Question about Craftsman 10" Table Saw
I have an older model 12 in table saw every once and awhile motor will start t smoke after using only a couple mn.
  • 7,733 Answers
The motor or the wood piece your try to cut? because if the motor is "smoking" i bet it do it once.So change the saw blade and post back please.
Posted on Oct 12, 2010
Smoking motor
The only answer to this is to take it back to where you purchased it at or call Makita.
Jan 20, 2014 | Makita 2705 10" Table Saw
I have to push blade to start and after a little while breaker trips
The Start capacitor is bad. (CD60A) Made in China the min. order is 1000 peices, replace motor cost more than the saw, or get a 200 uf 250vac capacitor (Grainger) to replace the CD60A. It is larger so you have to mount it on top of the external cap on the motor. I think the CD60A is going to be a major problem on all these saws.
Feb 18, 2013 | Craftsman 10" Table Saw
On a Craftsman 10" table saw Model 137.221960,
I have this saw. Motor just went on me (siezing up and smoking/burning) so if anyone can use parts then you're welcome to them. jmbombadil@yahoo.com in Conshohocken, PA.
Sep 20, 2011 | Craftsman 10" Table Saw
Smoking
if it is smoking when power is switch on - there is a chance that the motor winding has shorted out. OR it could just have sawdust in the motor, ( use a air compressor to blow down the saw and motor and see if this solves the problem ).
c...
Jan 02, 2011 | Bosch 4100 10" Worksite Table Saw
I HAVE A CRAFTSMAN MODEL # 137.218041,, 10" TABLE SAW. WAS RUNNING FINE, BUT WHILE CUTTING 2X4'S FOR FURRING THE SAW MOTOR STARTED SMOKING AND THEN QUIT. IT ALSO TRIPPED THE CIRCUIT BREAKER. I RESET THE...
Sounds like you may have overheated the motor. I'm surprised the overload on the motor didn't trip first. With this overheating, the windings in the motor have basically shorted out to ground. This is why your breaker is tripping. Rewinding the motor is no longer the option these days. You can try going online to www.searspartsdirect.com
May 15, 2010 | Craftsman 10" Table Saw
Want to replace under powered saw motor on sears 10"table saw
u can put a 2 and above if u want just need to have the correct rpms
Jan 26, 2010 | Craftsman 10" Table Saw
How to replace main shaft bearing
Almost all of the Skil table saws are the same setup when it comes to the motor and drive assembly. Remove your blade before servicing. You will need an arbor press, bearing seperator/puller and drill/driver bits (torx or philip depending on model) plus some adjustable ring pliers to accomplish this repair.
First thing you have to do is remove the motor from the saw. Place the saw on its wide side and adjust the motor with the height adjustment wheel so as to access the hex screws holding the motor to the rack.
Next, before removing the motor you need to remove the motor cord from the switch. Flip the table saw upside down flat on its table. Remove the switch cover and disconnect the black and white wire from the switch marking their position or noting the other wires from the cords position and the relation to the motor wires. Now you can undo the hex screws to release the motor.
Once your motor is released you can remove the spindle shaft by removing the 3 screws from the bearing housing. You can pry the assembly off with a couple of screwdrivers or by using a soft hammer and tapping the edges to remove.
Once removed you will have to remove the gear before you can get to the bearing. Use a bearing seperator/puller to pull the gear off the shaft. Once the gear is off you need to remove the woodruff key before removing the bearing. After the woodruff key is out you can remove the c-clip that holds the bearing to the shaft. Now you can use an arbor press to press the shaft out of the bearing.
Replace your bearing and put it back together. Any questions please post back.
Oct 12, 2009 | Skil Saws
Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Jul 18, 2009 | Craftsman 10" Table Saw
Smoking
Couple things I would look for first the condition of the blade do you see any buildup around the teeth like something has burnt on it. Also look into the area around the blade under the table (unplug saw first) to make sure that something hasn't dropped into it rubbing blade causing smoke. Also turn the blade by hand to make sure turning freely. The smoke could possibly be coming from a bearing. If it less than a year old Bosch has a pretty good warranty and you might look into that also. Let me know and I will dig deeper into it.
Jan 11, 2009 | Bosch 4000 - 07 Electric Table Saws
Hitachi Table Saw Quit Working
Sounds like you've got problems with the armature commutator or one of the bearings is bad. Your best bet is to take it out and visit a local motor repair shop to asses the problem. A new motor could be the answer but at some heavy duty expense.
Nov 27, 2008 | Hitachi 10", Table Saw with Stand,...
Craftsman 10" Table Saw Logo
137 people viewed this question
Top Craftsman Saws Experts
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
