Question about Sony KP-51HW40 51" Rear Projection Television
Are you sure?
You sure its the flyback? cuz i see a lot of stuff about the blue crt. Was it the eight blinks that pinpointed it?
  • Justin
    Justin Jun 01, 2008
    awesome. that link you sent doesnt show my particular model number that goes along with flyback no. ....8521. is that more of a universal flyback?
  • Anonymous Aug 06, 2008
    I have the same problem screen is blue then goes black and red light blinks 8 times. Has anyone found the flyback and did it fix the problem
  • Sony Master
  • 8,617 Answers
Thats what 8 blinks indicates for that model means T8005 is defective and T8005 is the flyback, you may very well have a bad blue CRT as well but the 8 Blink error code is definately the flyback and the flyback going out could have raised heat voltage to the CRT and that in itself could cause the Blue CRt to flash.
Posted on Jun 01, 2008
  • Sonny Berry
    Sonny Berry Jun 01, 2008
    you have the Same chassis as the HS30 which is a RA-6 sony chassis your model uses that same flyback. they usually only list a few of the models that that paticular Flyback fits as there are probably 200 models with the RA-6 chassis such as you have. but thats the flyback the service manual list for your model.
My sony kp- fx532m91 has trouble in turning on it takes 30 to 60 minutes before it will open/on. and it blinks six time every 3seconds. what could be a possible remedy anyone can help me.
Iam thinking that 6 blinks means power suply make sure all voltages are right according to the board.Could be somthing is pulling down on 5 volt line or12 volt line. If it is a CRT which Iam sure it is then there is 150 volts DC or so for the flyback there is a high voltage block for the high voltage for each gun red blue and green.Check power suply horizontal output high voltage block focus and screen block.
Nov 21, 2013 | Televison & Video
Sony blinking codes
Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board. To get more details, http://electronicshelponline.blogspot.com/
Nov 17, 2013 | Televison & Video
My Sony Bravia KLV32S400A goes off and red light blinks 8 times
Dec 06, 2011 | Sony KV-32S12 32" TV
Sony Trinitrion WEGA starts then stops,then timer light flashes eight times.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
Have you got external loudspeakers that have dodgy wiring? Just a thought.
Jan 15, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
9 blink problem with Sony KP-57ws520. Cost to get fixed anyone?
Nine blinks means that there is a problem in the HV circuit. It could be the flyback, the divider block or a shorted CRT. How old is your unit? How many hours per day do you watch it? If the flyback and divider block are bad it would be about $250 to fix at a reputable shop. Bad CRT and you are looking at $400. Give me more information and I may be able to pinpoint the problem for you.
hardrocko
Jan 26, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500 flashes blue, green, red then turns off
Re-insering the flyback wire is usually very easy. Push in and give a slght turn and check to see if grabbed. It sounds as if there is more issues than flyback wire. TV should turn on without one crt connected
Dec 14, 2009 | Sony KP-57WS500 57" Rear Projection...
Toshiba 32'' tv no power no sound red led in front on and blinks also hearing hissing from flyback model#cx32f60
for sure your tv has power as indicated by your flyback hissing it also indicates leaking high voltage that might destroyed your vertical or any other parts near your flyback ,the flyback itself should be replaced for its high voltage arcing can ruin so many components
Oct 13, 2009 | Toshiba Televison & Video
Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Jul 12, 2008 | Sony KP-51WS500 51" Rear Projection...
My tv is broken
You need a new flyback which is flyback number 145328521 you can get a new replacement fyback at the following link and they also provide free tech support so you can do the repair yourself. Heres the link.
http://servicemanuals.vstore.ca/
Jun 01, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-43HT20
If the flyback is bad, the 135 volts will reach about 70 or 80 volts and the set will shut down, and the LED will blink twice. Usually, for 8 blinks, the high voltage capacitor inisde the splitter is shorted, and an easy test for this is to disconnect the thin gray ground wire, move it away from everything else and turn the set on. The set will now run but the ground wire will hiss like crazy. If you replaced the splitter but the set will not run, try disconnecting the 3 high voltage wires to the CRT's and see if the set runs. If it does, reconnect the high voltage wires one by one until you find which CRT is loading down the high voltage. Let me know how you make out.
Apr 09, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP-51HW40 51" Rear Projection Television Logo
106 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
