Question about Whirlpool Duet GHW9150P Front Load Washer
Wont stop washing says f 02 press cancel wont stop seems like it runs two cycles before it will stop
  • 755 Answers
Http://www.bobvila.com/wwwboard/messages/whirlpool_washing_machine_f_02_error_code__319443.html
it probably needs its internal filter cleaned because it cant drain.
Posted on Oct 12, 2010
Flashing fp on my washing machine and stops half way through cycle please help
"PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in. Press START to continue the cycle from the moment that power was lost
-OR-
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Sep 28, 2011 | Whirlpool AWM8143 Front Load Washer
During wash cycle it stops and beeps, then f 02 scrolls on screen
Hi
Thanks for using FixYa. F/02 error means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Kenmore Elite 45986 Front Load Washer
My washing machine stopped during the wash cycle flashes 02 F back and forth
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Aug 12, 2010 | Whirlpool Washing Machines
02 F message that comes on after I start a load?
Thank you !!
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer starts wash cycle and runs for about 5 mins then stops and displays F 02 on the clock
Hi
Thanks
Rylee
Jun 21, 2010 | Whirlpool GHW9300 Duet Washer
F 02 flashing on washer
Thank you !!
May 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My washer stops about half-way through the cycle and displays an "02 F" message. I have to pause, then restart in order to complete the cycle. It sometimes does this twice per cycle. Any ideas what could...
This is the problem below.
F/02
Long Drain
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
www.appliancehelponline.com
Mar 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Cabrio wtw6600 stops at rinse and flshing light and sound, then afert pressing pause resum washing
Mar 09, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
