That appears " change cartridge invalid refill
  • 3,866 Answers
Ether the cartridge was refilled wroung or there is a issue with the print head, your going to need to take the refilled unit back where it was filled at, if that is not the case then the print head is not reading the cart.
Posted on Oct 12, 2010
5 Suggested Answers
  • 77 Answers
SOURCE: error message "change cartridge invalid refill" the printer wont print anymore
Trying cleaning the contacts on the cartridge and clean the contacts on the printer use a dry tint paper towel to clean the contacts. Then try to reinstall the cartridge using the software. Try to print the self test. If failed try another cartridge if you dont get any error then the cartridge might be defective
Posted on Apr 28, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: lexmark optra t610 invalid refill error change
    The error may not be specifically a toner cartridge problem but may be due to a stuck cover open switch on the printer. Perhaps this article on Error: "Invalid Toner Cartridge" or "Invalid Refill" will be able to determine the root cause of the problem. Just click on this link: http://bit.ly/dupj2m. Just make sure you are using a genuine Lexmark toner in the printer. If you need further assistance, you can also contact Lexmark technical support. Thanks.
    Posted on Sep 14, 2010
    drifterK
    • 4924 Answers
    SOURCE: Purchased refill cartridge from company
    If the printer worked fine with the cartridges for a while ..it means they are compatible ..and this is not the issue..The issue is with the counter needing reset..Just look in the manual ..to see the reset procedure and specially for counters..and they will work ..
    Some printers cane be tricked if you insert another cartridge for a while ..and than put these ones back ..The memory for the cartridge counter is just for the last 2 ..so it will probably see them as new..Also try to remove and put them back ..and see if it is asking to confirm if they are new..If it asks such a thing ..it will reset the counter when the confirming is done ..But .to be sure you have to reset the printer..or use new cartridges..(there are printers that will not reset the counters at all ..and will read the cartridge's chip ..and consider them after the number of copies done already ..This is the reason for needing reset ..
    Posted on Aug 08, 2011
    • 254 Answers
    SOURCE: my lexmark t632 says (
    You have a chip which controls the cartridge.
    Get the chip of the old cartridge and change.
    The chip is on the top right side of teh cartridge.
    Or put a genuine cartridge.
    Posted on Aug 16, 2011
    What to do with 30.05 change "cartridge invalid refill" problem
    Buy Original Lexmark Tonor.
    If you refill tonor, you need a new "Tonor reset chip" - some tonor remaufacture will stock them. Cost less than $2
    Aug 08, 2014 | Lexmark Laser Printers 34S0400 E 360D...
    Cartridges error on a lexmark
    Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
    Solution
    One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
    To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
    If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
    Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
    Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
    Turn the printer off. Doing this will disengage the cover open sensor.
    With the printer switched off, open the top lid and remove the old toner cartridge.
    Now replace the old cartridge with another new Lexmark toner cartridge.
    Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
    If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
    If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
    To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
    If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
    OR
    1 Switch on the Lexmark X83 printer.
    2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
    3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
    4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
    5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
    6 Repeat each step in this procedure again. Close the cartridge door.
    Oct 04, 2012 | Office Equipment & Supplies
    My lexmark t632 says ( change cartridge invalid refill )
    Aug 15, 2011 | Lexmark T632 Laser Printer
    Lexmark optra t610 invalid refill error change cartridge......how do i reset the printer to disable the error
    Sep 14, 2010 | Lexmark Optra T614 Laser Printer
    Change Cartridge Invalid Cartridge
    First, Lexmark does not now or ever support the use of a third party cartridge or a refilled cartridge ink cartridge even if it is a Lexmark cartridge. Lexmark considers this to product tampering.
    That said, please get a new Lexmark cartridge that is designed for your model of printer and see if it works. If you still get the failure, use a lint free slightly dampend cloth to wipe the contacts where the new cartridge goes. If that does not work, call Lexmark Technical support and see if there is still any warranty left on the printer.
    Worst comes to worst, you can just replace the printer given the cost of ink jet printers nowadays.
    Don
    May 29, 2009 | Lexmark T612 4069 Printer
    Error message "change cartridge invalid refill" the printer wont print anymore
    Apr 27, 2009 | Office Equipment & Supplies
    Invalid toner black
    The issue with refills is that sometimes you get a bad one where it will do this. The only solution would be to purchase a genuine cartridge.
    Mar 27, 2009 | Office Equipment & Supplies
    Lexmark error: 33.64
    Change Toner cartridge.
    Do not refill your toner cartridge in the same place anymore ;) Do not refill them like 10 times ;) Use original toners for your MF/Printer
    Maxi
    Feb 18, 2009 | Lexmark All-in-One Printer with PictBridge
    501 people viewed this question
    k24674
    jasbo
    jasbo
