Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Kenmore fridge106.56546400, icemaker shute leaks
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 113 Answers
Most likely the chute is not closing all the way. Warm air enters and melts some ice and drips. You'll eventually get a frost buildup there if not already. Order a ice door kit. Get a flashlight and look at the chute door real good for a partial closure for verification.
Posted on Oct 12, 2010
How to fix a kenmore ice maker leaking water
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
Feb 20, 2015 | Kenmore Refrigerators
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
I have a Kenmore Coldspot Model #78187891, with a leaky icemaker problem. The icemaker seems to leak near the front of the icemaker (closes to freezer door) and makes these stalactite structures. This...
Most likely ice maker is the problem and would need replacing. Water valve is letting to much water in but the amount of time solenoid stays open is controlled by the ice maker
Sep 28, 2017 | Kenmore Refrigerators
Kenmore freezer not making ice
Pour about 1/2 cup of water into icemaker ( unless ice is already there ) . If the icemaker dumps the cubes , then the water valve is bad . If it doesn't dump , and holds the frozen cubes , replace the icemaker . Also check your coils to make sure they are clean from dust , lint , etc . Check the fill tube going to the icemaker , to make sure it isn't frozen with ice . If it is , then watervalve is still bad (leaking ) .
Aug 25, 2009 | Kenmore Freezers
My Kenmore side by side refrigerator model 106.5686*601 is leaking water from the ice maker inside the freezer.
Icemaker leaks are common and cannot always be solved. May need a new Icemaker. Ofter you can obtain a kit from Lowes (use a Whirlpool kit.)
Aug 23, 2009 | Kenmore Refrigerators
Icemaker leaking causing icicles
Is it overfilling with water? If so, it may be an problem with the fill valve leaking slightly. I say slightly because if it were a large leak, the freezer would have frozen puddles in it. Also check the water chute to be sure the water is all going into the freeze tray. Sometimes they can work loose.
If the seam is leaking, there could be a crack in the housing - not sure that's repairable - sometimes epoxy will work (5 minute, 2 part) but it can be difficult for glue to hold on the type of plastic used in an ise maker housing.
Mar 27, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Refrig 51562 Side By Side; Icemaker leaks water underneat
you are going to have to replacwe the solinoid valve for the icemaker mbecause its leaking by
Feb 25, 2009 | Kenmore 51562 / 51564 / 51569
Fridge Leaking
the icemaker can overfill causing water to run over into the freezer
the fill cup on the back of the icemaker could be frozen letting the water overflow into the freezer
if the fill cup is not frozen then you need a modlue for the ice maker if it is whirlpool built, if ge or frigidaire design then replace the icemaker
May 07, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker leaking water
replace the icemaker fill switch in the icemaker its self its a micro switch behind the gold panel on the front of the icemaker
May 03, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
175 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
