Question about Whirlpool GT4185SK Microwave Oven
The microwave is on and turntable is turning but it isn't getting heated up.
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Posted on Oct 12, 2010
Manual for a whirlpool microwave oven model wmh31017aw-1
There is no turntable control. It is always on. The turntable should change direction each time the unit is used. If the turntable is not operating, it has malfunctioned. Newer microwaves for the most part all have full-time turntables to promote even heating, thus reducing customer complaints about ovens that don't heat right.
Dec 30, 2015 | Whirlpool Microwave Ovens
Bosch microwave oven,turntable not working,food not heated
Even if the turntable isn't turning, the oven should still heat the food but it will be uneven cooking. I would suggest that the unit is not "microwaving" This is usually the high voltage capacitor, fuse or diode failure. You will need knowledge of how microwave ovens work and specialist tools to test these. If you don't, I would suggest you get a tech who does. There are extremely high voltages in microwave ovens.
Feb 23, 2015 | Bosch HMT75G451B Stainless Steel...
Turn table in microwave wont turn
Repairs are expensive. New microwaves are cheap. But you don't have to spend a dime on either. If your microwave turntable stopped spinning, here's an easy way to try and fix it. And all you need is some warm, soapy water and your own two hands. You don't have to be an appliance expert to troubleshoot a seemingly broken microwave turntable. You might find that all your little Zappy needs is a checkup and a good, thorough cleaning. If you follow these steps and find that your microwave still isn't turning, it probably means the motor has spun it's last spin. Then it's time to retire old Zappy. Unplug the microwave. Safety first, kids. Remove the glass tray and the circular turntable guide. Wash them both in warm, soapy water to get rid of anything stuck. Pay special attention to the rollers on your turntable guide, making sure they're able to spin freely. Clean the internal cavity. Make sure to check your microwave's center cavity to make sure it's free of movement-hindering (and gross) leftover food. Check that the drive bushing is working. Make sure that the drive bushing, the plastic mechanism in the bottom of the microwave's interior that the glass tray turns on, isn't worn out or split in two. If it is, you'll need to have it replaced. Put it back together. Put the turntable guide back into the circular groove. Place the glass tray turntable over the turntable guide and onto the drive bushing. Adjust until the drive bushing should fits perfectly into the grooves of the glass tray. Test it out. Zap a mug of water for a short bit to see if you fixed the problem. Do not run the microwave without anything in it.
Aug 05, 2012 | Microwave Ovens
The microwave isn't heating/cooking on any setting but the turntable, light is working. What should I check before calling a repairman?
There is nothing more you can do, you have verified everything is working except it is not heating the food. The next step is have the repairman come in to isolate the cause.
Jun 02, 2011 | Maytag MMV4205 Microwave Oven
Russell Hobbs Microwave ,it heats the food but it does not turn round.
If the oven is STILL heating, but the carousel isn't turning, the symptoms you describe are commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is usually about $25 to $45 (U.S. Dollars). If your model number is not listed at all the sites, you may also try these sites that carry the Russell Hobbs brand parts:
http://www.russell-hobbs.com/parts.shtml http://www.directpartsandproducts.com/index.php NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common procedure.
May 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Turntable stopped turning one day last week. Will turn slowly without glass plate on spindle, but not with any weight. Is there a schematic for turntable drive somewhere?
If the oven is STILL heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
repairclinic.com
The average price for a motor is about $25 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is WB26X10038 (listed as item 43). If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
May 09, 2011 | Hotpoint RVM1425 Microwave Oven
Microwave lights, clock, and everything works except when you press start, it just counts down like its cooking, but the microwave is actually not on. No hum as usual or plate rotating. It just counts...
Hi, one of the most common reasons why the turntable won't rotate is that the microwave isn't clean. The turntable guide and carousel can get sticky, preventing the turntable from properly moving. If you have built-on food particles or liquids, fill a bowl with 2 or 3 cups of water and 1 tsp. of liquid detergent and lemon. Run the microwave for about 3 minutes. Clean the microwave with a cloth, including the base of the turntable, guide, carousel grooves and microwave base. Your microwave turntable won't rotate if the grooves on the base of the turntable do not sit right on the carousel. Also, check the position of the turntable guide. Place the guide directly under the turntable. Remove the turntable, and then reposition it into the carousel grooves.
Motor The carousel motor is located beneath the base plate of the microwave. If the carousel isn't turning at all, check the motor. Disconnect the microwave from the power source, and remove the turntable, guide and base plate. Try turning the motor to see if it's just stuck. If it doesn't turn freely after a few seconds, examine the motor to see if it's burned out or corroded. Use an ohmmeter to see if the motor has continuity. If not, you must replace the motor.
Bushings The drive bushings are plastic components that sit underneath the cooking plate. Remove the plate, and examine the bushings. Use a magnifying glass if necessary to see if any debris is caught in the plastic. Clean the bushings, and reinsert the plate. Turn the microwave on to see if it rotates. If the bushings are extremely worn or if some of the plastic is broken off, you need to replace it, which is a complicated repair for consumers. Contact a service technician for assistance.
May 07, 2011 | Amana Radarange Microwave Oven
Sharp Carousel Microwave Convection R-820JS. Oven gets hot but turntable does not rotate causing uneven baking.
repairclinic.com
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is RMOTDA254WRZZ (listed as item 1-3 under the "Oven and Cabinet" parts section. If your model number does not cross reference to all websites, use the part number from the Sears website as your search criteria.
Apr 28, 2011 | Microwave Ovens
Model # UMV1152BAQ,S/N 10406839EN Linkage to
repairclinic.com
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. The part number for a replacement turn table motor for the model you have listed is W10207571 (listed as item 22 in the parts drawing under the "Internal Controls" parts section.
Apr 20, 2011 | Maytag Appliances Over-the-Range Microwave...
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Whirlpool GT4185SK Microwave Oven Logo
35 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
