Question about HP LaserJet P4015N Printer
I try update Firmware for Hp 4015n, but unsusscess. Now LCD display 6/6 A/F. pls, help me
I had the same problem with a 4015x. HP Support advised me to deinstall the additional paper tray and the toner and reapply the firmware update 3 times.
It sounded stupid to me but it worked!!!
Make sure to use usb connection and wait 30 min between progress.
1 st time - no paper tray, toner, wait 30 minutes
2 nd time - no paper tray, wait 30 minutes,
3 rd time - all together now, wait 30 minutes
I hope this will help you and others,
Arthur
Posted on Nov 30, 2010
Wen I connect the network cable, 49.4C02 error code appear o HP Laserjet P4014dn, pls help!
Easiest way to update firmware on this model will be to download the easy firmware update, connect a computer direct with a usb cable and then run the firmware update after the computer finishes installing the printer.
Aug 14, 2014 | HP LaserJet Office Equipment & Supplies
Nokia5130c display light problem
step 1. First try to replace the LCD screen module, check and clean the LCD pin connector.
step 2. Try to flash update the device flash firmware to any latest available version.
step 3. Check the LCD supply voltages, also check the filter coil and capacitor, replace if found damaged.
step 4. Replace the Display EMI/ESD Filter IC.
step 5. Rework, replace the Display controller IC.
step 6. If you get into this level, you may need to rework or replace the RAPIDO IC and flash update the device again.
May 14, 2011 | Computers & Internet
How do I clear this error on an HP 4015n download file now send RFU upgrade on use dev port
Thank you for contacting FixYa with your printer inquiry.
It looks like a firmware upgrade was attempted and it failed in process. When the printer was restarted int prompted this error.
I have included a link to an HP Document that addresses this issue with steps and screen shots to walk you through the process. If you are still having trouble and this printer is under warranty contact HP Customer Service. They may be able to further assist you, send out a technician, or replace the formatter with upgraded firmware.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=130&prodSeriesId=3690646&prodTypeId=18972&objectID=c01574139
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Mar 03, 2011 | HP LaserJet P4015N Printer
Hp clj cm1312 mfp firmware corrupt ready 2 download, What to me to do? Help, please
You will need to apply the firmware to the machine. I've attached the link to hp site for you to download the firmware file as well. Below the link is the directions on how to accomplish this, as well you can see the same directions on via the link provided
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=3558902&prodNameId=3558903&swEnvOID=228&swLang=8&mode=2&taskId=135&swItem=t2-85206-1
Firmware Update Notes:
  1. The Firmware Update Utility uses the USB connection to the printer.
  2. The HP Color LaserJet CM1312 MFP print driver software must be installed prior to using this utility.
  3. The HP Color LaserJet CM1312 MFP printer must be on and in a READY state as shown by the LCD display on the control panel and remain powered on during the entire firmware update process.
  4. Depending on the processor speed of your PC, the firmware update process may complete on the printer before the update status progress bar in the flash firmware update utility on the PC screen completes, this is normal.
  5. Once the update process has started, do not use your PC for any other activity until the process is complete.
  6. Do not power cycle the product or the PC until the firmware update process is complete.
Process:
  1. Download the flash firmware updater file from HP.com to the PC desktop.
  2. Turn the printer off and then back on to clear main printer memory.
  3. Double click on the file CM1312_MFP_Series_FW_Update-20100616.exe flash firmware update utility file. An HP firmware update window will open.
  4. Select the appropriate CM1312 MFP driver in the dialog window. If you assigned a different name to the HP CM1312 MFP, choose the name that represents the correct printer.
  5. Click on "Send Firmware" when ready to proceed.
  6. The progress bar will begin to move to the right indicating information being transferred.
  7. DO NOT power cycle the product or the PC during this process or the product may become unstable and or unusable without further attention from HP. The flash firmware update can take up to 5 minutes to complete. Please be patient.
  8. During the product flash firmware update, the display on the product control panel will display "Printing Document - Erasing - Programming - Complete - Hewlett-Packard - Ready - Initializing - Ready". Once the download is finished the printer will be in the Ready state.
  9. At the conclusion of the firmware update, the dialog window will show a smiley face. Click on exit.
  10. If it is desired to verify the update, use the control panel reports menu under setup to print a configuration report. The configuration report will show the current firmware revision in the Product information block, Firmware Datecode: 20100616
Oct 20, 2010 | HP LaserJet CM1312 All-In-One Printer
Printer Model : hp LaserJet 3020 OS : Windows XP(32 bit) Problem : When I did my last firmware update I interrupted by pressing the cancel button on my printer control panel as it showed "Printing...
Never ever touch the printer while upgrading the firmware.
You now need to replace the formatter
  • DO NOT power cycle the printer or the PC during this process or the printer may become unstable and or unusable without further attention from HP . The firmware update can take up to 5 minutes to complete. Please be patient.
  • During the printer firmware update, the liquid crystal display (LCD) on the printer control panel will display "Printing Document" and will change to "Erasing". After a short while, the LCD display will change to "Programming". After a short while, the LCD will display "complete : )" and the "Ready" LED on the printer will be flashing. The printer will automatically power cycle to reboot and will make noises similar to power on.
Jan 28, 2010 | HP LaserJet 3020 All-In-One Printer
LCD doesn't display anything. Removed battery and reinstalled. No success. Is there a reset process?
try these steps to fix the problem your experiencing with your LCD. most of the time this will work.
1- Remove the battery from the Harmony Remote for 10 seconds and insert it back in, and test the remote to see if the screen is displayed properly. If this does not fix the issue, please proceed with the following steps.
2- Make sure you have the latest Logitech Harmony Software (version 7.6.0) installed on your computer.
3- Connect your Harmony Remote to the computer. Run the Logitech Harmony Remote software on the computer and Login to your account.
4- Click on the "Downloads" button at the top and select "Firmware"
5- Remote will go through the firmware update, which will put the Harmony Remote back to Factory Default with the most updated firmware. Then software will ask you to select "Yes" to update the remote and click on "Next" to do a remote update, which will take the information on your account with your Devices and Activities and bring them into the Harmony Remote.
6- If this Firmware Update process does not fix the LCD screen issue, try doing a Firmware Update in "Safe Mode". To do this; remove the battery from the remote, press and hold the "Off" button on the top of the Harmony Remote and insert the battery back in to the Harmony Remote. Screen will display "Safe Mode" and then please follow the steps 3 through 5 again.
Jan 14, 2010 | Logitech Harmony 670 LCD Remote Control
NO LCD DISPLAY
Jan 09, 2010 | Logitech Harmony 670 LCD Remote Control
6110 officejet, power light blinks. display says "warming up" continuously?
Pls run the attached file to resolve the issue.
Description:
These all-in-one product firmware updates will resolve issues with receiving faxes, warming-up, certain printing issues and memory full messages with the HP OfficeJet 6100 series products.
Warming-up - Under certain circumstances when the all-in-one will display "warming up" indefinitely after pressing one of the "Copy" or "Scan" buttons
After downloading and installing this firmware update, the software will determine if the hp all-in-one would benefit from this firmware update and inform you of the results.
Installation Instructions :
Download the file "HpAiOFWUpdate2_2.exe" via http://www.printer-drivers.com/drivers/246/246484.htm to a local hard drive. Make note where (in which folder) the file gets copied.
The hp all-in-one software for the OfficeJet 6100 series must be installed on your PC before installing this firmware update. The OfficeJet 6100 series must also be connected to your PC and turned on before proceeding.
Locate the file "HpAiOFWUpdate2_2.exe" on your hard drive and double-click the file to install the firmware update.
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Sep 15, 2009 | HP Office Equipment & Supplies
Harmony
Jan 05, 2008 | Logitech Harmony 1000 LCD Touchscreen...
HP LaserJet P4015N Printer Logo
798 people viewed this question
Seeker5211
Seeker5211
