Question about GE WBVH6240F Front Load Washer
GE WBVH6240F shut door hit start button and lock door light comes and door is locked then a second later lock door light goes off and machine will not work
  • 1 more comment
  • suzycue Jun 01, 2008
    door lock light comes on, drum spins once, door lock light goes off and the pause light starts blinking.... I've already checked drain hose, taken front panel off, removed drain plug, lots of junk came pouring out... checked the hoses, (found coins, cut up credit card, and misc plastic objects) removed the pump, opened and checked for blockage (found only lint.) Put all back together, thought it was fixed, but now doing the same thing.... afraid this might require expensive repair??
  • bobivey Jun 08, 2008
    I have the same problem.
  • cruisesinc Jun 09, 2008
    I am also having same problema
I got the same problem...
Posted on Jul 11, 2008
Door wont stay locked to run a load
You have a faulty door latch assembly and it will need to be replaced. Here is the part you need.
Oct 21, 2012 | Maytag Neptune MAH5500B Front Load Washer
Water in tub and nothing happen when we try to wash cloths
usually this is indicitive of a bad pump or something stuck in it.these machines when first started they try to pump out first
the cycle will continue as long as it senses water
have them inspect the pump
good luck with sear service i hope it goes well
Oct 13, 2009 | GE WBVH6240F Front Load Washer
My GE Washer Door Won't Lock
Try this, press the pause/cancel button twice. Open the door, ensure there is nothing blocking the door and close the door fully. Open the detergent drawer fully and re-close the drawer. Select Quick wash and press start.
If this does not correct the problem, call for service under warranty.
clarkco
Feb 19, 2009 | GE WBVH6240F Front Load Washer
GE WBVH6240F
check the door lock it may have a bad connection will the door lock?
Jul 11, 2008 | GE WBVH6240F Front Load Washer
Ge wbvh620f will not run
this is a good candidate for a premium solution, me thinks..
May 23, 2008 | GE WBVH6240F Front Load Washer
How do I clean my frigidaire self clean gas oven
after the three hour prompt comes up hit start while the door lock light is blinking and let me know what it does
Jan 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Washer load became imbalanced and forced door open, now cannot close door, lock stuck and washer will not run
Perhaps you have to change your lock, this is a sensitive point & will affect the smooth operation of your machine. Re. the inbalance, you hv to screw up & lock the front 2 legs (with check nut), adjust the front legs (screwed up) only to see if the machine does not move during wash/spin.
Nov 13, 2007 | GE WBVH6240F Front Load Washer
Door clicks and wont open and washer runs but wont do anything
Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit. - Door Lock/Switch unit Failure You should remove machine's top cover and then you will have an access to the door lock unit. Be aware you should discconect machine's power cable first !! Good luck!
Jun 15, 2007 | GE WBVH6240F Front Load Washer
GE WBVH6240F Front Load Washer Logo
409 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
