What are flat panels? - Computers & Internet
  • Computers & ... Master
  • 5,660 Answers
Since your question is in the PC Desktops category, flat panel refers to the flat LCD monitors, such as this example,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5966&CatId=2776
Posted on Oct 12, 2010
I have a single blue line in the middle of the screen
Is the problem with your flat panel ?
or flat crt tv ?
In the cause crt tv, there is the problem with vertical deflection driver IC or vertical deflection coils (some times called YOKE).
In cause of flat panel tv, there is the problem with the panel, the panel may be broken.
May 04, 2016 | Televison & Video
Need fix how do i make it stop flickering
Coby lcd tv keeps flickering Flat Panel Televisions ... - Fixya
www.fixya.com > ... > lcd tv keeps flickering > Flat Panel Televisions
Coby flat panel televisions lcd tv keeps flickering related questions and answers. Ask your Coby ... Why does my Coby 40 TFTV4028 LCD TV keeps flickering.
Coby adjust air fuel mixture Flat Panel Televisions ... - Fixya
www.fixya.com > ... > adjust air fuel mixture > Flat Panel Televisions
Coby flat panel televisions adjust air fuel mixture related questions and answers. Ask your Coby ... Coby 32 in tv ... to last channel, and will stop, and will display the first channel it has got. Then we have to make adjustments on channels. ... Ad. Question about 40 TFTV4028 LCD TV. 1 Answer ... Flickering can be adjusted.
Won't turn. on red standby light changes to on but then
Jan 04, 2016 | Coby 40 TFTV4028 LCD TV
Panasonic TH50PE8U
Panasonic Product Support - TH-50PX80U
shop.panasonic.com > Get Support
PanasonicOwner's Manuals. Owner's Manuals and Documentation. Operating Instructions Manual- TH-50PX80. Warranty. Warranty information. Warranty - TV Plasma ...
Panasonic TH-50PE8U Flat Panel Television User Manual
tv.manualsonline.com > ... > Panasonic Flat Panel Television
... and free pdf instructions. Find the user manual you need for your TV and more at ManualsOnline. ... Panasonic TH-50PE8U Flat Panel Television User Manual ...
Oct 29, 2015 | Panasonic Televison & Video
How do I replace fuse?
Sharp LC46D43U - Aquos - 720p LCD HDTV Service Manual
www.manualslib.com > ... > Service manual
Flat Panel TV Sharp AQUOS LC-46D82U Operation Manual. Sharp flat ... Flat Panel TV Sharp LC46SB54U - LC - 46" LCD TV Operation Manual. Operation ...
Sep 11, 2015 | Sharp Televison & Video
Vertical blue line running down screen
Hello
Most likely there is a problem with the Flat Panel TV itself. I have had Flat Panel TV over the years that developed all sorts of problems. Some for example only displayed everything in pink or green because they lost the ability to keep a neutral color. Flat Panel TV just go bad out of the blue, just like hard drives, there is a % error in Flat Panel TV that just happens due to production or usage.Usually this can be repaired but it costs more than a new Flat Panel screen is worth. I would suggest if the Flat Panel TV is out of warranty to go to the local store and pickup new one. If you still have a warranty on your Flat Panel TV talk to the company on their 1800 number and see if they can offer you a solution. If they ask you to send it in and you pay postage its a bad deal as postage on a Flat Panel TV is spendy.
Good Luck
Dec 26, 2010 | Sansui Televison & Video
Dell 42" Flat Panel TV....Multi colored lines on screen...twinkling colors
your flat panel set was hit by something causing the pixel lines. from physical force. sorry to tell you this but the display panel has to be replaced. call a service shop for verification.
Mar 09, 2010 | Televison & Video
ATI RAdeon HD2400 in Dell Optiplex 755.
From the AMD.Com website: Display Support
  • One Dual-Link DVI-I connector for high-resolution digital displays
  • ATI Radeon™ DVI-I to HDMI2 with 5.1 audio (adapter)
  • One VGA analog connector
  • HDTV Component (YPrPb) output (adapter)
  • Drive two displays simultaneously with independent resolutions and refresh rates4
  • TV output requires HDMI, component, S-video or composite cable (not included)
Two integrated DVI display outputs
  • Primary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI) or 2560x1600 (dual-link DVI)1
  • Secondary supports 18-, 24-, and 30-bit digital displays at all resolutions up to 1920x1200 (single-link DVI only)1
  • Each includes a dual-link HDCP encoder with on-chip key storage for high resolution playback of protected content2
It does using dual link DVI. Is that the cable you are using?
Here is a link to the complete specs
Sep 15, 2008 | ATI RADEON HD 2400 PRO Graphic Card
Sound
Hey merrybell;
So, you have a flat panel with no sound?
Well, with out Brand or Model let me start here:
1. Unplug 'flat panel',cable box or sat. box from the power source, a/c cord from wall, for at least 4-5 minutes, plug back into wall.
2. Make sure volume level on TV and boxes are turned up, some cable boxes have volume controls.
3. Ensure that speakers are turned on, some 'flat panel's' have options of turning speakers off. Check menu....audio/sound.
4. Double check all cables from 'flat panel' to "boxes", make sure they are secure.
5. Try different inputs and devices (dvd) on 'flat panel' or cables.
6. If still no audio, one the boards may be defective.
If so make sure you call a factory authorized service dealer to service your 'flat panel.
Good Luck, Big Irish, get back if have any more info.
Jun 20, 2008 | Televison & Video
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
