Question about Amana PTC074B25AE Electric Heat Air Conditioner
Air conditioning Interior unit will run fine all day, then the next day it will run for a few minutes, then cut off, run for a few minutes, and then cut off. We have no idea what may be causing the issue. It is so strange. Can you please help????
    Scholar:
  • 54 Answers
My guess would be from what you have described is that the refrigerant pressure might be low and is tripping the low pressure cut off that protects the compressor.
Posted on Jun 01, 2008
How do u get it to go cooler?
How to Cool Yourself in a Car Without Air Conditioning
www.wikihow.com > ... > Driving Techniques > Driving Basics
wikiHowHow to Cool Yourself in a Car Without Air Conditioning. ... some of the following suggested strategies may get you to your destination a little bit cooler ... Roll down the windows. ... Doing this will leave you cleaner and cooler for the day ahead.
Simple way to cool down your car after it's been baking in ...
? 2:30
https://www.youtube.com/watch?v=HDFNIgrvRWo
Jul 23, 2011 - Uploaded by Celso Yoshikazu Korogui
V?deo ensina como baixar a temperatura do interior do carros nos dias de muito calor.
Parked in the Sun ? Cool Down your Heated Up Car Interior ...
fixlife.org/131/remove-hot-air-fast-heated-up-car-interior-parked-sun/
Nov 21, 2015 - But with few cool tricks you can quickly get rid of the trapped hot air in your car interior and cool it down for a more pleasant drive afterwards ...
Cool A Hot Car In Under A Minute - Tested
Jan 14, 2016 | Cars & Trucks
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
Sharp split system, cutting out
If this is running in A/C mode, then I bet you have a low refrigerant charge. The compressor is dropping out on low suction pressure if it's cutting in and out every 5-10 minutes or so. If it takes hours, then it's likely a different problem.
Reply back and I can help you (been in that business for over 30 years.).
Feb 01, 2009 | Heating & Cooling
Coleman rooftop unit ac only.
These units should run in higher ambient conditions within limits. If your unit shuts down with an ambient temperature of 95°F there is a possibility that the system may have a slight over charge of refrigerant in the system or a slight undercharge. This can be easily checked under running conditions by checking the superheat of the gases returning to the compressor. You may also want to check the current draw and the voltage supply during these conditions that are causing the system shut down.
Sep 22, 2008 | Coleman Mach 15 Air Conditioner
Goodman Heat/Air unit Model # A49-20 Serial # 9909502720
It sounds like the blower motor has burnt up.(the one inside) The unit running for a few minutes then shutting off, is due to the high pressure/temperature safeties. When you removed the panels, did you notice any fan running?
Feb 17, 2008 | Goodman CKL49AR49 Air Conditioner
Hisense air conditioner
-If both compressor and fan motor starts and stop, thermostat is the defect.
- If only the compressor check for your outlet no sign of discoloration, check the voltage if normal, check the defective overload protector of the compressor it its external, or compressor itself is defective
Oct 26, 2007 | Heating & Cooling
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
