Question about Panasonic DMC-FX07 Digital Camera
Unresponsive buttons because of engaged zoom
When i turn my DMC-FX07 on it immediatly begins zooming in to maximum zoom, 3.6 times. It is unresponsive to everything but the mode select wheel and the on/off switch. I can put it in review mode but cant look at any other pictures except the very last one i took using the camara. In any mode except review the zoom bar displaying the fact that it is zoomed in to 3.6 times normal does not disappear like it usually does when i am done adjusting the zoom level. I have removed the battery, turned it on and off a couple times but nothing has changed its condition so far.
Thanks for any advice
Kit
  • 3 more comments
  • Anonymous Oct 20, 2008
    It Does The Same With My Camera I Have No Control Over What It Is Doing!
  • Anonymous Nov 06, 2008
    same problem as above.
    how do i get the zoom button replaced?
  • Anonymous Nov 28, 2008
    Looks like many have reported the same issue. I don;t agree witht eh solution posted. I don;t see anything about the zoom on my LCD. No workaround seems to work. This camera is a faulty one by panasonic. Never buying a panasonic again.
  • rhodus Dec 25, 2008
    i do have the same problem, turn it on and goes directly to zoom out. Then it is blocked and can not get into menu...
    what to do?
  • Anonymous May 06, 2009
    I have the same problem too! this is frustrating! i took such good care of this camera.
  • 95 Answers
The reason why the lens zooms out is because the zoom switch is faulty and might need replacing.The way to tell this is when you switch it on in camera mode you will see the zoom bar displays on the lcd and stays there.
Posted on Jun 02, 2008
Faulty zoom operation
This is normal. If you hold the zoom for an extended time the lens is slower than the indicated zoom. Forcing the lens to continue to its zoomed direction.
Apr 14, 2014 | Panasonic Lumix DMC-FZ18 Digital Camera
Hi, I have a DMC-FX30. When i turn the zoom
mera Digital Camera Hi, I have a DMC-FX30. When i turn the zoom Answer Failed: retry Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be... (More) (More) Hi, I have a DMC-FX30. When i turn the zoom swithc it is stiff and goes to full zoom and cannot be stopped - only when i switch the camera off. Can you help?
Feb 11, 2010 | Panasonic Lumix DMC-FZ28 Digital Camera
Camera will not retract nor function
It sounds like you will have to have the camera repaired. You don't necessarily need to drop it, as they can malfunction on their own. Before having the device serviced, try checking out the user manual for more explanation on this issue:
Panasonic DMC FX07 manual
Dec 03, 2008 | Panasonic DMC-FX07 Digital Camera
I have a lumix DMC-F27 camera it will no longer zoom. No I not in movie mode.
Do you mean DMC-FZ7?
I own one. Assuming that the camera is working normally, then I know two settings that will cause the zoom to be fixed.
Suggestion No. 1:
If the zoom is fixed at the wide end:
1. Turn the mode dial to "P". Now turn on the camera.
2. Press "MENU SET".
3. Press the up arrow button.
4. Now, a menu item named "CONVERSION" should be highlighted. Press the right arrow button.
5. A sub-menu screen should now pop up, select and set "OFF".
Suggestion No. 2:
If the zoom is fixed at the telephoto end:
1. Follow Suggestion No.1.
Suggestion No. 3:
If none of the above solve the problem, then the lens might have been knocked slightly out of position.
~If the camera has been dropped.
~If the camera has been thumped or banged.
~If while zooming, the lens was obstructed.
The zoom motor also could have died, it costs about $50.00 U.S. at Panasonic.com.
My best advice would be to contact panasonic customer service.
Jul 19, 2008 | Cameras
The Zoom Does Not Work
search dmc-fx07 on ebay lcd screen cracked lumix whole camera goes for about 20 bucks ... replace top side internals ... pretty simple :)
Jun 20, 2008 | Panasonic DMC-FX07 Digital Camera
How do I download pictures without the software
you can download your pictures just like a normal file connect your camera to your computers usb port using the usb cable and just transfer the files to your computer...
Jun 18, 2008 | Panasonic DMC-FX07 Digital Camera
Camera that keeps shutting off
Hey layneD,
What is most likely going on is that something stuck in the lens obstructing its movement (i.e. a piece of sand), or the lens has moved out of alignment. You could try removing the batteries and waiting a minute and then reinserting them. Another option you could try is putting the camera on a flat surface with the lens pointed upwards, and then hold the shutter button down and while doing this turn the camera on. One more thing you could try is blowing compressed air into the lens to try to dislodge anything that might be stuck in the lens. If none of these options work I would have it looked at by an authorized service technician such as bringing it to a Geek Squad® precinct at a Best Buy™ store and they can send it out for service. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 26, 2008 | Panasonic DMC-FX07 Digital Camera
Zoom broke
Solution: Procedure for setting Digital Zoom PowerShot A520
Digital Zoom When the LCD monitor is on, images can be zoomed with the combined optical and digital zoom functions as follows (figures are approximate): 5.7 times, 7.1 times, 8.9 times, 11 times, and 14 times 1. Press the <DISP.> button to turn the LCD monitor on.
2. Turn the shooting mode dial to any Shooting mode except for stitch_assist_icon_a70.gifor movie_icon_a70.gif.
3. In the [ rec_icon.gif(Rec.)] menu, select digital_zoom_icon_a70.gif(Digital Zoom).
digital_zoom_menu.gif 4. Select [On] using the left_arrow.gifor right_arrow.gifbutton and press the <MENU> button.
5. Press the zoom lever toward tele_icon_a70.gifand hold it.
  • The lens will zoom to the maximum optical telephoto setting and stop. Release the lever and press it toward tele_icon_a70.gifagain to further zoom the image digitally.
  • Press the lever toward wide_icon_a70.gifto zoom back out.
digital_zoom_lcd_a70.gif 6. Shoot the image.
  • Shooting procedures are the same as for the auto_mode_icon_a70.gifmode.
  • The digital zoom cannot be used when the LCD monitor is off.
  • images become coarser the more they are digitally zoomed.
  • Since camera shake may become a factor when using the digital zoom, the use of a tripod is recommended.
  • Digital Zoom is disabled when the [Postcard Print Mode] is selected as a image quality setting.
IF this fails, your camera is in need of service.
Dec 30, 2007 | Canon PowerShot A520 Digital Camera
Camera Frozen
I tried Option No.1 successfully when my Panasonic DMC-FZ7K froze once:
Option No1:
1. Try turning the camera on with the battery inserted.
2. Now remove the battery while the camera is on.
3. Flip the switch on the camera to off, then insert a fully charged battery. (Make sure that the battery's orientation is correct. Also make sure that the battery being used is not damaged).
4. Now flip the camera's switch to ON again.
Option No. 2:
If you can open the Setup menu then the camera can be reset which might help:
Turn on the camera.
1. Press MENU SET.
2. Press the left arrow button.
3. Press the down arrow button.
4. Press the right arrow button.
5. Now, press the up arrow button several times until the menu item named RESET is highlighted. Push the right arrow button and then select and set YES when the camera asks to be reset.
Oct 18, 2007 | Panasonic DMC-FX07 Digital Camera
When using the zoom button the cam stops working
This suggests the zoom motor has failed. As you only purchased it 2 weeks ago - it should be replaced under warranty
Aug 21, 2007 | Panasonic Lumix DMC-FX50 Digital Camera
Panasonic DMC-FX07 Digital Camera Logo
327 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
