Question about Motorola Mobility H710 Bluetooth Headset
Trying to charge my bluetooth...keeps flashing red and won't charge
    Sergeant:
  • 270 Answers
Most headsets or earpieces come with a charger or a cable. If you are using this, it is possible that your charger is defective.
There are many sites (and walmart) to get a new charger for $15.
Good luck and don't forget to vote.
Posted on Oct 12, 2010
2 Suggested Answers
  • 274 Answers
SOURCE: Bluetooth is plugged into charger
It is charging when the red light flashes.
After it's full, the light will not flash.
electronics wholesale
Posted on Nov 16, 2011
How to get my new Bluetooth set-up
So, what else can I tell you. You yourself have discribed that your headset is defective. So, being a new device, return it to be changed for a new one.
Jun 03, 2014 | Apple Cell Phones
How to pair a ROMAN R6250 Mini Wireless Bluetooth Headset Earphone Headphone to an iPhone 5S
1. Charge the headset:Headset is charged via USB cable, the light will be red when charging. When the battery is fully charged (about 2-3 hours), the red light of the headset will turn off automatically or the red light turns blue.
2. Turn on the headset:Press the on / talk button on the headset for about 5 seconds until the blue and red flashes alternately (or blue flashes or the blue lights all the time ), now the headset is ready to be connected to the iPhone.
3. Go to Settings, and tap Bluetooth. Turn on Bluetooth.
iPhone will automatically start searching for Bluetooth devices. Tap the device in the Devices list, then follow the onscreen instructions to connect to it. After matching successfully, the blue light on the headset will flash twice per time.
4. Call: when you finish all the above steps, you are going to talk via the Bluetooth headset. When there is incoming call, press the on / talk button, you can talk with Bluetooth headset, when you want to end the call, press the on / talk button, you can end the call.
5. Turn off the headset: Press the on / talk button for 5 seconds until the red light of the headset flashes quickly for twice, then release the button, the headset will be turned off.
Mar 25, 2014 | Apple iPhone Cell Phones
My Sony Ericsson Multipoint Bluetooth headset VH410 won't charge
light is not flashing only red light is coming on charging from last two days
Sep 18, 2012 | Sony Ericsson Multipoint Bluetooth Headset...
Bluetooth is plugged into charger but keeps flashing red light, dont know if its charging or not
I had the same issue -- charged it for days and still red light flashing. I was ready to break it open and see if I could replace battery. Then I looked on the opposite end of the charger and seen a little round hole thingy. I put the end of a pen in there and pushed it twice and -- the red light went away . Plugged the charge in and steady red then purple and now blue. Looks like that is a reset ..Try it -- it worked for mine.
Sep 22, 2011 | Motorola Mobility H721 Bluetooth Headset
When I try to charge my headset, the indicator light flashes red instead of staying solid. Please help me, I love this headset and I'm so upset it won't work for me..
If this is not charging correctly it may be that the battery is no longer functioning properly. The batteries are non replaceable on this headset. If this is still under warranty (1year) you should be able to get a replacement
Here is a link to the User's Guide.
Good luck from Headsets Direct!
Aug 30, 2011 | Plantronics M100 Bluetooth Headset
I just purchased a Voyager Pro. When trying to pair it with my Blackberry, I turned the device on and held the button down waiting for the LED to flash red/blue. The device turn on blue, then flashed red...
You will need to turn off your headset and then press and hold the power button until the LED starts to flash red/blue, red/blue, it will stay in this state for a few minutes.
Good luck from Headsets Direct - 800-914-7996.
Aug 08, 2011 | Plantronics Voyager PRO Bluetooth Headset
My voyager pro+ keeps flashing red when charging. However when it is unplugged with charger, it does not work at all. Please kindly help.
If it is flashing red like it is supposed to be charging, and it is not, look at the connections. Are they worn, not connected properly? Make sure that the AC charger is plugged in firmly. If this still fails to charge your bluetooth, it may have to do with the bluetooth itself. If this is still under warranty have it replaced. Try a different outlet or charger to see if that is what is not working.
Jun 19, 2011 | Plantronics Voyager PRO Bluetooth Headset
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
Im trying to hook up my mad catz bluetooth to my ps3 and i got it pass the scan part but it keeps saying theres a problem...PLEASE HELP
Is your PS3 seeing the Headset?
Is the headset in pairing mode?
Complete details below on how to connect it:
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Feb 22, 2011 | Mad Catz Bluetooth Headset for PlayStation...
Plantronics Explorer 220 bluetooth won't pair with LG NV3 phone. It's in discovery mode and I'm getting the red/blue flashing on the bluetooth like the manual says, but it just keeps searching and will not...
Well I got it working, of course, try turning the phone off on again instead of just the bluetooth, it worked. I should have done that before posting the question.
Jul 28, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Motorola Mobility H710 Bluetooth Headset Logo
464 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
