Question about Whirlpool and Maytag Washer Accessory
Whirlpool LSC900PW2 washer not draining water
Master_Tech
  • 770 Answers
SOURCE: Whirlpool Calypso Washer no draining
Did you get the tests done??
Posted on Jan 27, 2008
  • 1073 Answers
SOURCE: whirlpool washer ultimate care
check for problem with the pump it is coupled to the motor, if it is spinning then it should also be pumping out the water
Posted on Apr 23, 2008
jsrock516
  • 5911 Answers
SOURCE: Drain problem
If there's water in the drain line this is normal. There is roughly about a half a gallon of residual water that remains under the wash basket, drain line and drain pump combined. That's why it is important to leave the washer door open when not in use to allow the tub to air out. It will not evaporate the water, but will help reduce the build up of mold, mildew, and odors.
Now, if you look inside the wash tub and see standing water, then you may have some drain line issues. Make sure your drain line does not exceed 10 feet in length. Excessive lengths can cause backwash. Also, make sure the standpipe at the wall is at least two inches in diameter, a minimum of 34 inches from the floor and does not exceed a height of 72 inches. All these conditions can cause slow drain problems and/or backwash.
I hope this answers your question and that you find this helpful. Please post back if you need further assistance.
PS Make sure the standpipe is draining properly. It should be capable of draining approximately 17 gallons per minute.
Posted on May 28, 2008
SOURCE: My Whirlpool washer won't agitate or spin . But it does drain the water.
i also had the same problem, and it ended up being the coupler. It was not hard to replace, it cost me about 19.00. I didn't follow full recomende instructions. I tipped the washer backwards. Removed the drain pump and the motor itself. Then I removed the old coupling and placed the new one. The washer is working like new...
Posted on Jun 02, 2009
blueextc3221
  • 15935 Answers
SOURCE: My Whirlpool Duet washer does not drain. is it
It appears your pump has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have a whirlpool ultimate care II washer. When I start the washer, water pours in but does not fill up the washer. The water immediately drains away. Its not leaking out of the washer. I think the...
This issue calls siphoning effect. It happens when the drain hose was somehow lower or not stand vertically. It causes no air pressure column in the drain hose to keep the water out. Check the drain hose and make sure it is high enough. Try to hold the drain hose straight up and see if it is happened before having further inspection.
Oct 05, 2013 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool washer seems to be letting water back flow from the drain line.
sounds like the drain line is too low it needs to be higher than the water level when running a full load...you can check this buy filling with water and stoping the cycle and see where the water stops draining im sure it will stop at the level of your drain line in the back of the washer. the drain line in the back of your washer should come out of the bottom of the washer and then go up to a drain pipe..if its lower than the full water level of the washer then gravity will take over and drain the water... i hope this helps
Sep 09, 2011 | Whirlpool Estate TAWS750PQ 27-Inch Washer
I have A WhirlPool Cabrio.. when i start a load.. it flashes "FL' and beeps excessively.. how can i fix and prevent that?
Fl code indicates an overfill condition. If the washer is empty, then you likely have a problem with the water level pressure switch. If the washer is full of water and will not drain, you likely have a problem with the drain pump or the washer drain line.
If the washer is full of water, make sure that the washer drain is clear and working properly. Check the drain hose for kinks or clogs. If you find no problems with these issues, I recommend that you manually drain the washer using a wet/dry shop vacuum. Check the drain pump and connecting hoses for problems. You may need to replace the drain pump of water will drain out of the washer properly but the pump will not work properly. A clog in the check ball assembly at the bottom of the tub can also prevent the washer from draining properly.
Feb 20, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Water drains back through the fill lines.
THE COLD AND HOT WATER CANT GO BACK IN TO THE WATER VALVE ! NOW IF THE DRAIN WATER COMES BACK IN AFTER DRAIN MODE LEFT DRAIN HOSE UP A FOOT TALLER THIN THE WASHER OR CLEAN YOUR PUMP THIRS A CAP ON THE PUMP YOU CAN REMOVE TO CLEAN . NOW IF THE WASHE IS FILLING UP WITH WATER WHEN ITS OFF THE WATER VALVE IS BAD
Apr 03, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washer - tub drains while it fills.
Your drain is to low. Make sure that the drain that your discharge hose is going into is at least as high as the washer. If not the water will drain out as fast as you can fill it.
Aug 15, 2009 | Whirlpool Washing Machines
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Laundry comes out very wet
Hello tcburns07,
If possible, can you cycle a very small load of wash ( perhaps a towel or two) on the lowest setting to validate that : the washer is spiining up to normal speeds while draining water and that the water being drained is complete? Chancves are you have a either a blocked filter that limits water from completely draining, something in the drain pump or a restriction in your drain system. You could also have a worn belt that drives the pump. The test I suggested will at least determine if your washer is capable of draining all of the water from even a small wash load. Try that and let me know the results.
Regards,
Rick
Nov 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool and Maytag Washer Accessory Logo
57 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
