer powers up
easiest thing to try is a new usb cable could be that simple. try that and let me know the results
May 20, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hp 250 GB Pocket Media drive having erratic behaviour under Windows 7 (Motherboard ECS G41chipset), Under windows XP front and back USB ports recognize disk as USB 2.0 device - able to read and...
XP is a dead OS.
100% dead. and not supported now. by MS or HP.
but XP needs SP3, or USB will be bad
XP always had bad USB for years until , all patches were done.
The USB on XP are horrible.
you need good USB so all devices are PnP recognized
and negotiated currents (power) is working
and USB2 currents are weaker than USB 3.
and is key to making any motor driven HDD work right.!!
Dead as a door nail and no more security patches ever again.445635a4-18b0-42a5-a249-084bb91c84b0.jpg
Apr 04, 2017 | HP 250GB Pocket Media Drive 250 GB Hard...
I have a 2004 Honda vtx 1300c and the speedometer quit working. I checked the battery connections and the fuse and they are fine. All the other lights and the odometer on the dash work. The speedometer...
its the speed sensor The Speedo sensor has a little plastic coupler that is driven off the hex head of the bolt that holds your countershaft sprocket on. If the countershaft sprocket bolt has backed off,it could've damaged that coupler. Or the plastic coupler has simply stripped out from working against that steel bolt head. Unbolt the Speedo sensor(it's just two little bolts)and remove it,see if the hex shape of the coupler is rounded out,or if the hex shape of the sprocket bolt is rounded. Either of these could give you erratic readings. If the bolts that hold the countershaft sprocket cover are loose,or the bolts that secure the Speedo sensor are loose,these too could cause an erratic Speedometer reading.
Jun 14, 2011 | 2005 Honda VTX 1300 R
Has anyone found a fix (short of getting rid of) for Logitech MX 600 Laser Mouse pointer erratic operation?? Seems to work OK on a Flat smooth surface, but jumps all over the place on any mouse pad I have...
  1. Mouse is not clean.
  2. Optical portion of mouse is blocked.
  3. Moisture or other material on finger.
Mouse is not clean Users who have an optical mechanical mouse (most common mouse for desktop computers) are likely experiencing erratic behavior because the mouse is not clean or is dirty. Optical portion of mouse is blocked
Users who have an optical mouse are likely experiencing erratic behavior because a portion of the optical eye is blocked. Most commonly this is caused by a hair.
Moisture or other material on finger Users who are using a touchpad may experience erratic behavior because of moisture or other material on the finger such as lotion.
Mouse has been cleaned and still has problems If you've cleaned the mouse and continue to encounter issues and this mouse has worked in the past fine unfortunately your mouse is likely defective. One additional test that can be done to help determine if this is the case or not is to connect the mouse to another computer. Otherwise we suggest replacing the mouse.
Oct 24, 2008 | Computers & Internet
Erratic display
it sounds like a blown cap.. you can replace it if you know how to soder
Jun 11, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Service code EC?
CODE INDICATION
05 Refrig. Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
06 Refrig. Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
07 Freezer Cabinet Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
08 Freezer Evaporator Thermistor read open or shorted for 10+ seconds, or repeatedly read erratic temp’s
20 Defrost Under-heat with No Voltage Feedback Through Gray/White Wire at Defrost Start
21 Defrost Overheat
22 No Voltage Feedback Through Gray/White Wire at Defrost Start
23 Defrost Overheat with No Voltage Feedback through Gray/White Wire at Defrost Start
24 Defrost Under-heat
30 Excessive Icemaker Water Valve Solenoid Activation (Exceeded 15 Seconds)
40 Excessive Freezer Compressor Run
50 Excessive Refrigerator Compressor Run
Jan 21, 2008 | Sub-Zero 632 / S
NetGear FS608 Networking Switch Logo
113 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
