Question about Whirlpool Washing Machines
Washer won't spin and is giving a code with the letter F! Any ideas...besides call the repair man?
  • 755 Answers
Http://www.bobvila.com/wwwboard/messages/whirlpool_washing_machine_f_02_error_code__319443.html
This person cleaned their pump filter and got back up and running.
Was your code F02?
Posted on Oct 12, 2010
Machine won't complete spin/rinse cycle - begins but error codes due to unstability
Would love to help first need entire model number second did he give you the error code pertaining to this model
Sep 04, 2014 | Whirlpool WTW6400SW Cabrio Washer
My LG front load washer will not drain the water or spin out the water and it always has a series of beeps and then the error code IE which says in the manual that there is an inadequate water supply, i...
My daughters machine, a whirpool, did the same thing. A repair man came out and he told her to call back and complain about the machine....there was a recall on the machine because of a mother board problem in the computer. She called back and talked to Whirlpool and a service man came out and fixed it for free.
Jul 16, 2011 | LG WM-2277HW Front Load Washer
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
Jun 21, 2011 | Maytag Neptune MAH5500B Front Load Washer
My Roper TAWS800JQ1 will not operate while lid is down. I have to manually stick something into the hole where lid stick goes in order for the washer to rinse and spin. Are there any solutions besides a...
Try gluing (with epoxy) an extension to the lid switch actuator. The other option is to remove the cabinet top and replace the switch. Unplug the power before doing this. Hope this helps!
Oct 02, 2010 | Roper Washing Machines
Noise from spin dial...won't spin
Remove the cabinet.
Remove the motor.
Replace the direct drive coupling.
Check the pump for any blockage.
Mar 10, 2009 | Kenmore 22422 Top Load Washer
Door lock
Appreciate the direct "Ask Me".
To my knowledge, there are two (2) versions of a Frigidaire ATF6000ES Front Load Washer: a) ATF6000ES1 and b) ATF6000ES0, pls which one do you have?
If something is wrong with the washer, it could tell us the error codes and therefore would give us a general idea where to start the diagnosis. Other than the "Door Lock" is not lighted, anything else out of the ordinary? Or is the unit non-functional since it senses that the door is not lock and therefore would not engage any cycle?
To read the error codes, pls:
  • plug the washer to the mains;
  • wake the washer by pressing any button;
  • wait for a few seconds to stabilize the electronics/circuitry;
  • press and hold the Start/Pause and Cancel buttons simultaneously.
As long as the buttons are held, the failure code will appear in the display as an E followed by two (2) numbers, a number and a letter or two (2) letters. The control will beep and the Door Lock, Wash, Rinse and Final Spin indicators will flash. Pls note and postback the error code displayed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 09, 2008 | Frigidaire ATF6000ES Front Load Washer
Washing machine just keeps spinning
al indesit washer have a reset pattern
switch of with on/off button
turn selector to a large 'off dot' position
wait a couple of mins then switch back on
wait 2 mins
then switch off again and turn selector to a cycle start position
wait 2 mins turn back on and let it run the FULL cycle do not mess it about.
Sometimes it takes 2 or3 attempts so be patient
If there is a fault it will appear again within the cycle and give you an error code eg E7/E1 etc note this and call a repair man he will track it from this code.
Jan 22, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal De
