TravelMate 800 memory speed
I just got a TravelMate 800LCi which I brought to life again after switching some parts. It now runs as it should, but would benefit from more RAM (now 512Mb - I want at least 1Gb).
Acer specs says it has PC2100 DDR2 memory (266MHz). Some tips on the netforums I've visited says it can run with PC2700.
DDR2-memorys don't often comes with these low speeds, these SO-DIMMs are scarce and expensive, so I wonder:
Can faster memorys be mounted in this particular laptop?
(I know that it can't benefit from the faster speed they're designed for, but WILL IT WORK with, let's say - PC5400?)
  • 859 Answers
Probably not. Not in laptops where the northbridge chip is hardwired to run with one ram speed. However, you can try a faster piece of RAM from a friend. Better yet, is to go to or and use their memory configurator to find out for sure.
Posted on Jun 01, 2008
Upgrade to higher cpu speed travelmate 270
CPU speed is not going to make much of a difference. You need to increase RAM (random access memory). This will make a huge difference in speed performance.
Aug 06, 2014 | Acer Computers & Internet
I have acer travelmate 800 series,the notebook stopped working so i bought a new motherboard and power switch still the laptop will not start. it is getting power but wont start, i have tried taking out...
Have you tried powering it up without any periferals?? take out the RAM, HDD, WIFI, CD, etc... I've seen a BAD wireless network card preventing the system to power up... if it seams to power up than put back stuff in one by one starting with the RAM to see what periferal is causing the problem... If not than it could be the CPU...
Good Luck!
Mar 25, 2011 | Acer for Acer TravelMate 800 Series...
What ram does the travelmate 246xc support
The memory type and speed is 200 Pin 2.5v DDR PC333 SoDimm memory.
The laptop has 2 banks of memory space each supporting 1GB of ram.
Aug 15, 2010 | Acer TravelMate 246XC (LX.T3006.191) PC...
I have an acer travelmate 660 can i upgrade things like the ram and memory to play the latest games like the sims 2 or 3
Probably not. The ram and memory are the same thing, and it never hurts to get more. However, the key to running the latest games is determined primarily by the cpu speed, and a dedicated game card, which processes more video and sound information, and accelerates the video. As they say, you pay to play, and upgrading is the way, but the latest games require the higher end machines.
Jun 16, 2010 | Acer TravelMate 650, 660, 800, 6000, 8000,...
Motherboard p3v4x : during bootup i get a system
This error is usually caused by an incorrect setting of either bus speed or multiplier (or sometimes processor chip operating voltage). These could be set either by software ie in BIOS or by changing tiny switches mounted on the motherboard.
Have you consulted your motherboard manual?
Try here:
or try the ASUS website and look under support or the discussion forums.
This will help:
These freq and voltage settings are set under BIOS which is usually accessed by hitting the DELETE key on your keyboard after turning on your computer.
Sometimes a quick fix is to enter BIOS as per the above instruction and selecting LOAD BIOS DEFAULTS or something similar to that and then save and exit BIOS and allow the computer to reboot.. That may get you to the point of booting up without the improper freq comb error.
If you have no luck playing with the above info, shut down your computer and remove the left hand side cover on your computer box or tower, so you can access the inner workings of your computer.
Remove the cooling fan from your processor chip. It will be a large square or circular (black or silver colour).
Take a look at your processor chip. Note the part number printed on the chip, which is only visible after you remove the cooling fan. For example it may say for example SL52P or something else. It may also be an AMD chip.
Search the internet for its specifications ie search for SL52P.
For example, if it was a Pentium 3 chip running at 800 Mhz go to google and search for specs of P3 800 Mhz processor with the part number SL52P.
Google returns the following info (based on the example above) of:
ie its a chip that runs at 800Mhz speed with the memory running at 133 Mhz (800 mhz processor speed obtained by having the multiplier set to 6 but actually means the memory is running at 133 MHZ but the processor running at 6 times the speed of the memory bus ie 133x6=800 MHZ (one of the settings you need to get right in your BIOS settings)
So if you had this chip, in BIOS you would select 133 bus speed, with the multiplier of 6 usually locked down on the processor physical internal wiring.
If your BIOS doesnt allow you to play with the processor and memory bus settings (commonly done to make the processor overclock to a faster speed) the other option is that you have the DIP switches on your motherboard set to the wrong settings. Again, refer to to your motherboard manual. The DIP switches are tiny plastic switch blocks on the motherboard with a row of (usually) white sliding switches.
Intel chip info:
Also Try this:
Steve (Melbourne, Australia)
May 09, 2010 | ASUS Computers & Internet
I was given an acer travelmate 4230 which used to have vista but now has xp pro. I installed acer bluetooth drivers and software, but a popup tells me that the hardware could not be found. where in the...
On the Acer site, the list does not show a bluetooth.
TravelMate 4230 Series Specifications Part Number: TravelMate4230 TravelMate 4230
Feature Description Model PN CPU RAM HDD Optical LCD LAN OS TM4230-6128 LX.TES06.008 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP PT TM4230-6240 LX.TES06.012 C2DT5500 2*1G 160 8X Supermulti. 15.4 802.11abg XPP FR TM4230-6254 LX.TES06.006 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP FR TM4230-6327 LX.TES06.036 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP ES TM4230-6433 LX.TES06.005 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6434 LX.TES06.011 C2DT5500 2*1G 160 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6704 LX.TFF06.089 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP EN TM4230-6760 LX.TES06.007 C2DT5500 2*512 120 8X Supermulti. 15.4 802.11abg XPP ES TM4230-6822 LX.TES06.030 C2DT5200 2*512 120 8X Supermulti. 15.4 802.11abg XPP PT TM4230-6909 LX.TES06.034 C2DT5200 1*512 120 8X Supermulti. 15.4 802.11abg XPP PT Part Number See models above Processor / Speed Intel® Core™2 Duo processor with Intel® EM64T support:
T7200/T7400/T7600 with (4 MB L2 cache, 2/2.16/2.33 GHz, 667 MHz FSB) or
T5500/T5600 with (2 MB L2 cache, 1.66/1.83 GHz, 667 MHz FSB) Core Logic Chipset Intel® 945PM/GM Express System Bus Speed 667 FSB RAM / Max RAM 512 MB of DDR2 533/667 MHz memory, upgradeable to 4 GB using two soDIMM modules (dual-channel support) Video Subsystem Intel® Graphics Media Accelerator (GMA) 950 with up to 224 MB of shared system memory, supporting Microsoft® DirectX® 9.0, PCI Express® LCD Properties 15.4" WXGA TFT LCD, 1280 x 800 pixel resolution Hard Disk Drive 80GB or higher CD-ROM Drive 8X DVD-Super Multi double-layer drive Battery, Primary 44W 4000 mAh Li-ion battery pack (6-cell) with up to
2.5-hour battery life or
71W 4800 mAh Li-ion battery pack (8-cell) with up to
4.5-hour battery life
(varies by model) Sound Subsystem Intel® High Definition audio support
Two built-in Acer 3DSonic stereo speakers
Built-in microphone
Sound Blaster Pro™ and MS Sound compatible PCCard Support 1Type II PCCard slot Pointing Device Touchpad Peripheral Subsystem 4 USB 2.0 ports, 1 VGA port
Headphones/speaker/line-out jack, Microphone/Line-in jack
5-in-1 card reader (SD, MMC, MS, MS PRO, xD)
Acer OrbiCam™ integrated 1.3 megapixel CMOS
(selected models) Modem 56K ITU V.92 PPT approved, Wake-on-Ring ready Ethernet 10/100 Fast Ethernet, Wake-on-LAN ready
Intel® PRO/Wireless 3945ABG (dual-band tri-mode 802.11a/b/g) Dimensions / Weight 14.09" x 10.43" x 1.15/1.41"
6.09 lbs (with primary battery) AC Power 100-240V AC AutoSensing Adapter
5 G max. pulse / 40 G max. pulse
5-27HZ, 0.16" p-p, 2g peak, 27-500HZ
+5ºC - +35ºC / -20ºC - +50ºC
10% - 90% / 10% - 90%
10,000 ft / 40,000 ft Operating System Windows XP Professional with Service Pack 2
Windows XP Home with Service Pack 2
(varies by model)
Apr 07, 2010 | Acer TravelMate 4230-6499 Notebook
Can i combine 2 different DDR2memory RAM on two slots??? my motherboard can carry DDR2-667 and DDR2-800,,, i'm really confuse if i can add 1gb of 667 and 1gb of 800 and together they can run smooth..
They will run together but at the slower speed so you are better to match speeds.
I would sell the 667MHz stick and buy the matched 800MHz, its alot quicker.
Jan 14, 2010 | Intel DG31PR Motherboard
The button to switch on wireless on my PC doesn't work
You can go from control pannel and there you can find the option for wireless option and you can turn it on.
May 24, 2009 | Acer Aspire 5500 5570-2609 Laptop
Acer travelmate 2300 - power on but as if BIOS did not start
Open the memory cover from bottom of the laptop if you can find. And re-plug the memory chips carefully..make sure it be plug in properly. and try switch on again.
Nov 05, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
