Question about Whirlpool LGR5636L Gas Dryer
Burner wont light no heat , changed ignitor but still not working.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Is ignitor getting white hot? Look at it and see if it glows. If it does then that part of operation is probably working fine. There are two black valve coils on the gas valve that sometimes go bad. If you have a meter then I believe they should read 1-2 KOhms. ...can't remember. If you don't have a meter then I'd replace both of the coils (shotgun) and see if that fixes it. Hope this helps,
Posted on Oct 12, 2010
Oven wont light up but igniter is glowing and top burners are working good
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Mar 05, 2011 | Ovens
Oven "bake" burner wont ignite on a gas oven.
Oven not Working or Oven not Heating
heatman101
Dec 27, 2010 | Whirlpool Ovens
Pilot light lights but burner wont in gas oven
heatman101
ssg
Sep 30, 2010 | Tappan TGF320 Gas Kitchen Range
Hot point oven wont light ,ignitor glows but seems like no gas.top burners work
heatman101
Jun 04, 2010 | Hotpoint RGB528 Gas Kitchen Range
Burners work oven wont light
heatman101
dhdg
May 15, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
heatman101
fjf
Mar 28, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Ive got a tappan gas oven that wont light. The stove top burners light, but the oven or broiler wont. There is a ''glow plug'' that turns orange but the gas never ignites. What is wrong?
heatman101
gfgshg
Mar 13, 2010 | Tappan TGF320 Gas Kitchen Range
heatman101
ssgs
Feb 25, 2010 | Tappan TGF320 Gas Kitchen Range
Burners sometimes will not light
You can check the ignitors/wiring by switching
the output wires at the spark module. If the
front ones work & back ones stop working, change
out the module. If no change take a look at the
ignitor(remove screw on bottom to remove
ignitor), ignitor wire & ground wire by removing
the burners.
Possible Causes Of Continuous Sparking:
Defective spark wires.
Continuous high heat can cause spark wires to
degrade. Use volt/ohm meter to determine
continuity
of spark wires. Look for obvious cuts/ abrasions
or pinch points. A defective wire can allow
spark voltage to transfer through insulation to
ground prior to reaching spark electrode. Under
normal circumstances all igniters fi re together
and if the burner in question has found an
easier
ground path the spark will go there. It will
not, however, in most cases have found a
CONTINUOUS
ground path such as what the fl ame would
provide under normal circumstances. This will
cause
the spark module to re-ignite.
Sep 01, 2009 | Viking VGIC485-6G Gas Kitchen Range
Kenmore oven wont light
I am not sure what model or make you have to be precise but replacing the oven ignitor is relatively simple. Gain access to the bake burner area. There are two mounting screws which secure the old ignitor to the bake burner. Remove these screws and then follow the wires to their respective connections. Make the connection change and mount your new ignitor. If I can help further, I am here...
Waiting to hear from you,
Eric Campion
Feb 13, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Whirlpool LGR5636L Gas Dryer Logo
57 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
