Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Star like spots on sreen started with one increased to 16 within 3 weeks
  • Mitsubishi Master
  • 5,138 Answers
Bad Light Engine. Encompass Parts 1-800-638-3328
UED 1-800-648-6657
Posted on Oct 12, 2010
Cornditioner heating element burns out within 2 weeks. New element has burned spot in less than 3 minutes.
Make sure the voltage is correct and matches the power source.It is possible the blower is not turning to keep air blowing across it? There also should be a theremostat that shuts it off if its getting too hot. Any one of these could cause that to happen.
Aug 11, 2015 | Cretors Merchant 16 oz. Counter Popper w/...
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Our 65" Mitsubishi rear projection screen has developed spots, like stars. Is this fatal, or is there a cleaning process that will remove the spots?
sounds as if you may need to degauss (remove residual magnetic field) your set, such magnetism can cause the final image to become distorted. many televisions have a degauss utility in their menues
Sep 14, 2014 | Mitsubishi WD Televison & Video
CCTV power supply keeps decreasing the voltage
Your power supply appears to have a capacitor that is breaking down located within the diode bridge. You will need to replace the power supply or get it repaired.
Jul 16, 2012 | Optics
I AM GETTING LITTLE BLACK SPOTS WHICH ARE MULTIPLYING,AND NOW ARE BLINKING LIKE STARS IN MY SCREEN..STATRED IN ONE SIDE,AND SEEMS TO BE SPREADING ACROSS THE SREEN
sounds like the lcd panel is beginning to fail. you will need a tech to figure out if it is the panel, main board or lvds cable. Last time I saw this it was the panel.
Oct 26, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Numerous white spots on Smasung DLP TV
same problem for me ... check out this thread on AVSforums about it.
I have the same exact tv as you and had the same problem. I took it to a repair shop who told me I needed a new DMD chip and that it would be 850 to fix. I used the information in thread above to get the part number and bought the chip on ebay for under 200. Here is a link to the listing CHIP
People have had good success. I will be replacing mine tomorrow.
Feb 26, 2009 | Samsung HLS4676S Television
BAD LIGHT ENGINE call UED 1-800-648-6657
Feb 15, 2009 | Samsung HL-S4266W 42" HDTV
See link below for "field of stars" fix:
http://www.avsforum.com/avs-vb/showthread.php?t=1107926
Worked a charm on my 50" Samsung DLP. Read thread carefully as there are 2 different version of the DMD chip you will need to replace. I ended up fixing mine for less than $165!
Chuck
Feb 07, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Spots on sreen
Your spots on screen is normal, which is called color spots.Those were often found on crt tube, where discharge to grounding is slow.
Rdgs
Alan
Feb 24, 2008 | Mitsubishi WS-55807 TV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
